Bar plans? - Page 12 - AVS Forum | Home Theater Discussions And Reviews
post #331 of 860 Old 03-09-2008, 10:24 AM
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 282
Not sure, but can you do it in two steps? First a smaller amount on the top to level it - it would pool to the lower area. The second pour would be to complete the top.
Bud
chinadog is offline
post #332 of 860 Old 03-09-2008, 10:24 PM
dlclark's Avatar
http://triplejinlay.com/
This link has a gallery of photos from a custom builder in central, IL. He builds custom bars, poker tables, etc. Notice that he doesn't use stain, the color variance comes from use of different wood species. The bar he made for the Pub II in Normal, IL is really something. Probably not a DIY project but maybe inspiration for someone.
dlclark is offline
post #333 of 860 Old 03-10-2008, 06:52 AM
cjrivera's Avatar
Ahhh... the Pub II. Maybe I never noticed the bar there because I was too busy scarfing down all their famous cheese balls. Good times, good times.
cjrivera is offline
post #334 of 860 Old 03-13-2008, 12:50 PM
calmman's Avatar
I went to quite a few sites for ideas, and one I believe is called barplans.com.
<a href="http://www.scentorama.com">The Perfume</a>
<a href="http://www.emdrugs.com">Natural Diet</a>
calmman is offline
post #335 of 860 Old 03-13-2008, 01:30 PM
str1der's Avatar
Quoted: 28 Post(s)
I wish I could find some plans that use premade cabinets in their plans. I'm sure I can eventually figure something out but it would be nice to see something to start with.
str1der is offline
post #336 of 860 Old 03-13-2008, 03:32 PM
Capy235's Avatar
If your bar is not fastened to the floor you can use common wood wedges available at any home center to create a level before you pour. My bar is 10' on the front and a 6' return on one end and that is my plan when the time comes. Good luck and let us know how it come out.
Capy235 is offline
post #337 of 860 Old 03-13-2008, 04:41 PM
HeyNow^'s Avatar
wow...there are a lot of folks on here that have finished their bars and chronicaled how they did it with cabinets....Irmo, Bud (chinadAWG)(Chinadog), many others. Plans, smans....get creative bro!....
HeyNow^ is offline
post #338 of 860 Old 03-14-2008, 10:05 AM
IrmoGamecoq's Avatar
Yep, Randy's right, I used pre-built cabs on my bar, both for underneath and hanging back behind it.
IrmoGamecoq is offline
post #339 of 860 Old 03-14-2008, 11:05 AM
str1der's Avatar
Quoted: 28 Post(s)
Do you have any pics? This thread is getting kind of big.
str1der is offline
post #340 of 860 Old 03-17-2008, 10:22 AM
str1der's Avatar
Quoted: 28 Post(s)
Does this bar belong to anyone on this board? It's almost exactly what I was looking to build. http://www.electronichouse.com/slide...egory/3192/566
str1der is offline
post #341 of 860 Old 03-17-2008, 10:36 AM
Do a search on my userID for threads started...I don't start many threads so you won't have to look far. Good luck!
post #342 of 860 Old 03-17-2008, 10:37 AM
rmcveigh's Avatar
That's Bud's (chinadog) bar! Bud, I didn't know you made Electronic House. Cool!
-Ryan
rmcveigh is offline
post #343 of 860 Old 03-17-2008, 10:37 AM
HeyNow^'s Avatar
Chinadog. Look under Blazing Ridge Cinema in the Theater build forum.
HeyNow^ is offline
post #344 of 860 Old 03-17-2008, 10:55 AM
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 282
Yes, it got added just today. The person actually wrote the article a while back and it just went out. I forgot it was coming with all the stuff going on in the ATL over the weekend.
Bud
chinadog is offline
post #345 of 860 Old 03-17-2008, 11:33 AM
str1der's Avatar
Quoted: 28 Post(s)
None of your pics show up in the thread.
str1der is offline
post #346 of 860 Old 03-17-2008, 11:42 AM
Okay, sorry about that. Not sure what's up with it then.
Can anybody else see the pics in the thread below?
http://www.avsforum.com/avs-vb/showthread.php?t=891879
Imagestation migrated to Shutterfly awhile back, but the links were supposed to still be valid...
post #347 of 860 Old 03-17-2008, 11:56 AM
HeyNow^'s Avatar
Maybe He/she is being blocked from work...like me
HeyNow^ is offline
post #348 of 860 Old 03-17-2008, 12:06 PM
Which is exactly why I can't verify if the links are good either.
post #349 of 860 Old 03-17-2008, 01:34 PM
str1der's Avatar
Quoted: 28 Post(s)
Nope He isn't being blocked. The links don't work.
str1der is offline
post #350 of 860 Old 03-17-2008, 04:43 PM
HeyNow^'s Avatar
Irmo,
No worky from homey either!
HeyNow^ is offline
post #351 of 860 Old 03-17-2008, 05:17 PM
johnny15's Avatar
Quick question for anyone:
Has anyone tried using the envirotex lite on a bar top that has been tiled?? I think it would be neat to use a slate for a bar top, but because of the very rough and uneven texture that usually accompanies slate, it wouldn't be the best surface for setting beer & wine glasses and other things.
Any ideas?
johnny15 is offline
post #352 of 860 Old 03-18-2008, 03:07 AM
malbols's Avatar
I plan on putting ribbed black rubber matt on my bartop , then cover with Envirotex . This stuff is supposed to cover just about anything . I'll let you know how it turns out , should been doing top in another week .
malbols is offline
post #353 of 860 Old 03-18-2008, 06:05 AM
Irmo,
Dang it, guess I gotta update those links then. Thanks for checking...
post #354 of 860 Old 03-18-2008, 06:08 AM
Any ideas?
I don't see why that wouldn't work. It would be interesting to see what the glossy envirotex does to the color of the tiles...I love how it pulls the color out of my hardwood flooring on my bar.
I would certainly suggest you test it on a seperate tile piece first though. Off your bar obviously. Slate tile is probably pretty porous, so you're likely to get all sorts of bubbles and other irregularities come up after you pour. You may need to seal it with poly first.
Good luck and show us how it turns out.
post #355 of 860 Old 03-19-2008, 08:21 AM
johnny15's Avatar
Yeah, I was planning on testing it before I do it, but I was just wondering if there was anyone that had possibly tried this. Thanks for the suggestion about sealing it with poly first. I didn't think of that, but it makes sense.
johnny15 is offline
post #356 of 860 Old 03-19-2008, 10:50 AM
str1der's Avatar
Quoted: 28 Post(s)
Hey Irmo did you get those pics?
What would you guys say is the minimum space needed on the outside of the bar and a wall? I have an area that's about 10' X 10' with a wall on 3 sides. I'd like to do a corner type bar but not sure how far out I could come and still be comfortable.
str1der is offline
post #357 of 860 Old 03-19-2008, 11:08 AM
elmalloc's Avatar
Quoted: 156 Post(s)
Liked: 92
Irmo?
Projects:
NOT STARTED - Theater (Sim2 HT380, CIH 13ft wide).
IN PROGRESS (10%) - Home LAN (4 PCs).
Game room:
Epson 5040UBE, Denon S920W, Philips BDP7501, NVidia Shield TV, PS4 Pro, SI 110"
elmalloc is offline
post #358 of 860 Old 03-19-2008, 11:09 AM
I probably won't get to fixing those links until the weekend at the soonest, sorry...
As for space on the outside of the bar, I dunno...I hadn't really thought of that before. My concern was the space behind the bar, as I have lots of room outside the bar.
If your space is 10x10 though, I think it would probably look best to go symetrical and have the bar bisect that space right down the middle. But that really depends on whether you plan to have a back-counter behind your bar, which will eat up 2' feet of your back-bar space. You won't be able to split your 10x10 space if you do that.
One good suggestion I saw on here (I think it was Sdallnct that did it) was to use painter's tape and mark out your dimensions on the floor. You can get a good feel for the spatial relations that way, and if you want to go even farther, use cardboard boxes to fill in the spaces for the bar, cabinets, etc.
post #359 of 860 Old 03-19-2008, 11:16 AM
elmalloc's Avatar
Quoted: 156 Post(s)
Liked: 92
yes good advice
Projects:
Game room:
elmalloc is offline
post #360 of 860 Old 03-19-2008, 11:33 AM
str1der's Avatar
Quoted: 28 Post(s)
Yes I was planning on doing some mock ups but was just sitting here trying to draw it out on some graph paper. The area is basically like a 10' X 10' square with one corner missing so that's where you would enter
str1der is offline
Reply Game Room Equipment & Accessories
Basement Bar
