Can I take my computers wireless connection and output it w/ a DSL Cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-21-2007, 01:06 PM - Thread Starter
Nitrosoxide's Avatar
I have a 360 and of course it has no wireless reciever. So I was wondering if there was someway I could take my computers wireless connection and feed it to the 360 by way of a DSL cable going from my laptops DSL port to the xbox.
Nitrosoxide is offline
post #2 of 7 Old 10-22-2007, 07:08 AM
GreySkies's Avatar
Quoted: 618 Post(s)
Liked: 432
It might be. I'm assuming that when you say 'computer' that you mean your laptop, and you only have this laptop, correct? And that you're connecting wirelessly somewhere with your laptop, correct?
If this is the case, then you could try this--
1. Connect the 360 to your laptop with a crossover ethernet cable (it must be a crossover cable, not a regular ethernet cable) via the ethernet ports on your laptop and 360 (what you call the DSL ports).
2. Enable internet sharing on the laptop.
I can't help you with any other settings, as they're specific to the OS on your laptop and I've never had the occasion to use internet sharing on a computer.
GreySkies is offline
post #3 of 7 Old 10-22-2007, 07:15 AM
tmnjus's Avatar
I'm a bit confused by your terminology, but yes, you can connect a Cat-5 cable between your laptop and the 360 via the ethernet ports on each. If you do not have a network switch, you would need to get/make a cross-over cable.
Best is what you perceive it to be, not what others tell you it is.
tmnjus is offline
post #4 of 7 Old 10-22-2007, 09:23 AM
reedl's Avatar
From what you are writing, I think you want to use your laptop's wireless connection (it would be helpful to know what kind of wireless internet you are using, BTW), and share that connection with the XboX to allow the XboX to be able to connect to the internet?
Is that correct?
If so, you will either need to enable the internet sharing software on the PC, or get a program like winproxy and install it on the PC to allow the XboX to be able to use the PC's internet connection.
This is something that is not easy to setup, and can open up your laptop to being exposed directly to the internet.
But anyways, please enlighten us on exactly what you are trying to do. Are you trying to connect the XboX to the internet? Are you trying to get files off the PC to the XboX?
As to connecting the xBoX directly to a laptop, many laptops have the ability to connect directly to another computer, and will reverse the transmit and receive pins. So in some cases, a seperate hub/switch is not needed.
Reedl
Check out my theater! My Theater
Here is the Arcade: The Arcade
reedl is offline
post #5 of 7 Old 10-23-2007, 08:14 PM - Thread Starter
So do you think those "crossover" cables are needed. Or can I safely bet that most laptops can "convert" using regular ethernet cables?
post #6 of 7 Old 10-23-2007, 08:35 PM
Chris Ruhl's Avatar
This link is for the PS3 (20GB non-WiFi)... I think this is what you are looking for.
http://boardsus.playstation.com/play...hread.id=10274
http://www.i-hacked.com/content/view/118/62/
Works on mine.
Chris Ruhl is offline
post #7 of 7 Old 10-24-2007, 07:02 AM
GreySkies's Avatar
Quoted: 618 Post(s)
Liked: 432
Depends on your laptop. No laptop that I've owned could auto-sense. My wife's Gateway does (as does my gigabit switch).
Check your documentation (or manufacturer's web site). If you're still unsure, the best bet is to get a crossover cable.
Reply Game Room Equipment & Accessories
