2:35 vs 16:9 - Does my projector support both? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-20-2014, 05:11 PM - Thread Starter
joetheater's Avatar
Quoted: 16 Post(s)
Very novice question, but I just bought the Panasonic AE-8000U projector and it says it supports 16:9 aspect ratio. Im trying to determine what size screen to put in my dedicated home theater and am not sure whether I have to only get the 16:9 size or whether I should go for 2:35:1. If I buy the 2:35:1 will it still support the 16:9 format and just give me more flexibility if I end up watching a 2:35:1 movie? I had thought the only difference was that black bars appear on the screen when watching a 16:9 movie on a 2:35:1 screen. Is that correct?
thanks in advance
joetheater is offline
post #2 of 4 Old 01-20-2014, 07:35 PM
ch1sox's Avatar
Quoted: 323 Post(s)
Liked: 114
I have the Panasonic 8000 as well and a 2.35 screen. A 2.35 will support 16:9 just fine. When watching 2.35 content the screen will keep the same height as 16:9 content, but zoom to fill the entire screen. I personally like 2.35 because I want my movies to feel HUGE, immersive and larger in scope than TV shows. If you watch 16:9 content on a 2.35 screen, you'll have bars on the left and right. If you watch 2.35 content on a 16:9 you'll have bars along the top and bottom. I have more space for width rather than height so I got the biggest 2.35 I could fit (133"). This makes a 106" screen for 16:9 and I don't even realize the bars on the side. I do have a Black Diamond screen which probably helps, but you could always use masking if you get a white screen. There are some great ideas for fabric masking on these forums.
ch1sox is online now
post #3 of 4 Old 01-21-2014, 05:57 AM - Thread Starter
joetheater's Avatar
Quoted: 16 Post(s)
Thanks. This is very helpful. It sounds like the 2:35:1 is the way to go. It sounds like I have a setup similar to yours where I have limited height to work with but a lot of width. I haven't paid much attention to which movies are 2:35:1 vs 16:9 when they come out on DVD or blueray but I assume it's clearly marked? Will be interesting to see how much I notice the difference.
post #4 of 4 Old 01-21-2014, 10:22 AM
Josh Z's Avatar
Quoted: 2469 Post(s)
Liked: 1622
Here are two tutorial articles that may help you get started:
http://www.highdefdigest.com/blog/constant-image-height-refresher-2013/
http://www.highdefdigest.com/blog/constant-image-height-refresher-2013-part2/
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
Reply 2.35:1 Constant Image Height Chat
Panasonic Ptae8000u Hd Projector
