Finally found a solution for those looking for a score ticker - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1 of 68 Old 07-28-2010, 06:21 AM - Thread Starter
cpotteke22's Avatar
After months of sporadic searching, I finally found an easy, inexpensive way to stream sports scores and news to an LED ticker display. I know there have been a few looking for the same thing from time to time, so I figured this would probably be useful. Best part is no subscription fees and low cost.
First, find a BetaBrite, Alpha, or ProLite LED display (used is fine - I have a lightly used 48 inch ProLite TruColor XP I found on ebay for only about $80).
Next, depending on what sign you get, you will either need a long USB cable or a combination of DB9 cable/USB converter for connection to a computer running the software.
Last, Install this cool software that can stream RSS data to the sign. I use this one: http://www.kitchi-rss.com/ its very easy to use and free for most of the features (unless you want to run kitchi in the background as a service).
Pictures and video of my setup coming soon
cpotteke22 is offline
post #2 of 68 Old 07-29-2010, 07:13 AM - Thread Starter
cpotteke22's Avatar
photos added:
post #3 of 68 Old 08-03-2010, 01:01 PM
jkv
jkv's Avatar
thanks for the pointer.
Riverside Cinemas
jkv is offline
post #4 of 68 Old 08-03-2010, 10:10 PM
spartan119's Avatar
Nice setup man!
spartan119 is offline
post #5 of 68 Old 08-11-2010, 09:27 PM
pkonold's Avatar
Absolutely love it! Thanks man. Off to eBay
pkonold is offline
post #6 of 68 Old 08-12-2010, 10:52 AM
alarsuel's Avatar
cp, thanks for the idea. I have purchased my display, but while I'm waiting for it, I'm trying to get the rest together. What rss feed or feeds are you using?
alarsuel is offline
post #7 of 68 Old 08-12-2010, 11:17 AM - Thread Starter
cpotteke22's Avatar
I have been using the rss url's provided from ESPN's website:
http://sports.espn.go.com/espn/rss/index
I also found a site where someone created their own rss code which pulls the scoreboard info from ESPN. I don't have the link but I think I found it by searching google for RSS scoreboard feeds
post #8 of 68 Old 08-12-2010, 02:41 PM
Crise44's Avatar
Nice setup
Crise44 is offline
post #9 of 68 Old 08-12-2010, 03:14 PM
alarsuel's Avatar
Possibly stupid question to follow: Are those news feeds or am I missing the feeds for just scores, or are they all together i.e.: the NBA news feed includes game scores when there are games.
alarsuel is offline
post #10 of 68 Old 08-12-2010, 03:22 PM - Thread Starter
cpotteke22's Avatar
Unfortunately, and I am guessing as a way to protect the subscription based services, the major news networks (Sports or otherwise) do not provide live score info. As I mentioned, several people have taken it upon themselves to create their own RSS feeds from the scoreboard data from ESPN.com, etc. I don't have the URL for one of these handy right now, but I might be able to get it posted later
post #11 of 68 Old 08-16-2010, 09:19 PM
mhdiab's Avatar
Quoted: 60 Post(s)
Liked: 39
Anyone know how sports bars get their feeds? Should be a business here somewhere. Either way your setup looks great. I just need to figure out a wireless feed...
mhdiab is offline
post #12 of 68 Old 08-17-2010, 07:31 AM - Thread Starter
cpotteke22's Avatar
Thanks for the kind comments everyone
post #13 of 68 Old 08-21-2010, 12:20 PM
alarsuel's Avatar
I found some feeds here: http://forum.xda-developers.com/showthread.php?t=272354. Are these the ones you are using? Also, have you found a way to load multiple feeds into kitchi? I also have a Pro Lite, so I am thinking it should be the same. Oh, 1 last question: Do you get all the data or does it stop? I don't seem to get the whole scroll of games. Maybe 2/3 come through. I'm guessing that I'm reaching the character limit before all of the games. Any idea to combat this (maybe I need a feed with team abbreviations)? Again, thanks for the help and the great idea!
alarsuel is offline
post #14 of 68 Old 08-22-2010, 06:44 PM
alarsuel's Avatar
I lied, more ?'s. What settings are you using for a USB connection? I have gotten the sign working with a rj12 cable/serial adapter. However, when I try on a newer computer (no serial port) with a serial/usb adapter, nothing happens. Any ideas?
alarsuel is offline
post #15 of 68 Old 08-24-2010, 07:03 AM - Thread Starter
cpotteke22's Avatar
I'm using a dedicated, older computer for the sign that has a DB9 COM port on it so this is not something I've run into. My only guess is maybe baud rate of the port?
post #16 of 68 Old 08-24-2010, 07:09 AM - Thread Starter
cpotteke22's Avatar
I'm pretty sure those are the URL's I'm using...hopefuly I will be able to find similar work done by someone for top Fantasy Football scorers as the season nears.
To answer your questions, you can add multiple feeds by right-clicking input in Kitchi and select add input- you can then prioritize the individula inputs by right-clicking them and selecting move up or move down.
I have also had a problem with the feeds getting cut off. I have been playing around with a few things and am unsure if its the rate of my updates being to short, character count, or if the URL's for the RSS data cut the feed.
post #17 of 68 Old 08-24-2010, 05:35 PM
alarsuel's Avatar
Thanks for the answers! I guess I'll contact the dev for kitchi and see if they can answer the cutoff question. Does the NFL feed work for you? I can get MLB (or could on the old computer with serial port) but the NFL feed didn't give me anything. I though it was because of preseason, but click the url gives scores. We ought to be able to get this working flawlessly by Sep. 2nd! I let you know what I find from kitchi.
alarsuel is offline
post #18 of 68 Old 08-25-2010, 06:41 AM - Thread Starter
cpotteke22's Avatar
Excellent, I look forward to hearing what you find out!
post #19 of 68 Old 09-28-2010, 02:35 AM
turls's Avatar
Quoted: 465 Post(s)
Liked: 194
Have been watching this type of thing on and off looking for a solution without a subscription. I love the solution here but still dream about something closer to this:
http://www.risedisplay.com/products/LED_tickers/
or
http://www.tickercom.com/9/sports.html
I guess this solution really isn't any better than a DIY solution, interesting they are getting some press now:
http://www.twisplays.com/index.php?page=faq
Matt
UMR on HDR vs 4K: The benefit of greater saturation and luminance capability is...not very evident in all images unlike more pixels which can be seen in every scene.
turls is offline
post #20 of 68 Old 09-28-2010, 06:53 AM
moonheart's Avatar
This one is really interesting set up. Appreciate it.
Live and let to live other
moonheart is offline
post #21 of 68 Old 09-29-2010, 07:55 AM - Thread Starter
cpotteke22's Avatar
Any luck with this yet?
post #22 of 68 Old 10-17-2010, 09:39 PM
turls's Avatar
Quoted: 465 Post(s)
Liked: 194
Just got a used Alpha 220C through Ebay. Theater/Bar isn't done yet, but at least I can probably still hook this up elsewhere until then.
Also this is a pretty good tutorial, whether you are putting Twitter on the scroll or not:
http://www.youtube.com/watch?v=QR4dzFDwLns
Matt
turls is offline
post #23 of 68 Old 10-19-2010, 09:01 PM
qweqeqqa's Avatar
Nice done
qweqeqqa is offline
post #24 of 68 Old 10-20-2010, 08:06 PM
wolfievtec's Avatar
Sweet I've been looking for a sports ticker. Do you use that same program and just program in a sports RRS feed?
wolfievtec is offline
post #25 of 68 Old 02-23-2011, 02:37 AM
alarsuel's Avatar
Thought I'd update. I'm still having the problem of the ticker getting cutoff before all the info scrolls through. I tried the Kitchi devs but didn't hear anything. This reminds me to try them again.
alarsuel is offline
post #26 of 68 Old 02-24-2011, 12:33 PM - Thread Starter
cpotteke22's Avatar
I'm having the same problem. It also appears the NFL live scoring URL was no good. I wasn't able to receive live scores all season. At least with baseball season around the corner that one works
post #27 of 68 Old 03-31-2011, 08:39 AM
turls's Avatar
Quoted: 465 Post(s)
Liked: 194
Sounds like Kitchi may be a dud. Has anybody used this company?
http://tickermedia.com/sports-tickers-w.html
Matt
turls is offline
post #28 of 68 Old 06-04-2011, 07:37 PM
vespaguy's Avatar
Liked: 24
I realize this is an old thread, but I'm toying with the idea of making a "ticker" application. My idea is to make an actual scoreboard, similar to the one you'd see at the ballpark, so I needed to find realtime data... and more than just the score. And as most of you have already discovered, it's almost impossible to find RSS feeds for live stats.
But I hit a gold mine! For anyone who is looking for baseball stats - including real-time info, the MLB has a site where you can grab just about anything.
If you go to http://gd2.mlb.com/components/game/mlb/ you can drill down to the year, the date, then the game to pull information. You can also point to the current date and grab live updated XML. I believe boxscore.xml gives you the most up-to-date information.
I haven't yet written the code for my app to extract the info, but this discovery certainly gives me hope!
vespaguy is offline
post #29 of 68 Old 06-04-2011, 11:46 PM
CNWDI's Avatar
Do post if you make any significant progress. I also have interest in having a way to do a scoreboard ticker or something similar in the basement I'm finishing...but all the possible solutions I've seen either cost too much or don't give me what I really want (up-to-date scores on all games in progress year round). I *really* don't want to have to dedicate a screen to showing ESPNews.....
CNWDI is offline
post #30 of 68 Old 06-05-2011, 12:58 AM
alarsuel's Avatar
Sounds great, kitchi still gives me problems. Anything that gets us on the track to scores without being cut off is good to me. If you do end up creating an app, let us know! Truthfully, I'm not even sure the mlb, nfl, etc. data we had before still works. I'll have to check.
*The URL's found in the xda forum I linked earlier do still work. At least MLB and NHL do. Those were the only ones I could check because the others don't have any games today.
alarsuel is offline
Reply Game Room Equipment & Accessories
