Throw distance with anamorphic lens question - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By rboster
post #1 of 13 Old Yesterday, 01:36 PM - Thread Starter
paulfromtulsa's Avatar
Quoted: 147 Post(s)
Liked: 66
I currently have a Sony vpl-vw600es with throw distance of 19ft. Can I use a vertical compressions anamorphic lens on a 150" 2.35:1 screen? I vaguely remember needing more of a throw distance like 22ft for that large of a screen. Any input would help. Thanks
paulfromtulsa is online now
post #2 of 13 Old Yesterday, 04:28 PM
roxiedog13's Avatar
Quoted: 1373 Post(s)
Liked: 572
150" diagonal? What is the make and model of the anamorphic lens ? Is the screen curved or flat?
Need that information first .
Where do you live and what is your name paulfromtulsa ? OK , sorry couldn't resist that one.
Dedicated Theater: Sony VPL VW 675ESB & JVC X950RU/RS600 , Panamorph DC1 Anamorphic Lens, Draper TecVision XT1800X Screen, 2.40:1 132" diagonal curved 36FT radius, Anthem 1120 AVR , 7.2.4 Atmos, Panasonic UB900, Oppo 203
Lumagen Pro 4440 , Paradigm Monitor 11 fronts, Monitor 3 Center, Monitor V7 Rear, SA-ADP In-wall Surround, Niles DS-7 In-Ceiling, Subwoofers: Klipsch RW-12 + SVS PC13-Ultra
roxiedog13 is online now
post #3 of 13 Old Yesterday, 04:45 PM - Thread Starter
Quoted: 147 Post(s)
Liked: 66
The screen is flat and the lens is a panamorph vertical compression. I did the math and I can do the lens with my throw distance. But with the more research I do it seems like the lens might be more trouble than good. What are your thoughts? Would I really see a difference with 30 percent more output
Sent from my SAMSUNG-SM-G928A using Tapatalk
post #4 of 13 Old Yesterday, 05:47 PM
rboster's Avatar
Quoted: 944 Post(s)
Liked: 828
Paul you would really benefit from having your thread moved to the CIH forum.
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is online now
post #5 of 13 Old Yesterday, 05:48 PM - Thread Starter
Quoted: 147 Post(s)
Liked: 66
What is the cih?
post #6 of 13 Old Yesterday, 06:10 PM
rboster's Avatar
Quoted: 944 Post(s)
Liked: 828
What is the cih?
It's our forum dedicated to constant image height and all things anamorphic lens, CinemaScope discussion
http://www.avsforum.com/forum/117-2-...e-height-chat/
roxiedog13 likes this.
Retired Moderator
post #7 of 13 Old Yesterday, 06:11 PM - Thread Starter
Quoted: 147 Post(s)
Liked: 66
Ok thanks can you move this post over there?
post #8 of 13 Old Yesterday, 11:31 PM
coolrda's Avatar
Quoted: 867 Post(s)
Liked: 623
Simple. With a VC lens you start with your 16x9 image width. Your 2.35 image will only be as big/wide as your max 16x9 width. An HE lens will expand the 16x9 thirty three percent horizontally.
coolrda is offline
post #9 of 13 Old Yesterday, 11:57 PM
CAVX's Avatar
Quoted: 126 Post(s)
Liked: 81
To calculate the Throw Ratio for a HE lens, you use the 16:9 image width divided into the Projection Distance.
To calculate the Throw Ratio for a VC lens, you use the Scope screen width divided into the Projection Distance.
To get the same TR requires a longer throw for the VC. Optics pending, you may get away with a shorter TR.
Exactly what lens is it?
Mark Techer
I love my Constant Image Height system!
CAVX is online now
post #10 of 13 Old Today, 06:55 AM - Thread Starter
Quoted: 147 Post(s)
Liked: 66
It's an older lens panamorph p752. I found a good deal on one but not sure it's even worth the hassle now. Also not sure if the lens quality from 10 years ago can support 4k? Your thoughts?
post #11 of 13 Old Today, 03:23 PM
CAVX's Avatar
Quoted: 126 Post(s)
Liked: 81
The P752 was oil filled glass prisms.
Based on the one I saw back in 2006, I don't think this is "4k ready".
Out of curiosity, what was the asking price?
Mark Techer
CAVX is online now
post #12 of 13 Old Today, 03:59 PM - Thread Starter
Quoted: 147 Post(s)
Liked: 66
Thank you. Your probably right. $400
post #13 of 13 Old Today, 04:30 PM
CAVX's Avatar
Quoted: 126 Post(s)
Liked: 81
If you could find one of their solid glass versions, you'd find you'd be OK.
Regardless if the type of lens used (HE or VC), once set up and left and in the light path, both will essentially do the same as shown in this video
Mark Techer
CAVX is online now
Reply 2.35:1 Constant Image Height Chat
