Finally found a solution for those looking for a score ticker - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #61 of 69 Old 07-02-2015, 06:38 AM
turls's Avatar
Quoted: 477 Post(s)
Liked: 205
Originally Posted by Ryan J. Cahoy View Post
Question on Data what is of most interest - is it the big 6 sports (NFL, NBA, NHL, MLB, NCAA BB, NCAA FB) scores or is the interest more in following key news sources or twitter feeds of specified athletes or news agencies?
Thanks, I completely forgot about that. My old GoogleTV box had a nice screen saver type app that showed my Twitter feed. That is more valuable than the scores these days. I like to have various fan and official tweets going during sporting events on my 2nd screen. Having that on a 2nd large screen would be the most valuable. And that may not be as expensive for you or the end user either?
Matt
turls is offline
post #62 of 69 Old 07-02-2015, 06:49 AM
Liked: 3
Twitter is fairly easy - for flat screens that is a free widget in our platform where you can just pick a hashtag or user to follow.
Same with our web based ticker platform Twitter is free since we don't have any licensing fees to pay.
here are all of the different types of search strings you can do in twitter to define your own feed http://www.risedisplay.com/solutions/twitter-tickers/
any other thoughts on content out there?
Ryan
turls likes this.
Ryan J. Cahoy is offline
post #63 of 69 Old 07-15-2015, 11:14 AM - Thread Starter
cpotteke22's Avatar
As the OP of this thread, and the fact that I've recently moved, I'm looking to refresh my setup with something a little more "2015-ish" As others have mentioned, cost is a concern (the $20/month isn't too bad - would be nice if that could be split up based on use), but I'm wondering what could be done via software/hardware in a residential application to feed the score data into a "window" of sorts (like a small banner at the bottom of the screen or a side panel) on an existing TV.
Ryan - What other information do you have about your platform that supports this or the more standard ticker display?
cpotteke22 is offline
post #64 of 69 Old 07-15-2015, 11:19 AM
Liked: 3
For a video type display check out this free, open source software at www.risevision.com, there is a store with premium widgets for sports data that is licensed but there are free RSS widgets if you can find your own free feed.
If you install this on a computer (windows, linux, chromebox) and hook it to a monitor or large flat panel you can format the screen however you want.
As for more standard tickers, unfortunately at this point in time I would say we are probably too expensive for most home users given we are a US made product and focused on higher end custom applications. We have started to release a basic Easy Ticker product at http://www.risedisplay.com/easy-ticker/ that you could take a look at and there is an overview of our software there.
I hope that helps.
Ryan
turls likes this.
post #65 of 69 Old 08-05-2015, 12:34 PM
Liked: 1
You might want to check out videosportsticker.com...it is not customizable at the moment but we will be updating it in the near future. It can display Twitter posts to...to see a live full screen example, you can go to bokampers.videosportsticker.com.
Any thoughts and/or comments are welcomed...
turls likes this.
schencka is offline
post #66 of 69 Old 11-03-2015, 08:37 AM
Liked: 0
I am looking to attempt this project. What is the best LED (compatible, large, economical) to purchase to go along with the kitchi RSS software, and where can I purchase it from? Also, what are good rss feeds to use with it? Thanks.
ysebrow is offline
post #67 of 69 Old 11-05-2015, 07:17 AM
turls's Avatar
Quoted: 477 Post(s)
Liked: 205
See my post:
Mine is still in the box because the room it is going in is on the extreme back burner and I will probably use digital signage instead (although I don't have a good real time solution for it yet either). If you are interested let me know.
Matt
turls is offline
post #68 of 69 Old 02-02-2016, 04:43 PM
RBalwinski's Avatar
Quoted: 70 Post(s)
Liked: 50
Finally got to the Ticker display in the basement
Originally Posted by Peter Wallin View Post
Great pictures! That's what I made the program for.
I am the developer of "kitchi"
-Peter
Thanks Peter, I downloaded the program a little while ago and this evening purchased it. The help was rather basic, but I did have a feed up and running in no time. Found in your help was a 3 source feed. This really opened the doors for me. I have modified that as a test bed. One feed is showing NBA news, one is showing Hockey scores (there is a feed out of Europe), and the 3rd is showing latest local headlines. It seems to be working pretty good. Just need NFL and MLB to start up again.
I am going to try include my XML configuration file here, maybe it will help others out.
Projector: Epson Home Cinema 5030UB
Receiver: Pioneer Elite VSX-90
Bluray: Sony BDPS5500
Screen: Elite Screens ezFrame Series, 100" 16:9 AT AcousticPro1080P3 FF Screen
+ 6 Sonos Connects, Dayton Audio MA1240a Multi-Zone 12 Channel Amplifier
RBalwinski is offline
post #69 of 69 Old 04-18-2017, 08:23 PM
Liked: 0
ProLite TruColor XP to PC connection
hello, i just bought a used ProLite TruColor XP led board. It has one rs 232 jack on the side. Id like to get it connected to a PC for displaying RSS feeds (via kitchi). Not sure if I need a "MiniWeb" device to convert the RS232 connection to LAN, or if there is a RS 232 to db9 connector I may use?? My PC has both a serial port asnd USB 2.0/3.0 ports. What is the best method/cabling option to use with this board to have it communicate with my PC. Thanks!Chris
wcglitz01 is offline
Reply Game Room Equipment & Accessories
