Panasonic AE8000U or Epson 5030 with Lumagen? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By ChldsPlay
post #1 of 7 Old 08-08-2014, 04:26 PM - Thread Starter
ChldsPlay's Avatar
Quoted: 609 Post(s)
Liked: 317
Looking at getting a projector for my pending CIH theater setup. I was pretty much dead set on the Panasonic because of the auto zoom/lens memory. A local installer is pushimg the Epson and suggesting I use the Lumagen to shrink the imge for 16:9 material so I don't have to adjust the zoom once it is set for 2:35. My concern there is with losing resolution when I do that. Cost of the Lumagen isn't a factor as I will have it either way.
Thoughts?
ChldsPlay is offline
post #2 of 7 Old 08-12-2014, 02:15 PM - Thread Starter
ChldsPlay's Avatar
Quoted: 609 Post(s)
Liked: 317
Nevermind, I went ahead and bought the Panny.
post #3 of 7 Old 03-10-2015, 07:52 PM
mrdelaware's Avatar
Did you get a Lumagen as well? If so, how did it turn out? I'm also considering going with the AE8000U with a Lumagen specifically for a CIH with 2.35:1 screen. I keep getting more confused with each thread I read on here about various projectors, screens, etc.
mrdelaware is offline
post #4 of 7 Old 03-11-2015, 11:46 AM
jeahrens's Avatar
Quoted: 475 Post(s)
Liked: 198
You don't need the Lumagen to scale the image with the AE8000U. Lens memory will take care of resizing for you with no resolution loss.
jeahrens is offline
post #5 of 7 Old 03-11-2015, 01:25 PM
mrdelaware's Avatar
Yes, the projector does have the lens memory settings but it won't convert 16:9 content to fit a scope screen. I really don't like the black bars. My question/concern is with how the Lumagen performs with the AE8000U. What is the image quality like? I've read a lot of reviews on the various Lumagen products with most raving about it while some said it wasn't worth the price paid. Kinda wanted to hear from someone that has both the projector that I want mated with a Lumagen to see if they'd do it the same if they had to do it all over again.
post #6 of 7 Old 03-11-2015, 02:56 PM
jeahrens's Avatar
Quoted: 475 Post(s)
Liked: 198
The feedback on the Lumagen has always been very positive from all of the mentions I have seen on here. I'm fairly sure the Lumagen can crop an image in the fashion you are describing. Home theater enthusiasts are usually interested in preserving aspect ratio and intended shot composition, so I don't recall this use case being discussed. I find pillar boxing to be a non-issue and much less noticeable than letterboxing. Mainly because, unless you are width limited, maximizing for height makes all formats as large as they can/should be. Unlike a letterboxed scope image where it is much smaller than it should be. Masking the pillar boxes also helps to remove any thoughts of unused screen space if that bothers you. Still whatever makes you happy. The Lumagen is a great product and should be able to get you where you want to be. I'm sure an owner will chime in with a definitive answer.
jeahrens is offline
post #7 of 7 Old 03-13-2015, 10:14 AM - Thread Starter
ChldsPlay's Avatar
Quoted: 609 Post(s)
Liked: 317
I did get the Lumagen, and I also had calibration done with the Lumagen. However, I can't speak for how it looks. It's still in the box, along with my projector and speakers. I'm getting close on my theater construction, so I might know in a few weeks. My main reason for getting the Lumagen (with a projector that has lens memory) was for movies with shifting aspect ratios. I am curious to see how that feature makes other films/games look however and will experiment when I get the chance. I have seen the Panny in action before at someone else's theater and was satisfied with it, even when it wasn't calibrated.
mrdelaware likes this.
The Hodor Theater - Now with Atmos
Projector - Panasonic PT-AE8000U
LCR speakers - JTR Noesis 228 HT (3)
Surr./Back - Klipsch Pro Cinema KPT-8000M (4); Atmos In-ceiling - Niles DS8HD (4)
Subwoofers - Passive JTR Captivator Pro (2) - Powered by Crown XLS 5000.
Receiver - Yamaha Adventage A3050
Reply 2.35:1 Constant Image Height Chat
