Mits HC7800 with A lens - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-11-2013, 12:28 AM - Thread Starter
john hunter's Avatar
Quoted: 35 Post(s)
Have been planing my home theatre /music room for some time and as usual have to make some practical adjustments to my original ideas. I now can only manage an 8 ft wide Scope screen with a throw of 14 ft.
Had originally decided to go with a JVC 55 but with 4k on the horizon,it makes spending that sort of money a bit silly at the present time,at least for me.
Out of the blue, I have been offered a MITS 7800D .
It's ex demo but with only 48 hours on the clock. It has the 2 anamorphic modes which is great but I can only find out that the lens is a "1.5:1 zoom"
Am a bit concerned that with a 14ft throw the picture will be, ironically, too big.
So kind users of this site and anamorphic lovers, is it OK to use with an A lens on a 14 ft throw to give a Scope image 8 ft wide.????
Am thinking of a CineVista or Aussiemorph lens.
Help.
john hunter is offline
post #2 of 5 Old 08-11-2013, 10:20 AM
John Schuermann's Avatar
Quoted: 814 Post(s)
Liked: 782
Your specs are fine - an 8 foot wide screen should be no problem with a 14 ft. throw.
John Schuermann
www.thescreeningroomav.com Home Theater Design john@thescreeningroomav.com
JS Music and Sound Post Production Audio / Original Music for Film and Video
Check out my new movie!: www.stephensonmovie.com
John Schuermann is offline
post #3 of 5 Old 08-11-2013, 05:05 PM - Thread Starter
Quoted: 35 Post(s)
Thanks for that, John. I'm on my way!
Always liked curved screens since Cinerama days. I have read about the advantages of them with A lens.
Do I need one with this set up or is it just a matter of taste?
Thanks again. Your help has been invauable.
post #4 of 5 Old 08-12-2013, 10:56 AM
Quoted: 814 Post(s)
Liked: 782
You won't *need* a masking screen, but you may want one. We usually recommend them if you are at a throw ratio of three times the screen height or less. Your screen is about 3 1/2 feet tall, which puts minimum throw at 10 feet. You are considerably farther back than that, so you should have minimal pincushion. A screen with a slight curvature would be ok, although a flat screen screen will work fine. Since you have a fairly long throw, I would suggest a screen aspect ratio of 2.35:1.
John Schuermann
post #5 of 5 Old 08-12-2013, 05:07 PM - Thread Starter
Quoted: 35 Post(s)
Will do. Cheers and thanks.
Reply 2.35:1 Constant Image Height Chat
