Touch screen software - AVS Forum | Home Theater Discussions And Reviews
post #1 of 39 Old 09-14-2005, 01:31 PM - Thread Starter
tywest's Avatar
Im looking for software that would be equivalent to the games you would find on a "megatouch" video game. I recently obtained a touch screen for one of my old pc's. Has anyone ever heard of such software? Also, does anyone have a recommendation on touch screen jukebox software. It would need to play mp3,etc. Thanks
tywest is offline
post #2 of 39 Old 09-15-2005, 01:20 PM
crackity's Avatar
darn, have been watching this thread hoping someone would reply with some amazing news
I posted a similar thread a while back and pretty much came to the conclusion that I am going to have to just get a used megatouch and scrap the idea of having a bartop jukebox (although I REALLY like this idea)...... if only it was possible to get the best of both worlds..... well you can get a touchtunes thing (megatunes?) for megatouches but it will only control the main touchtunes jukebox, so not exactly what I would want.
Photohunt being my fav, I found a couple of stand alone apps that wer epretty cool. 1 had the exact same fullscreen feel while the other had a windows feel to it. Unfortunately the fullscreen one sucks as it doesnt have a large picture database and is not upgradable.... the windows one kicks its but in this respect.... I forget the names off the top of my head... if you want them, let me know.
I toyed with the idea of getting a bunch of stan alone games and making a menu based thign for them but I think it would be a little hookie with a common theme not going throughout and am curious if I would be stuck with the mouse following your finger presses around....
as for jukebox software, I toyed around with a lot of them a yer or so ago and I think I really liked JRIvers jMedia Center.... I think it only busted because it had incompatibiliity with a couple of my mp3s. Dont know if this is good for a touchscreen though as you would want there to be a keyboard tpye thing somewhere to be able to find songs that way.
So megatouch shopping it is..... anyhow if you manage to find some cool software, please post here ot PM me.... that would be awesome
crackity is offline
post #3 of 39 Old 09-16-2005, 05:56 PM
tcrandal's Avatar
Quoted: 13 Post(s)
Mainlobby seems to have the capability of doing many of the things you are seeking. Although I haven't used it in-depth yet, I'm looking into for a similar purpose.
tcrandal is offline
post #4 of 39 Old 09-19-2005, 10:38 PM - Thread Starter
tywest's Avatar
I haven't checked back since my first post. Thanks for the info... I did find one nice jukebox program.
www.thepcjukebox.com This seems to be the nicest one so far. Their website seems to be down at the moment, but it's nice.
I should be getting my 15" Elo screen soon. I plan on wall mounting it inside of a frame. I will be sure to post pic's when im done.
The hunt for touch screen games/software continues..
I checked out mainlobby. Do i need to get Homeseer for it to work? Im not planning on controlling any home automation stuff with it. I just like the idea of a home kiosk where only a limited no. of programs can be accessed easily on the screen.
tywest is offline
post #5 of 39 Old 09-21-2005, 08:08 PM
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 125
tywest,
You do not need HomeSeer to run MainLobby.
You could either build a touchscreen to launch your applications using MainLobby. Also, another option is to use DVDLobby to build an interactive game guide. Selecting a cover for the game (in place of a dvd cover) may fulfill your requirements.
Not sure which format the games are in. If you can double click on a file and have the program launch using windows explorer, then it shouldn[t be a problem at all to launch it from Mainlobby.
Hope this helps.
mcascio is offline
post #6 of 39 Old 10-02-2005, 07:49 PM - Thread Starter
tywest's Avatar
http://www.downloadatoz.com/criticalseeker/index.html
I didnt try it yet but it looks nice.
tywest is offline
post #7 of 39 Old 10-03-2005, 02:19 PM
crackity's Avatar
I looked into it about a month ago..... this is the best of the photohunt type games i could find but it has its drawbacks:
- No full screen "arcade" option
- its "clues" are nothing like standard photo hunt in that they dont give you a mismatch but instead stop time, zoom in an area of the screen, etc
what I really like about it;
has TONS of images, different levels of hardness, etc
same images with different differences
http://www.ronmarie.com/spotdiff2.html is dead on like photohunt, ful screen arcade mode, same hint system, etc but they are severly lacking in image base (and no sign of them caring to add more) kills it for me. When I just demoed the game, I was alredy running into duplicates which is a big big big turnoff.....
crackity is offline
post #8 of 39 Old 03-04-2006, 09:43 PM
thajenius's Avatar
Hello, I am also seeking some quality jukebox software. So far the best ive found is this...
I guess i cant post a URL yet. Google for a program called Nordbeats Jukebox
I have a 17" ELO LCD panel and it works great. I Just have to break down and buy the software. Ive been hoping that i would find something just as good, only cheaper.
thajenius is offline
post #9 of 39 Old 03-13-2006, 08:17 PM
klindy's Avatar
I've been using Xlobby for a while and haven't had any trouble. Best part is it's free!
Great flexibility and several precanned screen choices too.
Keith
klindy is offline
post #10 of 39 Old 04-10-2006, 09:02 PM
thajenius's Avatar
Ive completed my console radio to digital jukebox project. After trying many applications I did decide to go with Nordbeats Jukebox.
post #11 of 39 Old 05-25-2006, 09:43 PM
JohnWPB's Avatar
I think The Pc Jukebox is what you are looking for. It looks like the Bose systems you see in the bars. It replicates the High End jukeboxes you see in the bars.
You can check them out at ThePCJukebox d0t c0m
I have been using it for a couple years now, and am very happy with it. It does take a while to start-up, but once started it works well. Not a problem for me, as I leave that computer with the jukebox running all the time.
JohnWPB is offline
post #12 of 39 Old 07-08-2006, 07:01 AM
thajenius's Avatar
Jukebox Duex,
I made another smaller jukebox for bar night at the inlaws, I used Nordbeats on this one, but I may try out Freebox on it also.
post #13 of 39 Old 07-17-2006, 02:52 PM
silvershark9's Avatar
I was reading some things you guys mentioned on the software for touch screens. But i was wondering about some touch screens you recommend for under $300. Give me some examples that would be great. And it would be dedicated to only song selection probably.
silvershark9 is offline
post #14 of 39 Old 07-20-2006, 08:20 AM
mbartenhagen's Avatar
I would also be interested in more information on touchscreens. Can someone tell me if this would be possible:
I have a booth in my basement and am having a table built that will have a place to put a TV\\LCD on the end against the wall. A 15 to 17 inch model will probably work best, not so big that it looks obnoxious and not so small that you can't see it. The ultimate solution for me would be an widescreen LCD that had an onboard tuner but was also a touchscreen moinitor. Basically something that would be a TV but switching to input 1 (or whatever it was) would allow it to be a moinitor for a MCE extender or small form factor computer.
Does something like this exist? I realize I could use a computer and LCD monitor to do all of this but would prefer and onboard tuner for ease of use.
Mike
mbartenhagen is offline
post #15 of 39 Old 07-28-2006, 07:22 PM
jdolby's Avatar
I have a Compaq TFT5010 touchscreen monitor and can't find the software to make it work. Yes, I tried Hp/Compaq site and searched google. Any help would be appriciated. I am using Touchtone audio systems demo right now. Pretty good.
JD
jdolby is offline
post #16 of 39 Old 08-01-2006, 12:23 PM
Rupert's Avatar
JD
I couldn't find a reference on the HP web site describing which touchscreen software they use, but I did see one reference to MicroTouch, so that may be what you need. Can't hurt to try:
http://solutions.3m.com/wps/portal/3.../TouchDrivers/
Rupert is offline
post #17 of 39 Old 09-11-2006, 02:00 PM
chrismd77's Avatar
I have a number of Touch Screen monitors. I currently have one 19 inch (Elo Touch Screen), two 15 inch (Planar Touch Screens) and one 12 inch (Elo Touch Screen). The 15 inch and 12 monitors are mounted in the wall. I took apart the plastic housing and custom mounted them in various locations around the house. They are used in conjunction with my home automation software. All of the screens are controlled via a serial connection but USB is also available. The best thing about them is they are extremely easy to set up and I got them off of Ebay for a very good price.
The 19 inch monitor will be located in the basement at the bar, when I get around to working on it It will run the home automation software which controls all video and audio through the house and I am hoping to build some sort of MegaTouch to work with the monitor too. I have been watching this tread hoping someone would post a report of the software being available for a PC. I am going to start to buy the hardware to build my own MegaTouch and I will use my 19 inch monitor as the screen. I will keep everyone posted.
Chris
chrismd77 is offline
post #18 of 39 Old 10-02-2006, 08:04 PM
goobenet's Avatar
JD
It's more than likely Elo. Most touchscreens are either modified by Elo directly, or are "elo compliant". Try their drivers.
goobenet is offline
post #19 of 39 Old 01-05-2007, 08:18 PM
Naborneo's Avatar
So i'm in a bind with my Mega Touch, I sold it on eBay and when the guy received it, something involving smoke and what not...kinda sucks, now have a $1000 paper weight, so UPS sent it back today saying even though I had it insured they will not pay for the fact that in-between shipping it and receiving it the box was crushed and went up into smoke. When I received it today, the claims company tor the thing apart, screen was cracked entire case was broken, the back of the monitor was broke off...broken is where i'm going with this. I was looking to repair it because all in all its just a computer...So now that you know the back end of the story. Heres my question, as far as it looks the Hard Drive is still in tact, (not positive but no physical damage could be seen, will plug it in later to my PC to see what comes up) Dose anyone know how these things are run, can I just grab a touch screen off of ebay, put together a micro ATX mother board with this hard drive and vola la? Does anyone know about the BIOS that this mother board would have on it to run it? If anyone knows how to get into it and set it up. I'd be happy to make HD Images of the Mega Touch HD.
So if anyone has got some know how on this please let me know, thanks for your help.
Naborneo is offline
post #20 of 39 Old 04-25-2007, 02:35 PM
webrats's Avatar
software touchscreen etc for the magatouch is easy as long as you have the small circuit board with the key in it. you are golden
webrats is offline
post #21 of 39 Old 04-25-2007, 04:51 PM
CARTERlikesPants's Avatar
Nordbeats looks very nice.
I'll look into that.
CARTERlikesPants is offline
post #22 of 39 Old 05-24-2007, 12:26 PM
justtaint's Avatar
I've been using Freebox for the past 3 months. Barcrest, its designer, updates it quite often and incorporates user requests frequently. I'd recommend it. I think his website is www.freeboxjukebox.com
Tom
justtaint is offline
post #23 of 39 Old 06-04-2007, 03:39 PM
patrickjherbert's Avatar
I'm using Albumplayer (http://www.albumplayer.com/) and although I think it's a little rough importing music in, I very much like the way it works. It will work with either mouse or touchscreen, and I'm currently lurking in eBay hoping to find a deal on a touch monitor to mount on the wall next to my bar.
Having said that, I wish I'd seen this thread before I bought Albumplayer. I'm checking out a couple of the other options for software here and I'm not sure why I didn't get any hits on these while I was researching the whole thing.
patrickjherbert is offline
post #24 of 39 Old 01-17-2008, 10:32 AM
pesw's Avatar
Google for Touchtone. This is by far the best jukebox program I've tried. It's designed with a touchscreen in mind. Great on-screen keyboard etc. mp3touchscreens dot com
Peter
pesw is offline
post #25 of 39 Old 01-17-2008, 03:11 PM
Tony_M's Avatar
Ebay look up touch screens I picked up a used ELO 15 inch LCD flat touch screen for under 200 dollars.
Software was downloaded from ELO's website.
It is all a matter of looking and timing to find something for a good price.
Tony_M is offline
post #26 of 39 Old 01-17-2008, 03:13 PM
Tony_M's Avatar
I am using a program called
Ultimate Jukebox
http://ultimatejukebox.murphnet.net/index.htm
It is designed for a touch screen, and I have a used ELO 15 inch LCD touchscreen driving it.
Tony_M is offline
post #27 of 39 Old 01-20-2008, 02:41 PM
gscott69's Avatar
I use SKJukebox. I think it will work well with a touch screen. It has an on-screen keyboard. It can be found at http://www.skjukebox.info/
gscott69 is offline
post #28 of 39 Old 01-23-2008, 12:39 PM
charlie3133's Avatar
So this is why this forum is just so good.I had never even thought about having a pc jukebox never mind one with a touch screen, but this would fit into my bar area a dream.
So just to clarify
I need a pretty low spec pc but with lots of space for music files
A sound card
A touchscreen (possibly refurbished from ebay)
Some software such as what you have described in this post
And away I go???
sounds almost too easy. Did I miss anything?
I do have one obvious question though with regard to speakers
I want this in a fairly small place and its going to be used for background music only rather that sitting down and 'listening' to it ,so I don't need lots and lots of power or audiophile reproduction.
So to keep cost (and space requirements down) would it be best to try out some decent PC speakers?
If I did go with traditional speakers how would I get the PC connected to them. With a receiver?
charlie3133 is offline
post #29 of 39 Old 01-23-2008, 01:04 PM
Tedd's Avatar
Quoted: 1149 Post(s)
Liked: 439
Could be a lot simpler, and cheaper, for your needs....
DOS 6, MPXF and MPXPlay software and a 2 or 4 line character based lcd or vfd display.
Or if linux is your style: http://www.anders.com/projects/route66/
Dig out the old Pentium system.
Tedd is online now
post #30 of 39 Old 01-23-2008, 02:15 PM
Reply Game Room Equipment & Accessories
