cheapest receiver with Audyssey EQ or other Room Correction - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-29-2012, 04:02 PM - Thread Starter
Subjga's Avatar
Just looking for the cheapest receiver that has room correction software (Audyssey, or whatever Yamaha, Pioneer, Onkyo call theirs).
I'll be using Pioneer bookshelf speakers and an audiosource 12" powered sub.
This setup won't get much use, so I really want to cheap-out on the receiver. I was about to get the Sherwood RX-4105 but then thought it might not be a good idea to not have room correction.
Subjga is offline
post #2 of 9 Old 04-29-2012, 04:32 PM
glangford's Avatar
Quoted: 319 Post(s)
Liked: 255
Google is your friend. I found a yamaha (YPAO is their room correction) for about 350 bucks. A denon 1912 for around 400 with audyssey. I'd look at electronics expo and call them you can probably get close to 30 percent or more of the 549 priced 1912 denon with the xx13 models soon coming out. You might even try some of denon's refurb stores for a deal.
glangford is offline
post #3 of 9 Old 04-29-2012, 04:52 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
check out sites that specialize in refurbs.
accessories4less has an older denon 591 for 229.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #4 of 9 Old 04-29-2012, 07:57 PM
gene c353's Avatar
Quoted: 156 Post(s)
Liked: 114
I think the Pioneer 521/522 is the cheapest new receiver with room correction. The 521's are drying up fast though.
gene c353 is offline
post #5 of 9 Old 04-30-2012, 04:31 PM
afrogt's Avatar
Quoted: 1445 Post(s)
Liked: 984
afrogt is offline
post #6 of 9 Old 05-01-2012, 06:36 AM
BeechTom's Avatar
+1 the Audyssey correction on these Denons outshines the others, especially because it addresses the subwoofer where the others don't. Additionally, at least on the lower level Pioneer's, the room correction seems to be little more than setting speaker distance (my experience with an 821).
BeechTom is offline
post #7 of 9 Old 05-01-2012, 10:04 PM
fatuglyguy's Avatar
Quoted: 339 Post(s)
Liked: 762
the new yamaha RX-V373 has YPAO.
desktop + headphone Sonus faber Toy monitor|REL T Zero|Sony UDA-1|Sony MDR-Z7|Sony MDR-1000X|Audioquest NightHawk
ht Sony A1E 65" OLED|Monitor Audio Silver RX6, RX Centre, RX1|SVS SB-2000|Sony STR-ZA5000ES|Sony UBP-X1000ES|Sonos Connect + Peachtree Audio DAC•iT|Panamax M-5100PM
stereo Sonus faber Olympica II|REL S/5|Teac UD-501|Sony TA-A1ES|Sony SCD-777ES|Sony ST-SA50ES|Sony 43" X800D|Sony UBP-X800|Sonos Connect|Furman Elite-15 PFi
fatuglyguy is online now
post #8 of 9 Old 05-02-2012, 10:54 AM
Jimmy_R's Avatar
I'm looking at the Onkyo TX-NR609, $335 from Amazon.
Jimmy_R is offline
post #9 of 9 Old 05-03-2012, 03:14 AM
bladerunner6's Avatar
Quoted: 22 Post(s)
Liked: 59
Crutchfield has the 1612 for $200.
http://www.crutchfield.com/p_033AV16..._1612&skipvs=T
You might/should be able to use a coupon on it.
bladerunner6 is offline
Reply Great Found Deals
