Led lights - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-21-2011, 03:54 PM - Thread Starter
Cinder's Avatar
Anyone check out la led for their led flex and rgb flex?
Www.laledus.com
Cinder is offline
post #2 of 2 Old 01-24-2011, 02:28 PM
brnagin4's Avatar
I have used their rgb lights before and others. The RGB that they have is one of the best that I have seen and used. I have recently gotten their new touch color controller for it and it is really quite simple to use. It allows me to touch a wheel with all the colors on it and to also go to white from any color. It really has been the simplest RGB controller I have used.
BTW I also heard they just released a new dimming light bulb that works with all the automation systems. Has anyone seen it or used it?
Shhh did you hear that? Oh, you need better equipment!!
brnagin4 is offline
Reply Game Room Equipment & Accessories
