2.35 vs 2.40 Question - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By Josh Z
  • 1 Post By gravi
Old 06-16-2014, 07:56 PM - Thread Starter
gravi's Avatar
Quoted: 61 Post(s)
Liked: 26
I recently set up a 2.35 screen paired with a JVC RS46 projector using lens memory. I set up the 2.35 memory using the built-in image pattern - JVC has two vertical lines and they suggest the outer line to just barely cross the frame on the sides. I watched a 2.35 formatted movie (Star Wars) and it was perfect. When i put in a 2.40 format movie (Indiana Jones) I was expecting tiny black bars on the top and bottom, just barely visible. But the image completely filled the screen. Does this means I overscanned the 2.35 setting?
gravi is offline
Old 06-16-2014, 08:20 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
More likely the transfers are not 2.40 and the disc's packaging just lists them incorrectly... There's pre-70's history on the 2.35 vs. 2.40 - someone will chime in with facts there.
jautor is offline
Old 06-16-2014, 10:12 PM
Mark12547's Avatar
Quoted: 712 Post(s)
Liked: 472
There is a 3-year-old thread here on the subject.
The thumbnail explanation is that in the industry 2.35 and 2.40 were often used interchangeably (especially by the marketing department) so if you get a film marked 2.40, you don't know if it is 2.35:1, 2.39:1, really 2.40:1, or even 2.41:1.
My very humble setup:
Spoiler!
Mark12547 is offline
Old 06-17-2014, 11:15 AM - Thread Starter
gravi's Avatar
Quoted: 61 Post(s)
Liked: 26
Thanks for the explanation. I did not know that.
gravi is offline
Old 06-17-2014, 11:27 AM
Josh Z's Avatar
Quoted: 2137 Post(s)
Liked: 1434
This is a common point of confusion. I wrote an article on the subject last year:
http://www.highdefdigest.com/blog/co...er-2013-part2/
ellisr63 and Mark12547 like this.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
Old 06-17-2014, 06:57 PM - Thread Starter
gravi's Avatar
Quoted: 61 Post(s)
Liked: 26
Excellent article, very informative and a great concise history of cinematic aspect ratios. So thank you for the link.
I had no idea that from a production standpoint both 2.35 and 2.40 meant the same thing, at least from 1970 onwards. What I don't get is, despite the mis-labeling, why commercial vendors (video processors, screen manufacturers, etc.) did not adopt the actual 2.3942 ratio, regardless of what it was called.
I would also be curious to know if someone has actually measured blu ray releases over the last several years and charted if the vast majority are also closer to 2.40.
ellisr63 likes this.
gravi is offline
Old 06-18-2014, 05:55 AM
stanger89's Avatar
Quoted: 2634 Post(s)
Liked: 1354
What do you mean by "adopt"? My Lumagen can be set to just about any AR you can think of.
stanger89 is offline
Old 06-18-2014, 08:44 AM - Thread Starter
gravi's Avatar
Quoted: 61 Post(s)
Liked: 26
But not the stretch implemented on projectors. Similarly, screen vendors sell 2.35 format screens unless you explicitly customize. What I meant was that regardless of the nomenclature, if the vast majority of recent movies were indeed 2.39 why is the ratio that is most commonly implemented in products 2.35. Surely the industry knew 2.35 was actually 2.39 in most cases?
gravi is offline
Old 06-18-2014, 10:28 AM
stanger89's Avatar
Liked: 1354
What's usually on projectors is a 1.33x stretch, which is the exact match for a 1.33x anamorphic lens, and comes out to be right about 2.37:1 actually.
The reality is "2.35:1" is the term everyone understands (whether it's technically accurate or not), and the difference between, 2.35:1, 2.37:1, 2.39:1 and 2.40:1 is within the noise.
Old 06-18-2014, 11:29 AM
jeahrens's Avatar
Quoted: 475 Post(s)
Liked: 198
My guess is the industry knows very well there is variance and the screen manufacturers just picked a ratio and went with it. It's not really worth trying to make multiple screens or figuring out the most common of the 2.x aspects and building multiple screens when the differences when projected are very small.
While I understand the desire to be accurate, the reality is that simply over-scanning the left and right boarders by an inch or so has made every scope film fit my 2.35:1 screen fine. Unless that isn't an option or you simply must have it exactly right, that would be my suggestion. Then you can just relax and enjoy.
jeahrens is offline
Old 06-18-2014, 02:13 PM
Josh Z's Avatar
Liked: 1434
I don't know of anyone who has systematically charted this, but I can tell you that it's a total crapshoot what you'll get, and you cannot rely on the disc packaging to be accurate.
Some studios are pretty good about transferring at 2.40:1 (Warner, Paramount, Sony). Others are hit-and-miss. With Fox, you'll typically get 2.40:1 for brand new movies (though there are exceptions), but 2.35:1 for catalog titles, even those movies made well after 1970.
Josh Z
Josh Z is offline
Old 06-18-2014, 03:01 PM
stanger89's Avatar
Liked: 1354
It would be interesting if one could get Kaleidescape to part with that info. My understanding is they actually "measure" each disc so they can store the exact metadata to allow precise placement of automated masking systems.
Old 06-18-2014, 06:15 PM
DavidHir's Avatar
Quoted: 1702 Post(s)
Liked: 1320
Yeah, newer releases I've watched lately have all been 2.40 it seems, yet catalogs always 2:35.
DavidHir is offline
Old 06-25-2014, 12:01 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3038 Post(s)
Liked: 2970
And just when get your 2.37:1 screen installed, you'll watch Ben Hur ( 2.75:1 ) and Lawrence of Arabia ( 2.19:1 ) and you're back to square one !
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
Old 06-28-2014, 01:12 PM
DavidHir's Avatar
Liked: 1320
True, Craig. I've been wanting to watch Ben Hur just to see what it looks like on my screen. Lawrence is on my soon-to-watch list too.
I went with a 2:35 screen over 2:40 for the simple fact it makes 1:78-1:85 and 2:35 content look very slightly, yet noticeably larger to my eyes having tested it out. My zoom on my projector is already maxed out and so I do see very thin horizontal bars on 2:40 material if I look for them, but it's a total non-issue as they are so black especially on my JVC RS4810.
DavidHir is offline
