Pool table - AVS Forum | Home Theater Discussions And Reviews
post #1 of 49 Old 03-04-2007, 12:05 PM - Thread Starter
Bradp56's Avatar
I am finishing a room and it will be 13foot 1 by 16foot whatever because the length will be open ended, I will be fine for a 7 foot table but I was curious if anyone had any experience would it be possible to get an 8 foot table?
Bradp56 is offline
post #2 of 49 Old 03-04-2007, 01:49 PM
Seafighter's Avatar
I got mine from american heirloom - ahpooltables.com. Give them a call. They can help with room dimensions etc. After doing a great deal of research they offered the best value. Very well made piece of furniture.
Seafighter is offline
post #3 of 49 Old 03-04-2007, 02:23 PM - Thread Starter
Bradp56's Avatar
I will check into them hopefully i will be able to figure something out.
Bradp56 is offline
post #4 of 49 Old 03-05-2007, 09:13 PM
fuzzatch's Avatar
I have been looking into this also. I have a room that will be 17' to one corner (25' total) and am looking to get an 8' table, but not yet sure (nothing worse than hitting a wall on during your stroke). With roughly16' you could get an 8 footer but you will have to get some shorter cues or you will be hitting the walls. Here is a great size chart that my help you with your decision.
http://www.hotshotscanada.com/cat252_1.htm
fuzzatch is offline
post #5 of 49 Old 03-06-2007, 07:04 PM - Thread Starter
Bradp56's Avatar
Many say it will be fine others say no it wont, 13 ft 1 width would give me 4 and a half feet on each side, and they say you want to have 5 ft but usually when you shoot from the side the cue is angled up giving you more room, I know I am perfect for a 7' foot table but I really want an 8 foot table just wish I could test it before I buy I mean I could buy a 54 or 56 in cues. I just know how frustrating hitting the walls could be.
Bradp56 is offline
post #6 of 49 Old 03-06-2007, 08:58 PM
fuzzatch's Avatar
You could even go down to a 48" cue for when you are hitting strait on at the sides, this way you will have plenty of space. Smallest recommended width with an 8' table and 48" cue is 11'8, leaving you plenty of room, you could probably even be comfortable with a 52" cue.
Call a local table dealer and get some info from them. Maybe they have set up 8 footers in rooms similar to yours.
Also, another great way to test it out is to put tall box at the same position as where your table would be while standing at the sides and try out your stroke to see if you hit anything. Move it around the room to get a feel of how the table would be at all shooting angles. I did this at my old place to see if a table would even be worth getting. It wasn't.
Good luck.
fuzzatch is offline
post #7 of 49 Old 03-07-2007, 06:51 AM
apollo1813's Avatar
Just built a new home and have a combo pool/ht room. My room is 12' x 31'. Obviously length wasn't a problem but I was concerned about the width.
I went ahead and got the 8' standard table. WIth a straight-on shot from a side rail, where the cue ball is within 1/3 table width, I have to use a 42 or 48" cue. Other than that, not problems. In my mind, its a small sacrifice to have the bigger table. Plus, my local retailer only carried the 8' in stock so the 7 would have been a special order with lots of extra costs.
FWIW...I went with a Connelly table...very happy with it so far.
apollo1813 is offline
post #8 of 49 Old 03-07-2007, 05:42 PM - Thread Starter
Bradp56's Avatar
Well I went to my dads today and he has a room size almost identical to mine, he has a 7 foot table and ofcourse the 58 inch cue he had fit fine. So I thought I would measure if it were an 8 foot table the cue was close to the wall if the ball was right on the rail, I know usually you will be lifting the cue when its like that so I did and it still kinda hit. I tried a 56" cue and had no troubles so I am not sure what I want to do, The length of the room I will have is 16' 7 but one side is open ended, I am still not sure what I want to do.
Bradp56 is offline
post #9 of 49 Old 03-08-2007, 08:22 AM
kmeleon's Avatar
My room is 13' 2" for the width of the table, I use full length cues (58"? can't remember off the top of my head) and have a 52" for when you are anywhere closer than 4" or so to the side rail with a straight across shot. I advise you to get the 8' table, its really not bad. Just get one "shortie" cue and you'll be fine. 7' tables in my opinion are just a waste. Most bars are 8' around here so its nice to keep shooting on the same size table.
kmeleon is offline
post #10 of 49 Old 03-08-2007, 06:06 PM - Thread Starter
Bradp56's Avatar
Thank you for your advice, do you know where you can get a 56" cue or 54" So you guys think I should go with 8' I think I may do that because I really want one
Bradp56 is offline
post #11 of 49 Old 03-08-2007, 08:57 PM
fuzzatch's Avatar
You can probably pick up the shorter cues whever you decide to get your table. It is pretty common for table dealers to carry the gear to go with the table.
fuzzatch is offline
post #12 of 49 Old 03-10-2007, 01:38 PM - Thread Starter
Bradp56's Avatar
Does anyone have pictures of their Pool Rooms? Would love to see them.
Bradp56 is offline
post #13 of 49 Old 03-10-2007, 09:50 PM
fuzzatch's Avatar
I've got pictures of my room that will be a pool room in the future. It is currently under construction.
Links to the pics are in my sig.
fuzzatch is offline
post #14 of 49 Old 03-16-2007, 06:26 PM - Thread Starter
Bradp56's Avatar
Anyone else have pics of their rooms.
Bradp56 is offline
post #15 of 49 Old 03-16-2007, 07:38 PM
buckrogers71's Avatar
here's what I got:
I have 2 tv's down there. but its not my HT. Actually I dont even have an HT, just a 50" Sony wega and 5.1 surround sound in my living room.
It does the trick
I'll add some more pics later
buckrogers71 is offline
post #16 of 49 Old 03-16-2007, 09:17 PM - Thread Starter
Bradp56's Avatar
Thanks, I like that room the bar is pretty sweet.
Bradp56 is offline
post #17 of 49 Old 03-17-2007, 01:58 PM
Seafighter's Avatar
Mine has been added to the home theater website below.
post #18 of 49 Old 03-17-2007, 03:57 PM
Chuckwl's Avatar
buckrogers71 your area looks great!!
Chuckwl is offline
post #19 of 49 Old 03-17-2007, 04:10 PM
Thanks Brad and Chuck. Its a lot of fun down there. The only thing that I would really love to do is put a nice size tv down by the wood stove and some surround sound.
Maybe in time.
post #20 of 49 Old 03-17-2007, 07:18 PM - Thread Starter
Bradp56's Avatar
Go with a nice 1080P LCD and Dish Network you wont be dissapointed.
Bradp56 is offline
post #21 of 49 Old 03-17-2007, 07:21 PM - Thread Starter
Bradp56's Avatar
Hey Seafighter what size pool table is that.
Bradp56 is offline
post #22 of 49 Old 03-17-2007, 10:04 PM
just got my azz handed to me from one of my friends as i have a LCD 50" in the LR, a 20" in the bedroom, a 32" in the basement (in place of that 27" CRT) and the 20"CRT in the bar area. Geez!
post #23 of 49 Old 03-18-2007, 06:26 PM - Thread Starter
Bradp56's Avatar
LOL, Did you buy the bar or have it built?
Bradp56 is offline
post #24 of 49 Old 03-18-2007, 06:47 PM
i built the bar.
post #25 of 49 Old 03-18-2007, 08:04 PM - Thread Starter
Bradp56's Avatar
Thats one thing I need to learn to do because I want a bar like that its not too big and not too small, do you have any pics of the inner side of it?
Bradp56 is offline
post #26 of 49 Old 03-19-2007, 05:24 AM
aegisx's Avatar
We have space for a bar, but no water hookups or anything. Not sure I want to setup a bar without those.
aegisx is offline
post #27 of 49 Old 03-19-2007, 04:32 PM
I dont have anything like that, i make due. I am kinda lucky though, my kitchen is right up the stairs from the basement.
post #28 of 49 Old 03-19-2007, 08:32 PM - Thread Starter
Bradp56's Avatar
I would like to have hookups for a sink but I would make due if I couldnt get one.
Bradp56 is offline
post #29 of 49 Old 03-31-2007, 07:17 PM - Thread Starter
Bradp56's Avatar
I went with an 8' I purchased it, it an Olhausen. I cant wait. I bought a 52in cue for insurance.
Bradp56 is offline
post #30 of 49 Old 04-04-2007, 09:18 AM
TAllen01's Avatar
58" is standard for cues these days. You can ususally buy shorter ones at table dealers. Brunswick billiards (maker of tables) has a nice dimension chart on their site. Pics of my room will be up shortly, but I'm not moved in yet, and have ordered a larger table (4.5 x 9) for my room. I made the dimensions to meet the minimum recommended size for such a table (I think it was like 14' 10" x 17' 10", or something like that.
Thomas
TAllen01 is offline
Reply Game Room Equipment & Accessories
