CIH Explained - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-29-2013, 09:37 PM - Thread Starter
coolrda's Avatar
Quoted: 852 Post(s)
Liked: 615
Here's some good info at HD Digest via Josh Z.
http://www.highdefdigest.com/blog/constant-image-height-refresher-2013/
coolrda is offline
post #2 of 6 Old 07-30-2013, 10:35 AM
John Schuermann's Avatar
Quoted: 818 Post(s)
Liked: 782
Josh has always done an excellent job explaining the fundamentals of the CIH concept. This is a great place for anyone to start learning about this aspect of the home theater hobby (no pun intended).
John Schuermann
www.thescreeningroomav.com Home Theater Design john@thescreeningroomav.com
JS Music and Sound Post Production Audio / Original Music for Film and Video
Check out my new movie!: www.stephensonmovie.com
John Schuermann is offline
post #3 of 6 Old 07-31-2013, 01:20 PM
Josh Z's Avatar
Quoted: 2143 Post(s)
Liked: 1439
A follow-up piece for those interested:
http://www.highdefdigest.com/blog/constant-image-height-refresher-2013-part2/
CAVX and Trogdor2010 like this.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #4 of 6 Old 07-31-2013, 08:08 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
That is a good blog Josh.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #5 of 6 Old 08-21-2013, 02:20 PM
Josh Z's Avatar
Liked: 1439
Panamorph CineVista review:
http://www.highdefdigest.com/blog/panamorph-cinevista-review/
Josh Z
Josh Z is offline
post #6 of 6 Old 09-14-2013, 07:52 PM
MrsMiniver's Avatar
These two articles provided some really informative information to those who are unaware of common height vs common width. I would like to add a few more points that should be mentioned:
1. Speaker placement, the beauty of common height means that the speakers behind the screen will always stay in the same position, when looking at the screen, you will be looking at the exact same "eye-level" spot for both 1:85 or 2:40 features. For those who are building home theater with the speakers behind the screen, you should try to make sure that the L-R speakers are aligned with the edge of the 1:85 screen, not outside the 1:85 area.
2. Masking WILL improve contrast perception.
3. Original SCOPE 2:35 images are higher resolution images than 1:85, there is more light hitting the film frame and when projected the whole frame is used, when SCOPE is viewed on Blu-ray, the SCOPE or 2:40 image becomes the lower resolution image vs 16x9 which is the full resolution, it is almost like a reversal.
4. FLAT or 1:85 should NEVER be projected larger than the 2:40 image, having the 1:85 as being smaller than 2:40 was the intention.
MrsMiniver is offline
Reply 2.35:1 Constant Image Height Chat
