DIY Shuffleboard - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 78 Old 06-22-2008, 10:35 PM
Cameron's Avatar
That looks so cool. I want one, but I have never played shuffleboard.
I had better not try it, I would then need one and that is where the trouble begins!
-- Well I have really blown my budget now. --
Cameron is offline
post #62 of 78 Old 06-23-2008, 09:27 AM
elmalloc's Avatar
Quoted: 173 Post(s)
Liked: 105
I have played only 20 minutes, I have to adjust it with a wrench. a 3/4" wrench does not fit it...
I will let ya'll know after I get it adjusted. Oh funk, I thought these things should have only been 1K...
Projects:
NOT STARTED - Theater (Sim2 HT380, CIH 13ft wide).
IN PROGRESS (10%) - Home LAN (4 PCs).
Game room:
Epson 5040UBE, Denon S920W, Philips BDP7501, NVidia Shield TV, PS4 Pro, SI 110"
elmalloc is offline
post #63 of 78 Old 06-16-2010, 10:09 PM
jdubya123's Avatar
Hey~ I'm trying to build a couple economy level shuffleboard tables for our student center. There is a real interest in playing but I can't afford to go out and get a couple nice tables. I found this epoxy at Lowes, has anyone used it, or do you guys think it would work. Here's the link
w.eclecticproducts.com/glazecoat.htm
If not what works best...thanks for your help!
Sorry for dropping the first 2 w's in the link, it wouldn't let me post the url yet since I just signed up....
jdubya123 is offline
post #64 of 78 Old 03-01-2011, 03:39 PM
garv3's Avatar
hey...anybody still on this thread??? i'm looking to build a table, but my main question is how is the playing surface mounted/attached to the cradle surface itself??? and where do the climate adjusters come in???
garv3 is offline
post #65 of 78 Old 06-03-2011, 12:22 PM
peterj0hnson's Avatar
If any one is still on this, im currently under construction of my own table. I made the playing surface out of 20 1x3x10 maple boards, glued together and planed. I have just finished painting it as you can see in the photos, and I am just about to coat it with a 2 part hi gloss polymer.
Specific question for MercerT if he still exists on here. You said the moat you made around the first table when you poured the poly made a ridge. Is it better to just pour the poly on and let it trickle off the sides? I am worried that the edges will be slanted down and the pucks with fall of easier.
peterj0hnson is offline
post #66 of 78 Old 06-26-2011, 06:01 PM
elmalloc's Avatar
Quoted: 173 Post(s)
Liked: 105
Looks great, if it comes out well Ill ask you to make me one for $999 OK
Projects:
Game room:
elmalloc is offline
post #67 of 78 Old 06-27-2011, 12:47 PM
hotloc5's Avatar
I just finished a shuffleboard / curling table myself. Got a lot of guidance from Dave's website.
I documented the process with pics. If you're a beginner like me, it may be helpful.
buildashuffleboard.com
-Patrick
hotloc5 is offline
post #68 of 78 Old 06-30-2011, 02:18 PM
elmalloc's Avatar
Quoted: 173 Post(s)
Liked: 105
how much did it cost you, and what are the boards dimensions including thickness?
Projects:
Game room:
elmalloc is offline
post #69 of 78 Old 07-24-2011, 07:40 PM
hotloc5's Avatar
The project-specific materials cost me $495. I also had to buy all the tools, because this was my first project. With everything it came in at $837.
Dimensions for the playing surface on my board are 16 feet by 20 inches. Full details of the dimensions, blueprints, pictures, etc. are here: http://buildashuffleboard.com.
Let me know if you have any other questions. Good luck if you decide to give it a try!
-Patrick
hotloc5 is offline
post #70 of 78 Old 08-04-2013, 08:01 AM
scottyk's Avatar
Hello...I am really hoping the OP is still on here...
I am currently working on my own shuffleboard, and admittedly am a beginner to this sort of thing.
Here is my issue:
How is the playing surface secured to the structure? From everything I've seen/read, it seems like people are just having them "float", without actually securing them at all. My table is only 8 foot, so it seems like it would move around if somebody bumped it or leaned on it?
Can someone please off some advice here? I thought about using a few dowell pegs to help secure it down. However, being such a beginner, I am worried that I will screw up the entire playing surface.
HELP!
scottyk is offline
post #71 of 78 Old 08-23-2013, 02:24 PM
Vanderloop's Avatar
My 15' table built from an old bowling alley.
Vanderloop is offline
post #72 of 78 Old 08-23-2013, 02:26 PM
Vanderloop's Avatar
and the behind the bar shot
post #73 of 78 Old 08-27-2013, 08:28 PM
t-town oil's Avatar
Sweet!
t-town oil is offline
post #74 of 78 Old 06-18-2015, 06:48 PM
Liked: 0
I'm trying to bring this thread back from the dead. I just bought some bowling alley wood to make a table and am looking of any advice on the best way to build a table from it. Vanderloop your table looks great! Can you tell me how you put the 2 pieces of bowling alley wood back together? Also can you give me any hints/ideas that might help me create my table. I am quite a novice with wood working so any advice would be appreciated. Thanks in advance for everyone's help.
JoePit is offline
post #75 of 78 Old 02-10-2016, 02:28 PM
Liked: 0
Originally Posted by mercert View Post
sorry for the late posting I have been real busy!
update to my shuffleboard project:
I found that building a "dam" for the resin to "level" in was a mistake, it created a ridge that i had to sand to remove. It was like having a "bumper" to keep the pucks on the table. Lesson learned. I have since remodeled my messy garage and finally built a complete woodshop (Ka ching $$$) and have now embarked on building custom shuffleboard tables. I have refined all my processes and documented all my designs (being a retired mechanical engineer thats what we do!) so now i am off and running building my first production shuffleboard table. I will post pics of it as soon as I am able. in the mean time here are a couple of my final prototype table which plays great and has stayed consistant and level since i finished it in January.
As far as using anything other than hardwood laminated together for a playing surface, I personally would rather spend the extra money and time and make it to last and be consistant than to save time and money and end up with a less than good playing surface. I built my first surface using 1x2 home depot select pine figuring i would toss it after refining the processes needed but it is still true and straight because I used 12 pipe clamps to glue it up on a level surface and then planed it smooth and then on a VERY level surface covered it with envirotex 2 part poly resin and I have climate adjustment on the cradle to keep it that way.
Do you mind sharing what you have found to be the best way to use the resin? I realize this thread is about 9 years old, but I'm hoping you can help. I'm in the middle of a table refurbish and I want to do it right. Thanks!
ldo2626 is offline
post #76 of 78 Old 03-10-2016, 02:58 PM
jonnyphoto1's Avatar
Liked: 1
Really nice job on the build!
jonnyphoto1 is offline
post #77 of 78 Old 02-15-2017, 02:07 PM
mastermaybe's Avatar
Quoted: 435 Post(s)
Liked: 344
another thread revival!
Finished mine. I basically did everything myself. Sketched my logos and sent them to a decal guy who did a good job with them, I think. Made my scorers out of toy car hobby wheels and thread spools.
Regarding mounting the board and leveling/climatic adjustments...
My table is about 10' with a 9' playing surface. I used (6) hangar bolts that screw into the cradle and (literally) BITE into the underside of the maple- it DOES NOT MOVE. I can easily adjust the bolts by screwing/unscrewing the bolts from below the board's surface (mine is about 2" raised off the cradle bottom).
For climatic adjusters, I made my own. Got four lenghts of rectangular/tubular steel just short of the width of the table. Drilled three holes to accept some 2" bolts: one a 1/2" from either end, one dead middle. Adjusters went a foot from either end and then about 2 1/2 towards the center from there.
I sunk 3 threaded bolt receivers into the underside of playing surface to receive said bolts for the four adjusters. Then, I added the bolts and nuts- a nut on underside and top of the tubular steel. Onward, making sure I started all 3 nuts even, top and bottom, I made adjustments by tightening either the bottom or top nut of the MIDDLE bolt.
Tightening the top nut "pushes the center up, as the screw doesn't rotate and the tubular steel wants to flex back or UP. Tightening the bottom screw draws the middle of the board DOWN, as the nut is drawing up, while the screw is stationary, thus, drawing the board DOWN when the steel length wants to flex back down to its natural state.
Wanted to explain that for people as adjusters are hundreds of dollars and one can easily do this themselves. It took a bit of thought but it works.
Pics:
thanks
James
My Parlor and Theatre: "Jimbo's Dugout" : http://www.avsforum.com/forum/15-gen...re-parlor.html
Actual phone call (see pic to left):
 Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
post #78 of 78 Old 02-22-2017, 11:15 AM
Hamermaster's Avatar
I built one a few years ago;
Hamermaster is offline
Reply Game Room Equipment & Accessories
