DIY Hockey goal lights - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-25-2008, 12:04 PM - Thread Starter
bucnasty's Avatar
Being the biggest caps fan I know (as well as the poorest), I had to do something to make my room feel more like the verizon center. This setup has 19 inch legs as a base, 1 1/4 inch dowels, and the wood I used for the box is a 1x8 plank I procured from home depot for 8 or 9 bucks. The lights on the outside are Thomas and Betts Red Dot VAG-01 (the red and green glass bulbs are like 60 each so i'm sticking with colored bulbs), the center light was just a beacon light I picked up from a party store. They are plugged into three seperate remote controlled AC adapter plugs, its called superswitch and i got it from costco for like 15 bucks.
I also made an ambient light setup for my television using the stand itself, 1/2 inch dowels come out from the goal light stand into 3/4 inch dowels across, 1/2 inch dowels up and down. Again, being a poor college student, I am only using christmas lights right now.
bucnasty is offline
post #2 of 7 Old 06-25-2008, 04:49 PM
HeyNow^'s Avatar
Ted Leonis just called....SCORE!!!!!!!!!!!!! Wow nice,very nice. Great idea. Gosh, you just have to love this forum!
HeyNow^ is offline
post #3 of 7 Old 06-29-2008, 08:43 AM
carboranadum's Avatar
Quoted: 22 Post(s)
Liked: 26
Looks cool. Do you have the christmas lights on a dimmer?
CJ
carboranadum is offline
post #4 of 7 Old 06-29-2008, 05:23 PM - Thread Starter
bucnasty's Avatar
just an on/off RF remote, eventually I plan on using those 45 dollar LED bars from costco that react to sound and have 6 colors and all that but moneys tight and probably wont come till the fall..
bucnasty is offline
post #5 of 7 Old 07-29-2008, 07:33 PM
Netko350Z's Avatar
Netko350Z is offline
post #6 of 7 Old 11-12-2010, 12:07 PM
brakel's Avatar
Liked: 45
For anyone looking for an inexpensive, remote controlled goal light to round out your home "arena", check out this goal light: http://thegoallight.com/
It used multiple LCDs to simulate a rotating goal light. It also has the horn sound (which can be turned off).
I am not affiliated with thegoallight.com but I listen to a podcast by one of the makers of the product.
PSN brakel
brakel is offline
post #7 of 7 Old 04-22-2012, 09:45 AM
fleegerc's Avatar
That setup looks awesome. I have a question about hooking up a speaker so when I kick the light on it plays a Chelsea Dagger clip. Do you know the best way to do this? I'm struggling to find anything on the internet for an easy solution.
fleegerc is offline
Reply Game Room Equipment & Accessories
