Need Advice on CIH projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 08-05-2013, 10:31 AM - Thread Starter
alan_ct's Avatar
Quoted: 26 Post(s)
OK heres my dilemma...I have a JVC DLA-HD350 at the moment which has non memory motorized lens control...My buddy is buying it of me so It's time for an upgrade! I am using a 138" 235:1 scope screen. I made side masking panels for 16x9 viewing...My question is I like the DLA-RS46U due to the fact of its ability to memorize the aspect ratios...It takes a long time with HD350 to go back and forth. A real PITA...But after reading the reviews of the Epson 5020UB it seems like an overall better PJ than the JVC...I do intend to do some 3D viewing...I am just thinking the extra brightness in 2 and 3D is a big plus for my screen size. My room is very dark cause i know you will ask! Does anyone have any insight on setting the lens shift and zoom manually on the Epson? I think the Epson will be a better choice excluding the fact of the lens shifting. Price of the PJs about the same but you have you spend many more $$$ on glasses and emmitters with the JVC Opinions? Thanks!
alan_ct is offline
post #2 of 14 Old 08-05-2013, 11:04 AM
skater2's Avatar
Quoted: 38 Post(s)
Liked: 44
I'm sure that someone who knows more than me will chime in on this, but if you want the Epson, the 6020UB is basically a 5020UB, but with anamorphic support, and a couple of 3d glasses and an extra bulb for your expense. Maybe that's an option?
skater2 is offline
post #3 of 14 Old 08-05-2013, 02:12 PM
Josh Z's Avatar
Quoted: 2382 Post(s)
Liked: 1567
I recently test drove an Epson 6020UB. Personally, I would not give up a JVC for that. Yes, it's brighter, but contrast is crap (with or without the auto-iris) and it's loud as a freakin' Hoover, even in low lamp mode. If you do engage the auto-iris (and black level is an unbearable bright gray without it), you'll hear the loud mechanical whizzing every time it adjusts several times a minute. I've used other projectors with auto-irises (I currently have a Sharp DLP for 3D viewing), and none were this loud.
Other than brightness, I was not impressed with anything about the projector.
My $.02. I acknowledge that JVCs are useless for 3D.
alan_ct likes this.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #4 of 14 Old 08-05-2013, 03:22 PM
Glenn Baumann's Avatar
Quoted: 113 Post(s)
Liked: 54
alan,
Take a look at the Sony HW50 as it is also LCOS with nice blacks and seems to offer a nice balance of 3D, brightness, color and motion! eek.gif
alan_ct likes this.
Glenn Baumann is offline
post #5 of 14 Old 08-06-2013, 07:36 AM - Thread Starter
alan_ct's Avatar
Quoted: 26 Post(s)
Yikes, Josh,Thats not a great review on the 5020 especially the fact it will be directly over my head! Thanks...Glenn, I will take a look at the Sony as an alternative! Al
alan_ct is offline
post #6 of 14 Old 08-06-2013, 09:19 AM
John Schuermann's Avatar
Quoted: 1297 Post(s)
Liked: 1341
Hey Josh - is that the Epson we sent you? I used it in my home pretty extensively, and I didn't find the noise at low lamp mode objectionable at all. I also did not hear the auto iris working (though I did SEE it working). At high lamp mode, yes, it was very noisy.
Just curious. I wonder if it developed an issue during the transport to your home? Assuming it is the same one, that is.
John Schuermann
www.thescreeningroomav.com Home Theater Design john@thescreeningroomav.com
JS Music and Sound Post Production Audio / Original Music for Film and Video
Check out my new movie!: www.stephensonmovie.com
John Schuermann is offline
post #7 of 14 Old 08-06-2013, 09:25 AM - Thread Starter
alan_ct's Avatar
Quoted: 26 Post(s)
Originally Posted by Glenn Baumann View Post
alan,
Checked it out..Great reviews! If it had a motorized lens memory it would be a go...But at 4K Its a no go for me! smile.gif
alan_ct is offline
post #8 of 14 Old 08-06-2013, 10:11 AM
Josh Z's Avatar
Liked: 1567
Yes, it's the same unit. It could be that I had the projector closer to my seating position than you do. It didn't sound like it was broken. It was just loud. These Epson models are much brighter than most of their competition, which means that their lamps put out more heat and need more fan action to stay cooled.
The Sharp DLP that's currently in the same spot is much quieter. I can't hear its iris at all, whereas the Epson had an audible "bzzt... bzzt... bzzt...bzzt..." every time the iris engaged. It sounded like C3PO was waving his arms around behind me. Brightness pumping in the image was distracting as well.
The electronic color correction worked as advertised in dialing out the CineVista's chromatic aberration, which was very useful in my evaluation of the lens. But other than that, I wasn't too impressed with the Epson in general.
I suppose I could just be spoiled, but if the o/p is thinking about trading out a JVC for an Epson, I think he may be disappointed.
Josh Z
Josh Z is offline
post #9 of 14 Old 08-06-2013, 10:50 AM
Liked: 1341
Personally, I like the JVC better too, but the Epson surprised me. I had evaluated LCD projectors in the past and always found them to be very lacking. The 6020 was the first unit I evaluated that I really liked.
Russell has a 6020 currently and says that it is very quiet except in 3D mode where it gets quite loud.
Brightness pumping also distracted me, as it does on all projectors with an auto iris. I'm surprised that more people who go on about "director's intent" don't complain about the overall image varying in brightness, as certainly the filmmakers did not intend for the picture to get brighter and darker depending on picture content...
John Schuermann
post #10 of 14 Old 08-06-2013, 10:51 AM
Liked: 1341
Check out all of these 3D projectors under $4K:
HW50ES, Epson 6020, BenQ W1070, Optoma HD25, JVC X35
All happen to have vertical stretch as well, so can be used with an anamorphic lens. The only unit with lens memory is the JVC.
John Schuermann
post #11 of 14 Old 08-06-2013, 11:14 AM
Liked: 1341
Just wanted to point out that Sony and JVC also have the electronic color correction capabilities of the Epson.
John Schuermann
post #12 of 14 Old 08-06-2013, 12:57 PM - Thread Starter
alan_ct's Avatar
Quoted: 26 Post(s)
Not enough cash for an A~lens in my wallet unfortunatly:eek:I think I will stick to the R46 for now and deal with the poor 3D quality...90% of my viewing will be 2D anyways...I am really sick of the screen dance and looking forward to the aspect memory function:)
alan_ct is offline
post #13 of 14 Old 08-07-2013, 02:04 PM
Josh Z's Avatar
Liked: 1567
Do the new models allow independent zone correction like the Epson? My JVC RS40 (which is a few years old) can shift the entire panel for each of the colors, but doesn't offer independent control of each corner.
Josh Z
Josh Z is offline
post #14 of 14 Old 08-07-2013, 06:08 PM
Liked: 1341
Yep - independent zone correction on all of the newer JVCs (and the Sony HW50 and up).
John Schuermann
Reply 2.35:1 Constant Image Height Chat
