New question re: dvd players and V stretch - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-27-2006, 03:09 PM - Thread Starter
McCall's Avatar
Ok let me ask a question this way. Those of you that use a DVD player to vertically stretch your image for CIH 2.35:1. What make and model are you using of DVD player? thank you.
McCall
Yup that really IS me in the avatar.
http://www.avsforum.com/avs-vb/showt...he+Mickelodeon
McCall is offline
post #2 of 9 Old 11-27-2006, 05:00 PM
CraigN's Avatar
The Samsung 860 and presumably 960 can do it.
I, however, use the vertical fit mode on a Panasonic AX-100 projector to achieve the same thing.
CraigN is offline
post #3 of 9 Old 11-27-2006, 09:39 PM
scottyb's Avatar
Quoted: 18 Post(s)
McCall,
Your projector does the proper stretch. You need to use the "letterbox mode" for 2:35 movies.
Scott
scottyb is online now
post #4 of 9 Old 11-27-2006, 10:21 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
I have two players connected right now -
Both players are set to 16:9...
Player 1 (Toshiba 2106) is over component and this allows me to use either 4 x 3 normal or 4 x 3 zoom to display both ARs in the correct geometry.
Player 2 (Samsung HD950) is over digital. I use the full mode and then H-stretch for 235...
Both are SD though...
Mark
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #5 of 9 Old 12-09-2006, 12:49 PM
tcreech's Avatar
Momitsu 880
Not only does it have x-y scaling, but custom resolutions as well, so I can output a stretched, pixel-mapped image to my IF 4805...Looks great!
TC
tcreech is offline
post #6 of 9 Old 12-14-2006, 07:02 PM
stevejack's Avatar
Originally Posted by tcreech View Post
Momitsu 880
TC
I have the momitsu as well, but it has been a long time since I tried to pixel-map with it.
Where did you get your custom values from? I am interested in doing the same thing with my PE8720
Cheers,
Steve
stevejack is offline
post #7 of 9 Old 02-13-2007, 04:24 PM
ksmut's Avatar
Is the Momitsu 880 the only player that will pixel map and do x-y scaling?
ksmut is offline
post #8 of 9 Old 02-14-2007, 10:17 AM
bluesboyjr's Avatar
Are there any HD-DVD or BD players that can accomplish this task?
bluesboyjr is offline
post #9 of 9 Old 02-14-2007, 07:46 PM
CAVX's Avatar
Quoted: 122 Post(s)
Liked: 79
There is a rumour about that Samsung may add "Ezview" to their next Blu-ray player.
We can only hope...
Mark
Mark Techer
CAVX is offline
Reply 2.35:1 Constant Image Height Chat
