Table top arcade????? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-14-2007, 10:43 PM - Thread Starter
shamus's Avatar
Quoted: 23 Post(s)
Im interested in getting one of these. I did a little searching and they appear to start at $2000.00!!!! Any thing cheaper out there?
shamus is offline
post #2 of 8 Old 01-15-2007, 11:14 PM
dennisgg's Avatar
Good ole ebay:
Item number: 290072004415
Enjoy!
Dennis
dennisgg is offline
post #3 of 8 Old 01-16-2007, 01:29 AM - Thread Starter
shamus's Avatar
Quoted: 23 Post(s)
Originally Posted by dennisgg View Post
Good ole ebay:
Enjoy!
Dennis
Thanks Dennis, but I actually meant the arcade where you sit down and look down into it? Its basically a table with an arcade built into it. I havent seen one in ages but remember playing them when I was a kid. Maybe its not called tabletop but something else????
Thanks again.
shamus is offline
post #4 of 8 Old 01-16-2007, 01:48 AM
alinski's Avatar
They are usually referred to as cocktail table video arcade games. I remember playing Ms Pac-Man and Galaga on these a long time ago.
alinski..
alinski is offline
post #5 of 8 Old 01-16-2007, 06:51 AM
MikeN's Avatar
Build your own... research MAME
Mike Napurano
MikeN is offline
post #6 of 8 Old 01-16-2007, 03:31 PM
top1percent's Avatar
I've got one I just put a new board into. It was a Magic Sword game, but I converted it into a 48-in-1 Multicade. It now plays Ms. Pac, Galaga, Frogger, PacMan, Dig Dug, Gyruss, Burgertime, Centipede, Galaxian, Space Invaders and a lot more games. It's really cool. I just ordered the new Mag-Stik Plus joysticks from Ultimarc so I could switch from 4/way (Ms. Pac, Galaga, Pacman, etc..) to 8/way without any disassembly. I wouldn't part with mine for less than $1300.
I also have an original Galaga Upright that I'm considering converting as well.
I've also built a MAME machine in the past that was really cool as well.
If you can find a used Cocktail table with a Jamma Harness then you can build your own. Keep an eye on Ebay!
Cheers,
Brad
top1percent is offline
post #7 of 8 Old 01-16-2007, 10:07 PM - Thread Starter
shamus's Avatar
Quoted: 23 Post(s)
Thanks guys!
shamus is offline
post #8 of 8 Old 01-20-2007, 09:23 PM
jbalicki10's Avatar
You can also buy cocktail kits cheap as well. If you need links let me know.
jbalicki10 is offline
Reply Game Room Equipment & Accessories
