Dart Board + Backing Recomendations? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-13-2017, 07:41 AM - Thread Starter
ChadS13TDI's Avatar
Quoted: 55 Post(s)
I am looking for a nice dartboard. I am leaning towards electric that has the built in games since myself and anyone playing are total amateurs.
Also what are people using to back them to protect the surrounding walls? I have searched a few other threads and seen various things. MDF with cork seems to be common. I am looking for something that looks professional with as clean a look as possible.
What do you guys/gals suggest?
Basement Theater/Rec Build 2.0 - http://www.avsforum.com/forum/15-gen...ng-advice.html
ChadS13TDI is offline
post #2 of 5 Old 08-30-2017, 02:24 PM
whumpf's Avatar
I used this http://www.homedepot.com/p/Heritage-...1003/204602282. Looks great.
whumpf is offline
post #3 of 5 Old 08-30-2017, 05:54 PM - Thread Starter
ChadS13TDI's Avatar
Quoted: 55 Post(s)
Originally Posted by whumpf View Post
1/8" seems like it's not thick enough? Looks nice though.
post #4 of 5 Old 08-30-2017, 08:16 PM
whumpf's Avatar
I guess it depends what your goals are. I have it adhered directly to drywall. You can’t see holes from more than a foot or so, and even then hard to see.
whumpf is offline
post #5 of 5 Old 09-01-2017, 07:11 AM
Liked: 0
GranBoard or Darts Connect. GranBoard is a little more expensive, but looks a little nicer I think and is a little higher quality. Both are designed to hook up to wifi and run through an app on phone or tablet and can be chromecasted to a TV. They are both online boards where you can play against other people that have the same board.
DaveInMinn is offline
Reply Game Room Equipment & Accessories
