Movie Poster lightbox help. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-06-2008, 06:09 PM - Thread Starter
mosten's Avatar
I picked up 2 movie poster lightbox's today. There is no plexi in them so I need to get some. It has the spring loaded clips (4 metal frame pieces swing outward spring loaded to allow the poster to be put in while hanging). My question is do I need to sandwich the poster between two pieces of plastic, or can I get buy with just one sheet of plastic on the outside?
mosten is offline
post #2 of 2 Old 09-07-2008, 11:22 AM
Cameron's Avatar
Good question. Around here our plastic supplier doesn't give a discount if all you are buying is one or two pieces of acrylic. So I would get the first piece made and see how it goes.
-- Well I have really blown my budget now. --
Cameron is offline
Reply Game Room Equipment & Accessories
