Nespresso? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-13-2017, 08:14 AM - Thread Starter
gizzygone's Avatar
Quoted: 71 Post(s)
Nespresso?
I'm looking to add an espresso machine to my basement project.
I'm thinking Nespresso is the way to go... seeing as it'll only be used occasionally.
I'm wondering if anybody here has one? And if so, can you comment on it? I'm truly curious to see if my money is better spent on the Vertuoline or Original lines...
gizzygone is offline
post #2 of 2 Old 03-25-2017, 11:12 AM
greg_mitch's Avatar
If you want espresso, just get the original line. Cheaper and smaller coffee pods. The machine is really small. Can make a quick cup of espresso. If you want latte or cappuccino, then just get their Aeroccino and keep some half and half in the fridge. Works well and smells great.
I have both original and Vertuoline, a commercial Keurig, Chemex, Aeropress, and a normal Mr. Coffee. The original line Nespresso machine gets the most use with Chemex being 2nd.
greg_mitch is online now
Reply Game Room Equipment & Accessories
