Sony VPL-VW1100ES and anamorphic lens - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1 of 34 Old 07-21-2014, 06:31 AM - Thread Starter
Micke_'s Avatar
Quoted: 26 Post(s)
Hi
Today I have an Projectiondesign AM1080 and panamorph lens that is 7 years old.
I am building a new Cinema since i moved and am looking for a 4k projektor.
I have a 2.35:1 curved screen and dont want to go back to 16:9 screen.
Do I need an anamorphic lens for the VPL-VW1100ES projector? Today i Think the Picture with my panamorph
lens is ok but it is not so Sharp and Bright as without so would be great not to need an lens at all
dhurleycpa likes this.
Micke_ is offline
post #2 of 34 Old 07-21-2014, 09:39 AM
Andreas21's Avatar
Quoted: 1133 Post(s)
Liked: 728
Originally Posted by Micke_ View Post
Hi
You don´t need an anamorphic lens with the VW1100 as it has lensmemory, I have done this for over 2 years now and it works very well.
But I miss my setup with an anamorphic lens (Isco IIIL) so I just bought a Isco 1.25x DLP Cinema lens ( the best anamorphic lens ever is what I have read) and I am looking forward to test this with my VW1000 soo to be upgraded to VW1100 in a couple of weeks when the lens arrives. I think you need to upgrade your lens to make it work ok with the VW1100.
Andreas21 is offline
post #3 of 34 Old 07-21-2014, 11:56 AM - Thread Starter
Micke_'s Avatar
Quoted: 26 Post(s)
What is the downside not using an anamorphic lens with vw1100?
Micke_ is offline
post #4 of 34 Old 07-21-2014, 12:14 PM
Andreas21's Avatar
Liked: 728
You loose about 30% light when zooming to a 2.35:1 aspect compared to the 17x9 on the VW1100, and this goes with all projectors. When using a anamorphic lens you loose almost nothing if you have a high quality lens. You can also switch much faster from 17x9 to 2.35:1 and I like it. The downside is you can loose some ansicontrast and there is scaling involved, but if you have a high quality lens like the Isco and scaler like the Lumagen this is not a problem and I only see the positives with high quality anamorphic lenses. The only negative I find annoying is the picushion these lenses make, but this is also corrected with a curved screen.
post #5 of 34 Old 07-21-2014, 12:32 PM - Thread Starter
Micke_'s Avatar
Quoted: 26 Post(s)
do you need a scaler like lumagen when using the vw1100?
Micke_ is offline
post #6 of 34 Old 07-21-2014, 04:56 PM
John Schuermann's Avatar
Quoted: 1392 Post(s)
Liked: 1446
If you have a Panamorph UH480 or DC1, both are fully capable of 4K performance. In fact, the DC1 is the only anamorphic lens specifically recommended by Sony for their 4K projectors.
Be curious to know which Panamorph lens you have - they make 4 different models. I would also be curious to know what your throw distance and ratio are. The reason I ask is that you say the image is sharper and brighter without the lens. You should not see a decrease in sharpness with the lens unless you are outside the recommended throw distance.
The brightness issue is very unusual - you should definitely see a brightness increase with the lens in place, at least compared to zooming. The only way the image with the lens should appear dimmer than without it is if you are comparing the 16:9 image brightness to the 2.40:1 image brightness. Of course, the 2.40:1 image brightness will be lower because you are asking the projector to fill 33% additional screen area.
As mentioned, the Sony has lens memory so a lens is not strictly needed, however, using the lens will provide a brighter image plus prevent the black bars from actually being projected onto the wall.
John Schuermann is offline
post #7 of 34 Old 07-21-2014, 11:45 PM - Thread Starter
Micke_'s Avatar
Quoted: 26 Post(s)
Hi,
I have the U380 lens and I guess the new DC1 is better. I can´t zoom with the projectiondesign AM1080 so I have only compared to the brigtness I get when watching 16:9 without the lens in front.
My screen is 400cm wide. So if I use the sony vw1100 without any lens the black bars will be projected outside the screen, doesn´t this mean you will get a better resolution with the vw1100 and a DC1 lens also?
Micke_ is offline
post #8 of 34 Old 07-22-2014, 07:50 AM
Andreas21's Avatar
Liked: 728
No, you don´t need a Lumagen for 1080p material, but if you want to strech 4K material you need to wait for the 4K in 4K out version from Lumagen when it comes later this year.
John Schuermann likes this.
post #9 of 34 Old 07-22-2014, 08:29 AM
Liked: 1446
No, you don´t need a Lumagen for 1080p material, but if you want to strech 4K material you need to wait for the 4K in 4K out version form Lumagen when it comes later this year.
Correct. Right now there are no processors that will do the necessary vertical stretch with native 4K material, but Jim at Lumagen is working on it. Fortunately the projector will stretch 1080P no problem.
post #10 of 34 Old 07-22-2014, 08:56 AM
Liked: 1446
Hi,
Yes, by using a lens you take advantage of the entire 3840 x 2160 pixel grid of the projector, vs. 3840 x 1620 when you zoom letterboxed material. While this doesn't result in any true additional picture detail, the projector has more pixels to "draw" the image (for a more solid looking picture) plus a brightness increase of about 20% (as reported to us by Sony).
The UH380 is still a really good lens, but it might be worth the upgrade to the DC1. The DC1 features sealed optics, better optical coatings, and an improved light path over the 380. The net result is better contrast and brightness, plus the sealed optics means that dust and grime can never get inside the casing.
The 380 should still be nice and sharp, though. Are you at the recommended 14.5 - 17.5 foot (4.4 - 5.4 meter) throw distance? If not, you will definitely see a softening of the pixels with the lens in place. You might see if there is any dust contamination inside the lens too.
Good luck!
post #11 of 34 Old 07-23-2014, 01:01 AM - Thread Starter
Micke_'s Avatar
Quoted: 26 Post(s)
So the VW1100 can not stretch the 4K Picture to 2.35:1 format if i want to use an anamorphic lens? I also then will need an scaler? I have hade the projector at around 5meter the first time, but then moved so could only have it at 7m from the screen
Micke_ is offline
post #12 of 34 Old 07-23-2014, 10:55 AM
Liked: 1446
It cannot stretch native 4K material. It can certainly stretch Blu-ray, HD streaming, broadcast, satellite, cable, etc. The only thing it can't stretch (or process at all, to my knowledge) it true 4K source material. Lumagen is working on a solution but it's not available yet. You can always use the lens for HD material and zoom for 4K material, at least temporarily.
If you are at 7 meters, you are way outside the stock focus point for the UH380 lens, which would explain why you are seeing a soft image. On the positive side, the UH380 - should you decide to keep it - can be retrofitted to be tuned for that specific throw distance. There is a cost to do this, but it is way less than the cost of a new lens. At 5 meters you are fine.
post #13 of 34 Old 09-08-2014, 03:02 PM
Shepardos's Avatar
Quoted: 60 Post(s)
Hi,
How is the Performance with the CineVista lens, or is this lens not recommended with 4k projector?
Shepardos is offline
post #14 of 34 Old 09-08-2014, 04:16 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 194 Post(s)
Liked: 155
One would not (should not) even consider that lens with a high end 4k projector IMO. You should move to a higher end lens to compliment the PJ. The very higherst performance lens for that PJ is the Isco 1.25 Cinema DLP lens. That's a professional lens used by commercial cinemas. $20k list price. I happen to have one in stock, on sale. I'd sell at a much more reasonable price. Prefer to sell it with a CineSlide, but it is big and heavy so it takes a heavy duty version of the CineSlide, which is build to order.
GetGray is offline
post #15 of 34 Old 09-08-2014, 04:29 PM
Liked: 1446
Speaking for Panamorph, the CineVista will work with 4K, but with a high end projector like the VW1100ES it makes more sense to go with a high end lens. The lens GetGray suggested is an excellent choice, as is the Panamorph DC1 (which Sony specifically endorses for the VW1100).
post #16 of 34 Old 09-09-2014, 05:24 PM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2581
The best solution is to use a PC with a high quality scaler. Your best bet is to use MadVR if you want to do 4K vertical stretch. Most who have put Lumagen's 1080p --> 4K scaling up against MadVR's scaling prefer MadVR over what the Lumagen can do. An HTPC is the most practical and highest quality solution out there currently.
Seegs108 is offline
post #17 of 34 Old 01-29-2015, 07:19 AM
Dirk44's Avatar
Quoted: 109 Post(s)
I just jump into the VW 1000 Club, for 1080p i still use my Prismasonic HD 6000 lens mit Throw Ratio of 1,65.
Any new Information what happens with Scaler for UHD / 4k so far ? Something on CES ?
Best reagards dirk
Dirk44 is offline
post #18 of 34 Old 03-22-2015, 06:05 AM
Dirk44's Avatar
Quoted: 109 Post(s)
Hi guys,
i Already changed to the Isco 1.25 DLP Lens.
To Stretch 1080p i use the Build in scaler of the vw 1100.
I have no pc and no Knowledge to scale nativ 4k.
So do i have to take Off the Lens each Time then i watch 4k with Mediaplayer For Exemplare netflix or Trailer in nativ 4k.
Best dirk
Overwise -with the Lens in lightway -i loose Resolution ???
Dirk44 is offline
post #19 of 34 Old 04-13-2015, 08:43 PM
RS3771's Avatar
Quoted: 199 Post(s)
Liked: 65
While I'm eagerly waiting for the UHD Blu rays and the UHD Blu Ray players to hit the market by holiday season this year, I'm worried about not being able to V-Stretch the 4K video since Sony VPL-VW1100ES can't v-stretch it. I use an ISCO 1.25x a-lens to generate a 14-ft wide image currently for all 1080p content. And I've had tough luck with using Lumagen 2041 -the number of glitches and problems with finicky HDMI cables to random sparkles to any and every problem under the sun has made me remove Lumagen from the loop and all is well (as far as V-stretching 1080p material using Sony's scaler). What options would likely be there for V-stretching 4K video later this year (alternatives to Lumagen)?
RS3771 is offline
post #20 of 34 Old 05-12-2015, 08:51 PM
jabz's Avatar
Quoted: 124 Post(s)
Liked: 62
Is a Prismasonic HD-6000F Cylindrical A-lens sufficient to use with a Sony VPL-VW1100ES? They changed model numbers, so the current day equivalent is the Cinomorph C-100F.
jabz is offline
post #21 of 34 Old 05-12-2015, 10:34 PM
Dirk44's Avatar
Quoted: 109 Post(s)
Till March i Have this Lens in Front of my vw 1100.
In Right Throw distance in worked and all the light came trough.
Now i changed to the Isco 1.25 to be Ready for UHD BR this year in combination with New Scaler then...
Dirk44 is offline
post #22 of 34 Old 09-04-2015, 11:36 AM
RS3771's Avatar
Quoted: 199 Post(s)
Liked: 65
VW-1100 & 1.25x lens & UHD V-Stretch?
Now that UHD blurays are a certain thing and UHD Blu ray players will roll out in a few months, does any one know if there will be any sort of upgrade to enable the VW-1100 to V-stretch 4K inputs? I'm hesitant to use the next gen. Lumagen (Radiance Pro Series) as I've had a terrible experience with their Radiance 2041 and all the finickiness about its HDMI compatibility. Alternatives would be to V-stretch using the scaler built-in to the Bluray player - which I'm not sure Panasonic or Samsung will equip with and Oppo is not expected to release a UHD Bluray player until late 2016. BTW, I'm currently using the ISCO 1.25x lens.
Dirk44 likes this.
RS3771 is offline
post #23 of 34 Old 09-04-2015, 01:07 PM
Cam Man's Avatar
Location: Tucson, AZ, Telluride, CO, & Los Angeles,CA, USA
Quoted: 423 Post(s)
Liked: 447
You tease! Thanks for giving everybody a woody.
Are any features releasing in squeezed DCI files? There must be if you have a lens for it. Any titles would be appreciated.
Cam Man is offline
post #24 of 34 Old 09-04-2015, 02:12 PM
GetGray's Avatar
Quoted: 194 Post(s)
Liked: 155
Ha. That was a year ago, I think htat lens left a week after that post.
But here's something for the fire.... That lens went with a second one (yes *2* Cinema DLP lenses) for a Sony VW1100 DOUBLE stack. I built a custom frame to hold the 2 lenses, 2 lens transports and the 2 projectors. Came out very nice. Ken Whitcomb set it up and calibrated.
No, sorry I don't have any inside info on the DCI releases.
GetGray is offline
post #25 of 34 Old 10-26-2015, 05:22 PM
typecase's Avatar
Quoted: 14 Post(s)
Whoa! Any pics of that setup?
typecase is offline
post #26 of 34 Old 10-26-2015, 05:28 PM
GetGray's Avatar
Quoted: 194 Post(s)
Liked: 155
Nothing worthy of posting. Theater was too dark to get good photographs. They are supposed to have a photographer come shoot it, but I'm not sure when. All I've got is a short, dark little iPhone video.
GetGray is offline
post #27 of 34 Old 10-26-2015, 07:23 PM
Ajin's Avatar
Quoted: 12 Post(s)
Anamorphic lens and CIH
If anyone can chime in to answer this question, it would be greatly appreciated. I currently upgraded my 1080p proj to the Sony vw350es and use the old panamorph 752 A-lens(vertical compression) to display 2:37 on my widescreen. Proj is 22ft from screen. I think the pic looks pretty darn good. I recently have the chance to upgrade the A-lens to the ISCO IIIL and has my mouth watering. Don't want to plunk down many $ for this but wondering if this upgrade will make any signif difference in pic sharpness, distortion etc. I believe its a horiz expansion lens. I called Schneider optics and spoke with tech guys(they acquired ISCO) but of not much help except to say it was a very good lens. Couldn't help me with throw distance, pic quality improvement etc.
Has anyone got any opinions on whether this would be a significant enough improvement over my old Panamorphy 752?(its a prism lens) Will it work at my throw distance(it is the L version). Any thoughts would be appreciated.
Ajin is offline
post #28 of 34 Old 10-26-2015, 08:55 PM
GetGray's Avatar
Quoted: 194 Post(s)
Liked: 155
P752 is an oil filled early Panamorph antique. It's not even a real (solid) prism. The Isco III is a state of the art 4 element (2 doublet) fully cylindrical lens corrected for chromatic aberrations, and is fully focus-able (astigmatism). It's design is unchanged except for a case change when Schneider assimilated Isco. Isco still makes the Schneider XL equivalent. You can't compare them. I thin I paid $250 for a new P752 a long long time ago. At the same time the Isco III was $4800 dealer cost. The III is a horizontal expansion lens. It's not going to work like your P752 and you will need a 2.35 aspect screen to use it properly. It will work at that distance (assuming you don't have a giant screen). You didn't tell me enough about your screen to say if it works with it or not. Using the Sony with a P752 is about like to watching it through packing tape (well maybe not that bad, but bad). I know someone who has a used one with a CineSlide they'd sell if that helps you. He's a dealer who got it for his personal system but has moved and taken his PJ down. No idea on price, but I can point you to him.
As for the lens, call me, I'll help you. I'm an expert with the Isco lenses. Be easier to explain verbally if you need more than above.
Scott Horton
www.techht.com
615-859-5498
GetGray is offline
post #29 of 34 Old 11-05-2015, 05:38 AM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
WOW wanting to know if upgrading from an oil filled prisms adaptor to a state of the art lens will be noticeable.
Like comparing an electric skate board to a car with a V8.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #30 of 34 Old 11-05-2015, 05:39 AM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
Deleted
Mark Techer
CAVX is offline
Reply 2.35:1 Constant Image Height Chat
