2.35 Constant Height Faq - AVS Forum | Home Theater Discussions And Reviews
post #1 of 636 Old 06-30-2005, 08:55 AM - Thread Starter
Tukkis's Avatar
After reading many of the same questions being asked I thought it would be a good idea to have one main thread that discusses the main ideas of a constant height setup.
This article will deal with constant height info.
Feel free to add anything I missed as I'll keep updating this main post.
WHAT IS IT?
What is a 2.35 Constant Height Setup?
In basic terms, its the ability to watch 2.35 material in full resolution and with full width just as the director intended. In a constant height setup 2.35 movies take up the whole screen without any black bars above/below. This a good read to get a better idea of constant height: http://resmagonline.com/articles/pub...icle_774.shtml
What benefit does constant height provide over a normal 16x9 setup?
Because you are using the projectors full panel to display the 2.35 image, there is a 33% increase in resolution. The light output is also about 20% more than the same size picture without an anamorphic lens.
This results in a smoother more film like image that has alot more depth and punch to it.
Some other benefits of constant height also include more immersion for 2.35 films due to the extra width and no more annoying black bars. And also easier masking options.
HOW?
How does it work?
http://www.avsforum.com/avs-vb/showthread.php?t=830657
This link shows in a visual sense how a 2.35 constant height setup operates:
http://www.prismasonic.com/english/intro.shtml#2
http://www.panamorph.com/index.html See "How it Works" Box
WHAT DO I NEED?
What equipment do I need to run a constant height setup?
Here's a link that has some of the products that can be used for constant height: http://www.avsforum.com/avs-vb/showthread.php?t=537491
1. 2.35 programming
Movies/tv shows/dvd's and even trailers. Anamorphic enhancement preferred. Look out for HD 2.35 clips/movies in the future.
2. A 16x9 native projector
Although using a 16x9 projector with a lens is the ideal method for optimal resolution, it is just as possible to establish a constant height arrangement with just a 16:9 projector and no anamorphic lens and zooming (or a 4:3 projector with anamorphic lens and zoom) so long as you are comfortable with not using all of the projector's available pixels/brightness.
Projector/Lens Compatibility
3. Scaler that performs the required vertical stretch
This can either be built into the projector, dvd player, standalone scaler units or HT/Media Centre PC's. All you're after is the pre-lens vertically stretched image. Note though, that alot of projectors limit the options for changing the aspect especially when inputting upscaled DVD images.
Standalone scalers and HTPC's will generally provide more flexibilty.
4. 2.35:1 Screen
This means the screen is 2.35 units wide for every 1 unit high. Normal 16x9 screens are 1.78:1 ratio.
Most of the screen manufactures can produce a 2.35 ratio screen. DIY options are also possible. Again, all you're after is the 2.35:1 ratio.
The optimal screen for the true cinematic experience would be an acoustic sound screen that's transparent. This allows all front three speakers to be placed behind the screen with sound coming directly from the screen. Again, most manufactures provide this option. DIY solutions also exist, with Dazian Celtic Cloth and SMX (SandmanX) 720 being the most popular.
5. Anamorphic lens (Horizontal stretch or Vertical squeeze)
There are two ways to reach the final goal of constant height - Horizontal stretch lens or Vertical squeeze
Some may want to remove the lens for movies with ARs less than 2.35 in order to maximize the number of display pixels used. In so doing, there are a few things to bear in mind.
A situation occurs when removing a vertical squeeze lens that does not happen when removing a horizontal stretch lens. The displayed picture becomes too tall for the screen. That is assuming the screen AR matched that of the PJ and lens system. In that case the PJ zoom function must be employed to shrink the displayed pictured -- Hmm, scaling with a lens again. This time however the shrink occurs equally in both dimensions - isotropic scaling. The Pj would have to be capable of a zoom ratio of at least 1.322 : 1 , assuming the lens had a compress ratio of (16/9) / 2.35
A way of thinking about this is that the vertical squeeze lens does not affect the throw distance whereas a horizontal stretch lens decreases the throw.
Additionally, depending on the specific lens (either type) and projector, lens offset can enter into the mix and require additional adjustments. Some anamorphic lenses shift the position of the displayed picture vertically.
And finally, some projectors may shift the vertical position of the center of the picture when zoom is invoked as well.
Which Anamorphic lens is right for me?
http://www.avsforum.com/avs-vb/showt...ght=Anamorphic
http://www.prismasonic.com/english/specs.shtml Horizontal/ Vertical with option of motorized
http://www.panamorph.com/Products.html Vertical or Horizontal
http://www.isco.eu/index.php?id=home-cinema High end lens with option of motorized
www.cineslide.com Manufacturer of Isco lens transports, USA distributor for ISCO lenses
How Anamorphic lens technology works
How the different lenses work
http://www.panamorph.com/Technology.html
SCREEN MASKING?
Manufacturers that sell Screen Masking for 2.35
What happens to sides of the 2.35 screen when I watch movies with less width (1.78/1.85 etc)?
You mask/cover up the sides of the 2.35 screen when you watch movies that aren't as wide as 2.35. Just like the real cinemas. Ever wondered why the movie screen widens for some films when you go the cinemas. Now you know. To maintain the height necessary for 2.35 movies the width must increase. Hence the term constant height.
A fellow member posted this:
"As with any fixed pixel display, when you need to map a non-native aspect ratio into the panel you will not use all of the pixels. Since the lens in this case transforms the 16:9 projector into a 2.35 projector any ratio other than this will result in either pillar boxing or letter boxing. For ratios greater than 2.35 this would be letter boxing (constant width). And of course this means anything less than 2.35 would have black bars on the sides, which is constant height"
How do I figure out how much I need to cover up?
The great thing about constant height is you only need to mask the sides of the picture. To figure out how much you need to mask when you watch movies with less width than 2.35 you multiply the screen height (which remains the same for all movies aka constant height), by the aspect ratio of the movie.
So say you watch a 1.78:1 ratio movie. For a screen 50" high you multiply it by 1.78. Hence the 1.78 units wide for every 1 high.
So 1.78 x 50" = 89"
1.85 x 50" = 92.5"
1.33 x 50" = 66.5"
As you can see a 1.78 movie is 89" wide out of the possible 117.5" for 2.35 movies. 2.35 movies of course don't need masking as they take up the whole width.
A very limited number of films are shot in ratios wider than 2.35 eg. Ben Hur. You can either live with the small black bars top and bottom, stretch the image so it fills the 2.35 screen or if you're totally obsessed mask the top and bottom. This would mean you would need a 4 way masking system.
What do I do with the anamorphic lens when I want to watch non 2.35 (scope)films?
There are a few ways to go about this.
1. Leave the lens in place all the time for all aspect ratios. This implies a loss in resolution and brightness for anything other than 2.35 films as the sides of the picture are now wasted on black pillar bars. A few on this forum leave the lens in place and don't notice any PQ loss as full vertical resolution is still used for all ratios.
One thing to take note of though with brightness is that because the 16x9 image is smaller in area to the 2.35 image, it requires less light to appear as bright as the 2.35 image. Therefore leaving the lens in place means that the brightness should be perceivable the same between 2.35 and 16x9.
The brightness drop occurs if you compared a 1000 lumen 16x9 image with no lens compared to a 500 lumen image with the lens. The areas are the same but the 1000 lumens is brighter as more light is covering that area.
So by keeping the lens in place you shouldn't notice difference in brightness between a full width 2.35 image and a 16x9 image with black bars on the sides.
2. Slide the lens out of place for non 2.35 movies. This uses full resolution/brightness for all aspect ratios. This can sometimes cause the picture to drop depending on the lens.
3. Leave the lens in place but use the passthrough mode that some lenses have (prismasonic range). This involves leaving the lens in place like option 1 but using the passthrough mode on the lens which means not stretching it horizontally and just letting the projected light 'passthrough' the lens unaltered. This like option 2 uses full resolution/brightness for all aspect ratios (2.35/16x9).
How a passthrough lens works.
WHAT ABOUT CONSTANT WIDTH/AREA?
Constant Width is for those who can only accommodate a 16x9 screen. The width remains the same but the height changes. It still uses the full panel of the projector for 2.35 films but you dont get the extra width benefits for scope films. Only a vertical squeeze lens works for this application as you take the vertical stretched 2.35 picture and squeeze it down vertically to correct the geometry.
To find out more check out 'The 16:9 Screen Option' a little down the page: http://panamorph.com/Ultimate235.html
What about this Constant Area methology that everyone's talking about?
The idea behind Constant Area is that every aspect ratio has same/similar area. This means that every aspect ratio appears large as the brain perceives size in how much area an object has not in width or height. The screen ratio for constant area is 2.05 which is halfway between 1.78 and 2.35.
Here's some links that go into more detail:
http://archive.avsforum.com/avs-vb/s...threadid=15649
http://www.videophile.info/Screen/Page_01.htm
http://www.mindspring.com/~zyber/cinema-screen.html
Where can I see some 2.35 Constant Height setups in action?
2.35 Picture Thread
Jeff Leonard
Willy Gib
Alan Gouger
Gary Lightfoot
Additional reading:
http://www.brooklyncenter.com/cinema...inemascope.htm
http://www.thecinemalaser.com/anamor...pport-page.htm
http://www.thedigitalbits.com/articl...hic/index.html
http://www.thedigitalbits.com/articl...reenorama.html
http://www.avsforum.com/avs-vb/attac...chmentid=39384
If I've missed anything please tell me and I'll add it on.
Tukkis is offline
post #2 of 636 Old 06-30-2005, 10:09 AM
joachimm's Avatar
The thing that wasn't quite obvious to me at first was the "scaler" part.
As I understand it you can scale/stretch using 1) a DVD player, 2) a separate box between DVD player/projector, or 3) the projector.
I think the Panasonic PT-AE700 will do the vertical stretching, but I'm not sure if that's the best way to do it (certainly the cheapest). It might be nice to have
someone expand on this part.
Thanks for writing this up.
--Joachim
joachimm is offline
post #3 of 636 Old 06-30-2005, 10:12 AM - Thread Starter
Tukkis's Avatar
Yes that sounds correct.
Yes the AE700 will do the required vertical stretch. There's only a handful of projectors that will do this.
Tukkis is offline
post #4 of 636 Old 06-30-2005, 10:31 AM
tvted's Avatar
Quoted: 23 Post(s)
This is only true of 480 source. Wish it were otherwise.
Good work BTW.
ted
tvted is offline
post #5 of 636 Old 06-30-2005, 10:33 AM - Thread Starter
Tukkis's Avatar
Yeah true, upscaled I dont think works.
Tukkis is offline
post #6 of 636 Old 06-30-2005, 10:48 AM
Josh Z's Avatar
Quoted: 2137 Post(s)
Liked: 1434
The only issue I have with the FAQ is that it implies that the only way to do constant height is with a 16:9 projector and anamorphic lens. Although this is the ideal method for optimal resolution, it is just as possible to establish a constant height arrangement with just a 16:9 projector and no anamorphic lens (or a 4:3 projector with anamorphic lens) so long as you are comfortable with not using all of the projector's available pixels.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #7 of 636 Old 06-30-2005, 03:28 PM
Shawn Kelly's Avatar
Quoted: 37 Post(s)
Liked: 25
Tukkis, while this covers more than constant height 2.35, we've had a lot of folks comment over the years that it has been helpful.
http://www.panamorph.com/ConfigurationGuide.htm
Shawn Kelly
Panamorph, Inc.
www.panamorph.com
Shawn Kelly is offline
post #8 of 636 Old 06-30-2005, 07:50 PM - Thread Starter
Tukkis's Avatar
This is very true. I'll add that comment to the post. The point of the FAQ was to answer some of the basics of constant height for new comers. Alot of the same questions kept popping up in this forum.
Thanks Shawn, I added that link to the top.
Tukkis is offline
post #9 of 636 Old 07-01-2005, 11:16 AM
Josh Z's Avatar
Liked: 1434
Any thoughts about adding some info for those doing contant area set-ups, or is that a whole different can of worms?
Josh Z
Josh Z is offline
post #10 of 636 Old 07-01-2005, 01:08 PM - Thread Starter
Tukkis's Avatar
I'd love to add it but dont know enough about the mechnics of it. If you or someone else would like to write a summary about constant area please do so and I'll add it in.
This is the only info I have about it. http://www.videophile.info/Screen/Page_01.htm
Tukkis is offline
post #11 of 636 Old 07-01-2005, 01:51 PM
Josh Z's Avatar
Liked: 1434
I have some screenshots from my constant-area setup here:
If I find some free time, I'll write up a more detailed explanation of it.
Josh Z
Josh Z is offline
post #12 of 636 Old 07-01-2005, 02:40 PM
tvted's Avatar
Quoted: 23 Post(s)
tvted is offline
post #13 of 636 Old 07-01-2005, 10:23 PM - Thread Starter
Tukkis's Avatar
Ted and Josh, thanks I added those links in. I'll keep adding to constant area as I get more info.
Tukkis is offline
post #14 of 636 Old 07-03-2005, 03:50 PM
jamin's Avatar
Quoted: 30 Post(s)
Liked: 29
Alternatively to step 4, one can use a vertical anamorphic lens that squeezes the picture back down therefore gaining the same benefits.
Yes
If you were to use a vertical lens then you would have to manually zoom the projector the extra width necessary for constant height.
This is a bit misleading. There is no "extra width necessary" for constant height. There may however be a width that you want for your setup.
The vertical lens can be put in front of a 16:9 projector and boom - it is 2.35. Since the width in that case stays the same, one way of thinking of it is that the throw distance is unchanged. That is in contrast to the horizontal stretch anamorphic lens which decreases the throw distance.
Without performing this zoom on a vertical lens it would only be a constant width, variable height setup and not constant height, variable width.
Other than changing the aspect ratio, the lens by itself does not make a PJ constant anything, nor does a one time zoom. The scaling performed prior to allowing the image to be displayed provides for the constancy element.
I realize that some will use the lens some of the time and remove it (or pass through) at other times. This then becomes another element of the "scaling" and typically allows for maximizing panel utilization albeit with a fluctuating illuminance ( which may or may not be a problem).
So the lens, either vertical of horizontal, merely changes the aspect ratio of the projector. As always, any picture aspect ratio greater than that of the PJ will result in a letterbox and anything less results in a pillar box.
plug in to play
Acoustic Mafia - Hear No Evil
jamin is online now
post #15 of 636 Old 07-04-2005, 08:40 AM - Thread Starter
Tukkis's Avatar
jamin , thanks for the input. I updated that section with your feedback. Please check to see if its correct now.
Tukkis is offline
post #16 of 636 Old 07-04-2005, 11:28 AM
jamin's Avatar
Quoted: 30 Post(s)
Liked: 29
Tukkis,
Hmm, let me try it this way.
The aspect ratio of the projector combined with the anamorphic lens transformation creates a new "native" aspect ratio for the projection system. It matters not whether the lens does a vertical squeeze or a horizontal stretch.
With respect to the aspect ratio, and given the same scalar, you can mutiply the numerator or divide the denominator and it makes no difference:
AR = ( 16 * k ) / 9 = 16 / ( 9 / k )
Any time the picture to be displayed is not the "native" aspect ratio of the projection "system" then the full panel will not be utilized.
This is true regardless of the type of lens used for the anamorphic transformation.
When the aspect ratio of the picture to be displayed is greater than that of the projection system then letter boxing needs to be established. Likewise if the AR of the picture to be displayed is less than that of the projection system then pillar boxing needs to be established.
Again this is true regardless of the type of lens used for the anamorphic transformation.
The panel AR of the projector should be thought of as a non square pixel panel that has the AR of the projection system when the lens is in place.
This is Irrespective of the type of lens employed.
If the lens is removed, or passed through, the PJ panel AR again becomes the aspect ratio that is native to the projector.
Scaling to the PJ panel is the same when either lens type is in place. Scaling to the PJ panel is the same when either lens type is removed.
A situation occurs when removing a vertical squeeze lens that does not happen when removing a horizontal squeeze lens. The displayed picture becomes too tall for the screen. That is assuming the screen AR matched that of the PJ and lens system. In that case the PJ zoom function must be employed to shrink the displayed pictured -- Hmm, scaling with a lens again. This time however the shrink occurs equally in both dimensions - isotropic scaling.
Additionally, depending on the specific lens and projector, lens offset can enter into the mix and require additional adjustments. Some vertical squeeze lenses shift the position of the displayed picture vertically. Some projectors may shift the vertical position of the center of the picture when zoom is invoked as well.
plug in to play
jamin is online now
post #17 of 636 Old 07-04-2005, 11:54 AM - Thread Starter
Tukkis's Avatar
Tukkis,
As I understand it when you put a anamorphic lens in front of a 16x9 projector, the projector is now a 2.35 projector. So as you said anything smaller than the projector ratio (2.35 with lens on) has black bars. With a horizontal and vertical lens this occurs. The way around it with a horizontal lens is passthrough or remove the lens. This inturn now makes it a 16x9 native projector. Removing the vertical lens also makes it a 16x9 projector again but as you said it's too tall. So zooming is required.
So the best and simplest way to get full resolution for 16x9 and 2.35 is use a horizontal lens. This means passthrough can be used and no zooming is required.
But you're right, both vertical and horizontal will work. Vertical just needs more effort to setup each time if you want the best PQ for all ratios.
Did I write anything incorrect in the faq?
Tukkis is offline
post #18 of 636 Old 07-04-2005, 12:28 PM
jamin's Avatar
Quoted: 30 Post(s)
Liked: 29
Correct
If you were to use a vertical lens and wanted to maintain constant height, you would have to scale or zoom anything narrower than 2.35 so that it fits within the height restrictions.
If you want constant height then you need do nothing with AR less than 2.35 as long as the lens stays on -- regardless of which type of lens it is.
This means anything less than 2.35 would have black bars on the sides if you use a scaler.
This is true of either type of lens.
If you zoom down then full picture quality is maintained for all ratios.
The full panel resolution can only be utilized for 2.35 when the lens is on (either lens type) or for 16:9 movies when the lens is off. All other ARs decrease panel utilization. Of course this is always true of all projectors at any AR other than native.
You cant use all the projector's resolution/brightness for movies narrower than 2.35 with a vertical lens and still maintain constant height if you use a scaler.
You can maintain constant height for ARs less than or equal to 2.35 with a scaler regardless of which lens type is in place. You can not use the full panel resolution for all aspect ratios as noted above, regardless of which lens type.
If you leave the vertical lens in place and scale instead of zooming narrower films, you lose some resolution/brightness due to side black bars.
And this is true whether the lens is a vertical squeeze or horizontal stretch.
plug in to play
jamin is online now
post #19 of 636 Old 07-04-2005, 06:01 PM
jamin's Avatar
Quoted: 30 Post(s)
Liked: 29
Some may find this useful even in the CH forum.
Attached is a graph showing pixels on screen vs aspect ratio for various PJ configurations.
A couple of things to note : positive slope lines denote constant height (CH) regions and negative slope denotes constant width (CW) regions. The horizontal no slope lines are for constant area (CA) implementations.
EDIT:update jpg
plug in to play
jamin is online now
post #20 of 636 Old 07-04-2005, 09:44 PM - Thread Starter
Tukkis's Avatar
Jamin, Thanks for the link. I added it to the post.
With regards vertical lens stuff we were discussing, would you mind writing a couple of paragraphs and I replace mine with what you write. This should clear alot of it up.
Tukkis is offline
post #21 of 636 Old 07-05-2005, 05:34 AM
Quoted: 37 Post(s)
Liked: 25
Hi Tukkis. I would just like to add that it might be good to qualify this with a "for constant height". I realize this is a constant height forum but a constant width forum does not exist here at this point. Vertical compression lenses are best for max resolution in a constant width scenario.
Also note that some horizontal lenses still produce a vertical offset when they are removed, so the relative ease of achieving 16:9 max res even in CH mode depends on the horizontal lens type.
Shawn Kelly
Panamorph, Inc.
www.panamorph.com
post #22 of 636 Old 07-05-2005, 09:42 PM
jamin's Avatar
Quoted: 30 Post(s)
Liked: 29
1. ~~~~~
2.~~~~~
3.~~~~~
4. An Anamorphic lens (Horizontal stretch or Vertical squeeze)
5.~~~~~
plug in to play
jamin is online now
post #23 of 636 Old 07-06-2005, 12:38 AM - Thread Starter
Tukkis's Avatar
Thanks jamin, I replaced mine with what you wrote.
Tukkis is offline
post #24 of 636 Old 07-07-2005, 08:17 AM
acksnay's Avatar
Great and noble effort Tukkis!
Here's some outstanding issues I'm having during my CIH design (Infocus 7210 / Primasonic H-1000 / Premiere Gyrolock):
1) Lumen calculations: What percentage loss/gain between a 16:9 letterboxed image and the full panel / 2.35:1 stretched image?
2) Mounting the lens. Does it have to be DIY? Do any ceiling mounts have extensions?
3) Should screen to seating ratios change based on new stretched pixel size? (Not that I'd move my sofa back and forth mind you ). 4/3x is standard with 720p. Should that be reconsidered?
acksnay is offline
post #25 of 636 Old 07-07-2005, 08:39 AM - Thread Starter
Tukkis's Avatar
About a 20% increase between a zoom/letterboxed 2.35 image and one with the lens that uses the full panel.
There may be. I dont know enough about that to give you a decent answer. Maybe do a search on here to see how others mount theirs.
I dont have a constant height setup yet but from what I've read for seating distances, about 1.2-1.3x for 2.35 images were what most were using. Its up to personal preference really so maybe try it on the wall first to see the size. Or if you can move seating then you have a bit of leeway.
Tukkis is offline
post #26 of 636 Old 07-10-2005, 02:43 PM
WillyGib's Avatar
WillyGib is offline
post #27 of 636 Old 07-10-2005, 05:18 PM
bills2k's Avatar
O NELLY!!! O WILLY!!! I am stunned. What an incredible job. Thank you so much for posting. It gives people like me so much hope and excitement waiting for my goodies to arrive so that I acn proudly join you guys. What scaler are you using? The H1000 gives a stunning picture. Enjoy.
bills2k is offline
post #28 of 636 Old 07-11-2005, 06:37 AM
WillyGib's Avatar
The 4805 has a letter box mode that will do the vertical stretch for 2.35 films, so for now thats what I use. Once I upgrade the PJ, in a couple of years, then I will think about a scaler (Dragonfly)
WillyGib is offline
post #29 of 636 Old 07-11-2005, 02:27 PM
jeffleonard's Avatar
Just a quick post to say you can check out my 2.35 setup here in the member's gallery.
jeffleonard is offline
post #30 of 636 Old 07-11-2005, 02:46 PM
bills2k's Avatar
Excellent work, Jeff. When am I going to be able to watch my movies in 2.35:1 ?
bills2k is offline
Reply 2.35:1 Constant Image Height Chat
