Composite AV Selector/Switch Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-05-2010, 07:00 PM - Thread Starter
Mr Schickadance's Avatar
I have a bunch of older video game systems I wanted to connect to my HDTV. My tv only has one composite input so I would need a switch/system selector. I have about 6 systems I need to connect and everything I've seen is mainly 3 or 4 inputs. Does anyone have any recommendations on where to look or what to get? I've seen a lot for component and hdmi but nothing for older composite connections. Thanks.
Mr Schickadance is offline
post #2 of 10 Old 02-06-2010, 11:01 AM
Chris Ruhl's Avatar
I don't know if this will work or not, but dont' see why it wouldn't.... a Component Switcher should work for composite, if it's a mechanical switcher.
Chris Ruhl is offline
post #3 of 10 Old 02-06-2010, 07:44 PM
elmalloc's Avatar
Quoted: 26 Post(s)
Liked: 42
someone buy this man a new TV
Current Projects:
ON HOLD - Building Home Gym.
elmalloc is online now
post #4 of 10 Old 02-06-2010, 09:03 PM - Thread Starter
It's actually a newer tv. Samsung 42inch 1080p...3 HDMI inputs, 2 Component, and 1 Composite (which is what all the older video systems use, like NES and Sega Genesis). It just seems like like clearly nobody really uses these type of connections anymore on newer tv's. Make sense?
post #5 of 10 Old 02-07-2010, 08:22 AM
elmalloc's Avatar
Quoted: 26 Post(s)
Liked: 42
Yes. Argh I want NES and Sega to work as well!!!
You should purchase a cheap receiver, many of the receivers nowadays will switch composite inputs up the HDMI input for you.
Current Projects:
post #6 of 10 Old 02-07-2010, 09:34 AM - Thread Starter
Wow..did not realize they made things like that. What kind of receiver do you mean?
post #7 of 10 Old 02-07-2010, 11:46 AM
elmalloc's Avatar
Quoted: 26 Post(s)
Liked: 42
Myb rother in law just bought an onkyo receiver ($300-350ish) that auto converts all signals to be sent over a single HDMI. SO you could plug all your components into it and it will play it through one cable to your TV.
I can find other brands/models if you're interested. I bet even some of the sub $300 receivers do that.
Current Projects:
post #8 of 10 Old 02-07-2010, 12:30 PM - Thread Starter
I didn't realize that the receivers did that as well. I was looking into Onkyo a month ago for a 5.1 system but never got around to buying one. This would be great and take care of both things then. Thanks for the help.
post #9 of 10 Old 02-07-2010, 12:33 PM
elmalloc's Avatar
Quoted: 26 Post(s)
Liked: 42
yes you need a receiver, they do many things well nowadays. make sure you buy a new one, older models don't do everything.
new ones nowadays switch 3-4 HDMI/components/svideos/composites for you, and will output them all over just one HDMI cable.
Current Projects:
post #10 of 10 Old 02-22-2010, 03:53 PM
vegaskiller73's Avatar
You can try this one.
Click Me
I have this one from monoprice Click. Mine is hooked up to the BD player and xbox360 and it works great for the money.
It says componant but in the Knowledge Base section someone asks the question of what you are trying to do.
vegaskiller73 is offline
Reply Game Room Equipment & Accessories
