A question about constant hight - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-09-2007, 06:46 PM - Thread Starter
mrigsby's Avatar
Ok, I'm looking in to going the constant 2:35:1, but what happens when you watch something that doesn't conform to the lenses. I've read that panamorph works with 70% of movies, does it work with TV shows as well? How does this work.
If this has been asked before, forgive me, I did a search and couldn't find anything
Thanks in advance.
mrigsby is offline
post #2 of 4 Old 02-09-2007, 08:00 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
The only time a program or source "does not conform" is when it can not be 'scaled'.
Typically for this type of program, you simply move the lens out of the light path...
Mark
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #3 of 4 Old 02-11-2007, 02:19 PM
McCall's Avatar
Thanks in advance.
Nothing is going to give you a 2:35 width picture for all your aspect ratio DVDs or TV.
as stated you can move the lense out of the way. and other aspect ratios will have black bars
McCall
Yup that really IS me in the avatar.
http://www.avsforum.com/avs-vb/showt...he+Mickelodeon
McCall is offline
post #4 of 4 Old 02-11-2007, 07:02 PM
Tukkis's Avatar
Anything narrower than 2.35 will leave unused portions of the screen blank on the sides. If you leave the lens in place all the time these unused portions on the side will be black bars.
If anything is wider than 2.35 (eg. 2.76) you'll use the full width and have black bars top/bottom.
Tukkis is offline
Reply 2.35:1 Constant Image Height Chat
