2.35:1 screen using two projectors (1 for 16:9 other for 2.35:1) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-02-2013, 08:33 PM - Thread Starter
BitChin2's Avatar
Looking for opinions, or perspective from anyone that has setup this way.  My room is in final build stage - 20' x 24' x 10' with 1st row ~ 11.5' from screen 2nd row ~ 18.25' and bar seating behind that.
want 140" wide 2.35:1 screen, but option for 16:9 HDTV and occasional movie.
BitChin2 is offline
post #2 of 5 Old 10-04-2013, 12:13 PM
sipester's Avatar
Due to the ever lower price of projectors these days and the unchanged cost of an automated sliding mechanism for the lens, that seems like it might be a good option (you could even do a fixed CineVista lens if you want for the 2.35:1 image). Dual screens can also be cheaper than one screen with an automated masking system.
sipester is offline
post #3 of 5 Old 10-04-2013, 02:02 PM
blastermaster's Avatar
Quoted: 433 Post(s)
Liked: 550
Assuming you have an anamorphic lens and depending on how far away your projector is from the screen, you may want to consider a curved screen. They look super cool and are functional in that they remove the pincushion effect from the lens. I have found that less light gets reflected off the side walls because of the curve. FWIW I have a 138" curved DIY 2.35:1 screen. For 16:9 you could get a manual or automatic (expensive) setup. I'm going to make some panels wrapped in velvet and either use earth magnets to hold them in place or find a way to hang them.
Here's a link to a few pics I posted:
http://www.avsforum.com/t/842769/the-official-seymourav-center-stage-screen-thread/1980
I used Seymour AV Centerstage XD material. All in the screen cost around $350 iirc.
Video: Optoma HD3300, Panamorph UH480, Darbee Darblet, Samsung BD D6700 Blu Ray player, DIY Seymour Centerstage XD 138" Curved Screen
LCR - Tannoy DC12i, Sides - Tannoy IW63, Rears - Tannoy Saturn DC6ti Bookshelf, Ceilings - Tannoy CMS 603DC (TF), Tannoy CMS 601DC (TR), 3 Micro Marty/1 Full Marty DIY subs
Amplification: Emotiva XPA-3, Emotiva XPA-2, Outlaw Audio 7700, 2x Inuke 6000DSP
Receiver: Anthem MRX 720
blastermaster is online now
post #4 of 5 Old 10-04-2013, 06:06 PM
Socio's Avatar
Another option might be the Elite Peregrine Twin series screen with both 16.9 and 2.35 screens in one;
http://www.elitescreens.com/index.php?option=com_content&view=article&id=15&catid=1&Itemid=19&lang=en
But the largest screen is 133 inch.
Socio is online now
post #5 of 5 Old 10-05-2013, 08:16 PM - Thread Starter
BitChin2's Avatar
Have my material and will be installing a 144" x 81" screen - will think a bit about if it should curve or be flat.  I have a box frame that will include curtains to allow masking on sides and top - may add mask for bottom if it bothers me.  My real concern is how to display 16x9 content at constant height - that will now be later project as initial screen will support 16x9 at same width as 2.35:1 content, although I think it will be too large for front row - might pick up an Epson 200 for smaller 16:9 viewing (main projector will be Epson 5030 or 6030
BitChin2 is offline
Reply 2.35:1 Constant Image Height Chat
