Can I put my CO2 tank in the attic?
2K views 1 reply 2 participants last post by  Jester 2
#1 ·
I want to install a soda fountain machine and wondered if it would be bad to put the CO2 tank in the attic? What about the bag in a box syrups?
Thanks in advance,
NH
#2 ·
I do know that the heat will play havoc with your pressure regulation. See the temp of the CO2 has a direct effect on the pressure. You get it to hot and it can blow the pressure relief valve, and as CO2 is heavier than air it will either escape your vents in your eves or find a way into the house. It also displaces oxygen, so be careful. I don't want to sound alarmist just information for you. This is one of the best websites I have found to explain the soda fountain setup.
http://www.boneville.net/soda/default.htm
Any other questions let me know I am also in the process of setting up my own as well as keg tappers from a pre-mix fountain
Jester2
