Is there an adapter that will allow me to connect my AV In to my Wii and DVD player? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-23-2013, 06:46 PM - Thread Starter
sanflippo's Avatar
Hello,
We have a 32 inch APEX tv. I want to keep my wii and DVD player connected to it as well as my cable box. At this point, only the cable box is connected. I have to disconnect the cable box and connect the wii or the DVR player if we want to use them. Is there an adaptor that will keep all three items connected at the same time?
Thank you
________________________
nintendo wii charger
Wii Housing Case
video game accessories for vshopmall
sanflippo is offline
post #2 of 3 Old 01-24-2013, 04:52 AM
xm41907's Avatar
Originally Posted by sanflippo View Post
Hello,
Yeah, but it will depend on what kind of connection you're tv uses, HDMI, Component, composite, etc. Figure that out, and look for a switch for that connector and you're good to go.
xm41907 is offline
post #3 of 3 Old 01-24-2013, 03:09 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
Need to know what input types are available on TV and which output types you're using for your sources. In the meantime, this may solve your problem http://www.mcmelectronics.com/product/83-12630&green=22486662030&utm_campaign=MyBuys&utm_medium=Recommendation&utm_source=hcat&utm_term=83-12630
Dropkick Murphy is offline
Reply Game Room Equipment & Accessories
