Should i d set my Xbox 360 to 480P when watching movies? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-08-2009, 04:02 PM - Thread Starter
bond_007's Avatar
i use my 360 as my dvd player, if i have it set at 720p, does the Xbox have to downscale when watching a dvd? if it does wouldnt it be better to set it at the dvd's native resolution? im using at samsung project with a native res of 1280x720p native i believe, if it matters
bond_007 is offline
post #2 of 5 Old 02-08-2009, 05:41 PM
whiskey > work's Avatar
it won't upscale unless you have it connected with hdmi or vga
whiskey > work is offline
post #3 of 5 Old 03-08-2009, 04:06 PM
Lighting Guy's Avatar
Quoted: 14 Post(s)
Technically it should look better the higher the res from the xbox. You should set it to what looks best to you though, because that depends on your projector's scaler, etc.
Lighting Guy is offline
post #4 of 5 Old 03-20-2009, 12:09 PM
neo235's Avatar
For movie 480p is recommneded [IMG]http://www.********************/pics/6/7.gif[/IMG]
neo235 is offline
post #5 of 5 Old 03-20-2009, 01:08 PM
TurkeySandwich's Avatar
As you know, standard DVDs will be 480P straight from the disc but your projector will display a 720p image. Converting the 480p signal up to a 720p signal can be done by either the xbox 360 or the projector.
You have two options.
1 - Set the Xbox 360 to output 480p. If the Xbox 360 outputs 480p, the projector will convert (upscale) that 480p signal to 720p.
2 - Set the Xbox 360 to output 720p. In this case the Xbox 360 will take the 480p signal and upscale it to 720p to output. This 720p signal will then be displayed by your projector.
Which method you use depends on whether the Xbox 360 or the projector does a better job of upscaling. This is purely a subjective call, and in most cases the differences won't be noticeable unless you are specifically looking for them.
To answer your question - There is no right or wrong way to set it up. Try them both and see which one you like better.
And fyi - this is probably better suited for the Xbox forum, or even the DVD player forum.
TurkeySandwich is offline
Reply Game Room Equipment & Accessories
