Panamorph UH480 with transport/ JVC 520 Setup - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By CAVX
  • 1 Post By Jedi_Mike
post #1 of 9 Old 08-11-2017, 10:33 AM - Thread Starter
chipvideo's Avatar
Just wondering if anyone else has this combo and how to set up easily. I am upgrading my PJ from a smaller panasonic 3000u and pretty much eyeballed it and got it pretty close by just mounting the sled on plywood to the celing. I was wondering if they make a fitted piece of metal that attatches to the PJ so it is fool proof and spot on. Any other ideas. The reason I ask is because I need to move the piece of wood on my celing in order for it to fit as I only have 6 inches of clearance from the back wall to the back of my current PJ and to where my lens is attatched and this new PJ is much larger and wouldnt fit in between the two right now.
chipvideo is offline
post #2 of 9 Old 08-11-2017, 05:46 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
Panamorph did make a metal plate for exactly what you are asking about.
It wasn't cheap from memory.
Sent from my SM-G900I using Tapatalk
chipvideo likes this.
Mark Techer
I love my Constant Image Height system!
CAVX is online now
post #3 of 9 Old 08-11-2017, 06:14 PM
Jedi_Mike's Avatar
Quoted: 16 Post(s)
These show up in the classifieds on rare occasion. They are designed to work with the Chief RPA ceiling mount. The alignment works out great, only complaint I have is the center of balance is very far toward the back when the lens is not installed. I prefer to align the projector first, then install the lens; this is difficult with the plate having the PJ shifted so far back from the center of the mount.
A couple sold in 2016:
Panamorph AK8J-3D Anamorphic Lens Mounting Plate for JVC Projectors
FS: Panamorph AK mounting plate for JVC projectors
I bought the one in the second link. John Schuermann was a pleasure to work with; I wound up buying a projector from him too.
Jedi_Mike is offline
post #4 of 9 Old 08-12-2017, 02:12 PM - Thread Starter
chipvideo's Avatar
Thanks for the advice. Probably just going to setup the PJ and then mount the lens later. Need to get some spacers so I can mount the lens further down or just use an extra 1/2 inch sheet of plywood strip for the transport to mount too.
post #5 of 9 Old 08-12-2017, 11:00 PM
coolrda's Avatar
Quoted: 1091 Post(s)
Liked: 996
I have that plate that I bought from AVS. Still in the box.
coolrda is online now
post #6 of 9 Old 08-17-2017, 01:27 AM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
I had to help align a Panamorph UH480 today mounted on the same plate.
What is the optimal distance from the screen with these? I believe 17 feet. Can someone with correction element A confirm please?
Mark Techer
CAVX is online now
post #7 of 9 Old 08-17-2017, 05:36 PM
sbquart's Avatar
Quoted: 128 Post(s)
Can you post a picture of how you have it mounted? I have the same plate and not sure if I have all the required parts to mount my Sony with it.
sbquart is online now
post #8 of 9 Old 08-18-2017, 01:14 AM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
The JVCs have 4 bolt holes in a big square. Sony have a triangle array designed for their mount.
What I didn't like about this installation is the 4 bolts holding the Panamorph. It did not allow any yaw.
Mark Techer
CAVX is online now
post #9 of 9 Old 08-27-2017, 09:37 PM
mhanna1102's Avatar
Liked: 0
I just recently upgraded from a JVC-HD100 (small Panamorph mounting plate) to a JVC DLA-X500 projector. This projector fits on the AK(X) plate. There is an individual on ebay that may still have another one. I paid $250 plus shipping. One sold a few months ago on ebay for $32 but that was a week before I was looking for one. Go figure.
The plate/projector combo is much bigger than the old projector/plate. So big that it would not fit because it hit the back wall when mounted on my current ceiling mount. I had my projector mounted on a chief mount before I found the AK plate. I was going to have to drill holes in the plate to make my projector fit, but noticed that the mounting holes on the chief plate were 4 inches closer to the front. I attached the chief plate to the top of the Panamorph AK plate and it moved the entire mount 4 inches closer to the screen. This was perfect for me and no drilling.
My projector is only 14 1/2 feet from the screen (not optimal) but can push 165 inch screen with less than 1" pin-cushion on the top/bottom and sides.
I can post pictures if you are interested.
mhanna1102 is offline
Reply 2.35:1 Constant Image Height Chat
