What brand HDMI Cable do you use? - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #1 of 50 Old 06-26-2014, 07:49 PM - Thread Starter
Plasma5300's Avatar
Quoted: 131 Post(s)
Liked: 24
I was just wondering which brand hdmi cable and at what length? Just curious.
Plasma5300 is offline
post #2 of 50 Old 06-30-2014, 04:21 AM
Signs's Avatar
Quoted: 208 Post(s)
Liked: 963
Just cheap unbranded ones as i don't need to go over 5 meters
Signs is offline
post #3 of 50 Old 06-30-2014, 05:23 AM
landlocked's Avatar
Monoprice
Last edited by landlocked; 06-30-2014 at 05:24 AM. Reason: included quote in error
landlocked is offline
post #4 of 50 Old 06-30-2014, 10:14 AM
airscapes's Avatar
Quoted: 390 Post(s)
Liked: 307
Mono price Redmere 30 and 40 foot. Prefect, never once a drop or sparlly or any other cable related issue as of 1 year now.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #5 of 50 Old 08-01-2014, 05:45 AM
Liked: 0
The best HDMI cable, that I heard its Monster 1000HD Ultimate High-Speed HDMI Cable.
But I use Cmple 28 AWG HDMI
grols is offline
post #6 of 50 Old 08-02-2014, 01:26 AM
aftcomet's Avatar
Quoted: 53 Post(s)
No offense, but discussing the brand of an HDMI cable is the most useless thing ever.
aftcomet is offline
post #7 of 50 Old 08-02-2014, 02:29 AM - Thread Starter
Plasma5300's Avatar
Quoted: 131 Post(s)
Liked: 24
I hear you. I was just curious. Hdmi is hdmi.
post #8 of 50 Old 08-02-2014, 01:30 PM
aftcomet's Avatar
Quoted: 53 Post(s)
Yup. Digital so it doesn't matter. I usually get $1 cables from eBay.
aftcomet is offline
post #9 of 50 Old 08-13-2014, 09:41 PM - Thread Starter
Plasma5300's Avatar
Quoted: 131 Post(s)
Liked: 24
Ive heard of redmere for thin cables with the chip to push the data. Now I seen a sony slim cable. Its really thin. Im not sure if it has a chip in it. Is it ppssible for a thin cable without the chip to push all the data correctly?
post #10 of 50 Old 08-15-2014, 10:06 AM
Avliner's Avatar
Quoted: 28 Post(s)
Liked: 34
Monoprice cables all'round, + a 30' Redmere to the PJ... no complaints whatsoever...
Regards, Chuck
Hold on tight to your dreams - ELO
Avliner is offline
post #11 of 50 Old 08-16-2014, 07:23 PM
SeveredDime's Avatar
Monoprice, my longest run is 40'. No issues.
SeveredDime is offline
post #12 of 50 Old 08-28-2014, 04:32 PM
weaselfest's Avatar
Quoted: 46 Post(s)
Liked: 41
Extron's longest super thin HDMI cable that is passive is only available up to 2m in length, for what that's worth.
underachiever extraordinaire
weaselfest is offline
post #13 of 50 Old 08-31-2014, 06:20 PM
Otto Pylot's Avatar
Quoted: 1625 Post(s)
Liked: 1020
Pure marketing b.s. Plain and simple. Any HDMI cable that comes with a certificate of compliance for the length you buy will work just fine. Presently, 25' is the maximum length that can be certified for passive high speed hdmi. Thicker gauge wire can be used just fine for longer lengths, or if your runs are under 25', you can probably get away with a smaller gauge wire if you need the flexibility and less strain on the connector end. If you need an active cable, Redmere works great.
tubetwister likes this.
Otto Pylot is offline
post #14 of 50 Old 10-01-2014, 11:02 PM
Liked: 0
Yes, Monoprice is really great..
Levonpoche is offline
post #15 of 50 Old 10-01-2014, 11:19 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
I use to use those too but they are so heavy and rigid they started to break my HDMI inputs on my AVR's
bluewaves likes this.
NODES is offline
post #16 of 50 Old 10-02-2014, 12:07 AM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 623
Monoprice ,AmazonBasics , Newegg generics 6' to 12' they all are inexpensive and work fine .
tubetwister is offline
post #17 of 50 Old 10-05-2014, 12:20 PM
Liked: 0
Whatever I can find cheap, not brand loyal and have never had an issue...
adeehr is offline
post #18 of 50 Old 11-18-2015, 04:32 AM
Liked: 0
Most of the cheap ones are very good. I have a bunch of eBay ones that work perfect.
Jonnypro16 is offline
post #19 of 50 Old 12-04-2015, 05:21 AM
Bill97Z's Avatar
Quoted: 79 Post(s)
I have been using mediabridge ultra from amazon. I tried amazon basics cables (3 pack) and two were bad. I started experiencing pink and purple color casts (BAD) on my TV and thought it was the set, but replacing the cables fixed it.
GrandPixel likes this.
Bill97Z is offline
post #20 of 50 Old 12-04-2015, 05:29 AM
luisev's Avatar
Quoted: 189 Post(s)
Liked: 100
Monoprice Redmere to my projector and Belden Bonded Pair from Bluejeans Cable for everything else.
DIYSG 893 | Emotiva ERD-1 | DIY 18" Sub
Emotiva XMC-1 | XPA-2 | XPA-5 | Crown XLS 2502
Samsung 58" Plasma | BenQ HT1075 100" Screen
Amazon Fire TV with Kodi | Oppo BDP-103 Bluray Player
Mogami and Blue Jeans Cables
ATS and DIY Acoustic Panels
luisev is offline
post #21 of 50 Old 12-04-2015, 05:30 AM
Quoted: 663 Post(s)
Liked: 282
amazon mediabridge 3', 5' 10'
TV- Samsung 55" UHD (UN55JU6500FXZA)
service - directv
Receiver - Denon AVR-X2100W,
Speakers -F L/R - Infinity Primus P363, C - Infinity Primus PC351
Sub - Klipsch Sub-12HG
(slow build out)
mdram is offline
post #22 of 50 Old 12-04-2015, 08:47 AM
Quoted: 23 Post(s)
Liked: 5
+1 monoprice
sweets1 is offline
post #23 of 50 Old 04-16-2016, 08:51 AM
ELECTRICDON's Avatar
I only use Audioquest
ELECTRICDON is offline
post #24 of 50 Old 04-20-2016, 05:01 AM
Quoted: 663 Post(s)
Liked: 282
amazon
service - directv
(slow build out)
mdram is offline
post #25 of 50 Old 04-21-2016, 12:24 PM
Liked: 0
Amazon as well.
rajivhifi is offline
post #26 of 50 Old 04-23-2016, 10:45 PM
Liked: 1
I've used Monoprice HDMI cables for years and they still remain the only place I buy HDMI cables from. I'm sure other places have good quality for the price, but I have found their cables to be fantastic quality at great prices with very good customer service to boot. Any time I've had to talk to their support staff, they've fixed any issue I've had quickly and with little to no effort on my part. I recommend them to anybody who asks.
stufio is offline
post #27 of 50 Old 05-04-2016, 10:49 AM
GrandPixel's Avatar
Quoted: 164 Post(s)
Liked: 44
I got a variety of lengths of thin (flexible) and cheap hdmi cables from ebay a while back. They work fine and it's handy to have some extras for various purposes. I also purchased 30' and 50' RedMere cables (Cabernet Ultra series) from monoprice a while back during 40% off! sale - excellent deal! I intend to use them when I set up theater at my new place this Summer. Equipment will be in a closet at back of room, so 30' is to projector, 50' is to TV at front of room. I used the 30' one for an outdoor movie, worked great! Also they are both 18Gbps, so 4k60 capable.
GrandPixel is offline
post #28 of 50 Old 05-09-2016, 01:09 PM
Otto Pylot's Avatar
Liked: 1020
Unless the cables are certified by an ATC for a given length at 18Gbps there is no guarantee that you will get 4k, 4:4:4 @60Hz over about 15' - 20' unless they are 26AWG or thicker. And even then, there's no guarantee. The cable is probably listed as "up to 18Gbps".
post #29 of 50 Old 05-09-2016, 01:49 PM
GrandPixel's Avatar
Quoted: 164 Post(s)
Liked: 44
These are active cables with RedMere, and yes they are claiming 18Gbps for cables up to 50'.
http://www.monoprice.com/product?p_id=12962
post #30 of 50 Old 05-09-2016, 02:58 PM
Otto Pylot's Avatar
Liked: 1020
There is nothing magical about cables with Redmere technology. They just draw a little power from the sink end to extend the HDMI signal longer than 25' using proprietary chipsets to ensure signal integrity and timing. However, at long lengths some Redmere cables do not have the updated chipsets in them so they have issues with the video protocols that require the higher bandwidths. Just be aware of that in case you start to develop issues. They may claim bandwidths up to 18Gbps at 50' but I'd be surprised if it comes with a certificate of compliance for a 50' cable that has been tested for 4k, 4:4:4 @60Hz following ATC testing protocols.
Reply Game Room Equipment & Accessories
