? Pool table in 13'6" long room? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-10-2007, 01:15 PM - Thread Starter
sarkleshark's Avatar
Is there any pool table/que combo that will work in a 13.5 foot long space length wise.
Width is not a problem as one side is open but I cannot orientate the table in that direction.
thanks
sarkleshark is offline
post #2 of 8 Old 01-10-2007, 10:04 PM
pingone's Avatar
go here http://www.ornerbilliards.com/ and check out the dimension chart.
pingone is offline
post #3 of 8 Old 02-09-2007, 06:29 AM
buckrogers71's Avatar
you could get a bar table. most of those are about 7' long. According to the previous posters website, they recommend 5' on all sides. What I would do is marki out a 7' table w/ masking tape and then get a cue or something that you could manipulate to the different size cues and see how that feels.
You may just have to use a shorter cue.
I found this if you are interested.
http://www6.mailordercentral.com/bum....asp?dept=1035
buckrogers71 is offline
post #4 of 8 Old 02-12-2007, 01:48 PM
i70x7's Avatar
I just had a pool table installed and 60" is the bare minimum distance on all sides in order to use a full length stick. One small portion of my table doesn't have a full 60" clearance so I just bought a shorty stick for those situations.
i70x7 is offline
post #5 of 8 Old 02-15-2007, 12:41 PM
bane1202's Avatar
I had a friend try and put a bar table in a similarly sized room... 3 or 4 cue sized holes in the sheetrock later he decided it was a bad idea... particularly if kids will be playing on it or semi-intoxicated or inexperienced people.. if its just you and your buddies or something it could probably be done reasonably well.. 13-6 is a good sized room
bane1202 is offline
post #6 of 8 Old 02-15-2007, 07:14 PM
fuzzatch's Avatar
I would say no.
Nothing is more frustrating when playing pool then having to wory about hitting the walls as this will realy mess up your stroke. Even with a 7' bar table you will only have around 3' front and back to work with. I have a room almost 17' to a corner and I am still worried about having ample room when playing when I get an 8' table.
fuzzatch is offline
post #7 of 8 Old 02-18-2007, 08:46 AM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 488
Reminds me of that Seinfeld episode where Frank Costanza turned George's bedroom into "The Place To Be" by putting the pool table in it...
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
post #8 of 8 Old 02-18-2007, 11:47 AM
Fronk!'s Avatar
Help...
Fronk! is offline
Reply Game Room Equipment & Accessories
