CH and HS20 - AVS Forum | Home Theater Discussions And Reviews
Old 08-19-2005, 03:19 PM - Thread Starter
elm_sd's Avatar
I am looking at CH for my Sony HS20 the with a height of 51" , becasue of the recessed lens of the HS20 what would be a good selection for this projector , is it worth it to use a ISCO 3 for the HS20.
The ISCO site has the atachment 2 for this projector..
Best Regards
ELM_SD
Quality TV = C-Band
elm_sd is offline
Old 08-20-2005, 02:42 PM - Thread Starter
elm_sd's Avatar
Well in my search I have found that the panamorph 752 might work as it accepts up to 50mm and the next size the P75J is up to 75mm, flush on my projector is 35mm but with these lens I loose is screen size since I cant move my projector back and I dont want to zoom in case of cut off with the lens..
still looking
ELM_SD
Quality TV = C-Band
elm_sd is offline
