ISCO IIIL (and general A-lens) set up questions - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 33 Old 11-01-2013, 09:06 PM
stanger89's Avatar
Quoted: 3308 Post(s)
Liked: 1769
Originally Posted by Brian B View Post
Will inserting the Duo back in the chain let me store a zoomed preset for 2.35/39 that will eliminate the black area??
I can't say for sure, not knowing the Duo, but yes, you should be able to electronically crop the sides off of 2.40:1 content. You should also be able to properly crop/expand 1.85:1 content, or anything in between (like 2.20:1 movies).
stanger89 is offline
post #32 of 33 Old 11-02-2013, 12:56 PM - Thread Starter
Brian B's Avatar
Quoted: 235 Post(s)
Liked: 104
Looks like I'll have some work to do this weekend and see how it goes.
B.
Brian B is online now
post #33 of 33 Old 11-10-2013, 06:34 PM - Thread Starter
Brian B's Avatar
Quoted: 235 Post(s)
Liked: 104
So, I spent a few hours tweaking and watching. I re-inserted my DVDO Duo as well (with the idea to use it for calibration eventually) and tried using it for squeezing the image vs. the projector.
First I re-centered the projector and focused for 1.78:1 with a slight spill onto the borders. Then I used the AVS 709 disc's 2.35 grid as a guide for adjustment of the lens. I found I could turn the focusing (on the lens) and make the image slightly bigger or smaller as desired. I figured I could try zooming and cropping the image with the Duo for slightly wider films to eliminate the bars below, but it wasn't really a big deal with what I watched.
I didn't find there to be a large difference (if any) visually from my seating distance between the squeeze in the projector vs. the Duo.
Next I tried watching a few minutes back and forth between the image with the lens in place vs. the projector zoomed. I didn't find there to be much difference (aside from the hassle with my projector which does not have preset memories).
Since my room is not a "batcave" there really wasn't visible spill below the screen--this was a concern for me before I tried it.
I think the sensible thing to do for me is to sell the lens and sled, sell the projector and upgrade to a newer model that I can just zoom. Less gear, less complication and adjustment for me initially and most importantly the chance to have a newer model with e-shift, more light output and hopefully a better image. I'm thinking this will hold me over for a few years until 4k (or whatever) makes a dent.
Thanks for all the advice and help.
What is a reasonable price to ask for the lens + sled?
Brian
Reply 2.35:1 Constant Image Height Chat
