2.35 n00b seeks advice - AVS Forum
post #1 of 5 Old 09-14-2014, 11:24 PM - Thread Starter
tbacos's Avatar
Hey guys. I'm looking into the 2.35 thing in my new home theater. I have a Sony HW50ES projector that will be ceiling mounted about 14' from the screen. Haven't purchased a screen yet.
What are my options for a 2.35 image from the Sony? Panamorphic lens? Lumagen? Any general advice to a newcomer?
tbacos is offline
post #2 of 5 Old 09-15-2014, 08:54 AM
jeahrens's Avatar
Quoted: 90 Post(s)
Liked: 72
Your best route would be a horizontal expansion lens, like the Panamorph. A good lens like the Panamorph will run you about $1500 or you can find a used example for about $1000. The only other option would be an inexpensive 2 prism lens which you can get a hold of for <$500. The picture quality will not be as good as the better lens, but it's certainly watchable.
The Lumagen route has a some concerns. The first is at 14' can the projector zoom out enough to fill the proposed 2.35:1 screen? The second is are you willing to compromise the resolution of non 2.35:1 material? This is assuming you will zoom the projector to fill the 2.35:1 screen (black bars spilling over the top/bottom) and then use the Lumagen to squeeze all other content to fit within the height of the screen.
jeahrens is online now
post #3 of 5 Old 09-15-2014, 08:56 AM
jautor's Avatar
Quoted: 385 Post(s)
Liked: 417
That projector is a manual zoom, so you're either going to have to deal with that, or add an anamorphic lens. Since the projector has the aspect ratio controls, you'd be set up for using a lens. (Have to go look again to see if you could leave the lens in place or not - whether the pj can squeeze)
Jeff
jautor is online now
post #4 of 5 Old 09-15-2014, 09:27 AM - Thread Starter
tbacos's Avatar
Awesome. Thanks guys. Didn't know that the lumagen would require a zoom to full width. Definitely a deal killer in my setup.
Now I gotta figure out what I need to mount the lens via a ceiling mount. Other examples I've seen have the projector standing upright on a hanging shelf mounted from the ceiling...is that a requirement for a Panamorph lens? Are there mounting kits/sleds that can attach to the ceiling, a chief mount, or the projector itself?
tbacos is offline
post #5 of 5 Old 09-15-2014, 10:45 AM
John Schuermann's Avatar
Quoted: 54 Post(s)
Liked: 76
Panamorph does make a CineVista mount specifically for the HW50. The projector can be either table or ceiling mounted.
Keep in mind that the CineVista is designed for a fixed installation, so if you want a transport you would either need to rig one yourself or take a look at the Panamorph UH480, which comes in a variety of moveable configurations.
You might contact Panamorph directly - they can answer all your install questions without any kind of sales pressure.
John Schuermann, Filmmaker / Film Composer
Home Theater Industry Consultant
JS Music and Sound
Panamorph
Check out my new movie!: www.stephensonmovie.com
John Schuermann is offline
Reply 2.35:1 Constant Image Height Chat
