Klipsch RW-12d Subwoofer - Only $299 - Save 70% - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 656 Old 01-13-2013, 10:33 AM
cacophonix's Avatar
Quoted: 30 Post(s)
I bought this sub last week and it arrived from newegg without issues. It was double boxed and i didn't see any damage anywhere. Good job, Newegg. But unfortunately, it didn't work well in my open living room, so i put it on craigslist for $25 less than newegg and sold it the same day.
I tested it in another room where it worked much better. I can see why people love this sub. The output is very good, and has good controls with easy access. It does dig deep. The only negative thing i could say about this is the cabinet construction. It could be better. It failed my knock test big time. I didn't remove the woofer to check, but i don't think they have any kind of bracing in there. The cabinet is surprisingly light for its size. But then, i don't expect any big name brand to invest too much into cabinets which would make them heavier to ship. But for the sale price, i don't think you can do any better than this sub. For the vast majority, this is all the sub they can afford and handle. If you are an obsessive audiophile, you might want to invest a bit more and either buy from an internet direct company like hsu, svs or rythmik.
cacophonix is offline
post #272 of 656 Old 01-13-2013, 12:22 PM
LastButNotLeast's Avatar
Quoted: 1793 Post(s)
Liked: 1404
If you're an obsessive audiophile, you're not looking at $300 subs. If you're a value-hunter like myself (and, apparently, many others on this thread), this is a great deal. Using my DSP1124P with a little nudge at 20Hz, I'm getting "sound" (mostly "feeling," at that level) starting at about 18Hz. I have another sub taking over at 40Hz, so I don't think my Klipsch will be overworked.
I'll be running REW again soon just for fun, but that's another thread.
I'll be curious to see what you replace this sub with and what you end up spending (you probably should have just gotten two! wink.gif).
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #273 of 656 Old 01-13-2013, 12:47 PM
SauceXX's Avatar
I just upgraded from an H100 and couldn't be happier. I had considered a HSU VTF-2 MK4, but I've recently upgraded a few other components and didn't want to spend twice what the Klipsch cost. The sub is louder, less boomy, more precise, better with both HT and music and has a commanding presence the BIC did not. The one complaint I have is the same one that's been noted here already; that the port tube arrives loose. I was able to reseat the tube and when I get a chance I'll epoxy it. Kind of a pain but easier than sending it back and possibly getting the same problem in return.
As a side note, a few previous posters talked about the sub chuffing. I don't know what volume they're driving the sub but it's got to be at the max, which would blow my roof off. So far I haven't heard any chuffing and I really don't think I'll ever get it loud enough to find out.
SauceXX is offline
post #274 of 656 Old 01-13-2013, 01:33 PM
Maniac2k's Avatar
Ok im a bargain hunter. I just hope the price drops to $299 before it goes oos permanently.
Maniac2k is offline
post #275 of 656 Old 01-13-2013, 03:19 PM
cacophonix's Avatar
Quoted: 30 Post(s)
I'll be curious to see what you replace this sub with and what you end up spending (you probably should have just gotten two! wink.gif ).
Michael
I'm consider myself to be an obsessive audiophile who sadly has no deep pockets to indulge in this hobby as i would like to. So i try to keep an eye out for deals on products that punch way above their league. Like i mentioned in my post, i can see why this sub is popular. Just that it didn't work in my room ... i use audyssey to eq the bass, but it didn't sort out the issues fully. Maybe i need to use a DSP like yours. But for now my DIY ER18MTM that goes down to about ~35Hz will have to run in full range mode. I've a tc sounds LMS-12r/passive DIY in the works ... I'm hoping that would be the answer to my prayers. If not, there is always audiogon smile.gif
post #276 of 656 Old 01-13-2013, 04:55 PM
JDF1384's Avatar
Originally Posted by Maniac2k View Post
Thanks for the review! So you say its not built as well as other subs in this price range and you close with you wont find a better sub in this price range. So, if you could do everything over, would you get the klipsch or something else? If something else, which one? Thanks!
Well, as I said, I don't think you're going to find a better sub in the $300 - $400 range. I had considered the HSU STF-2, which is a well regarded sub, and the Lava LSP12. What sold me on this Klipsch sub (apart from the low price) was the Sound and Vision review here: http://www.soundandvisionmag.com/article/shootout-five-mid-price-subwoofers
Now if this Klipsch sub was still selling for $700 I wouldn't even consider purchasing it. For that much money I would be looking at an HSU VTF-3 or Outlaw LFM-1EX. For the $350 I paid for this Klispch sub though, I'm quite happy. If I could go back I would certainly buy it again. If I had a bit more cash to spend I would have bought an HSU VTF-2 instead. Like SauceXX, I didn't want to spend twice the money for it though. Maybe in the future.
-Jeff
JDF1384 is offline
post #277 of 656 Old 01-13-2013, 05:18 PM
Bond 007's Avatar
Quoted: 2625 Post(s)
Liked: 2088
-Jeff
You made the right choice. I got an stf2 first because I was impressed by the thought of an "upper crust" sub. It is good quality I guess. I only had it for 3 days. I have a small room 12x16 and I could barely hear it no matter what I did.
I got the RW and it kills the stf2. Much more output and just as accurate by my ears.
It cost me $110 to find that out. $43 to ship it to me and $67 to ship it back. So I have $409 in my RW the way I see it and I am still happy.
Licence to Kill
Bond 007 is offline
post #278 of 656 Old 01-18-2013, 04:24 AM
Maniac2k's Avatar
On sale for $299 again. Just ordered one.
Maniac2k is offline
post #279 of 656 Old 01-18-2013, 07:01 AM
davemex's Avatar
Quoted: 17 Post(s)
I got to eager to get my speakers and ordered yesterday at $350. Contacted Newegg and after some "negotiations" they refunded the difference. Always a good company to work with!
Edited to add:
They're having a big speaker sale right now. There's lots of other good stuff to be had on discount if you poke around.
LG 65EF9500 /Denon AVR-2113ci / Darbee DVP5000/Definitive Tech SM 350 + Mythos 3 Center + 2 Klipsch RW-12D Subs / Custom 20TB Ubuntu Server + Win 10 HTPC/ Xbox 360 / OUYA / iRule Pro
davemex is offline
post #280 of 656 Old 01-19-2013, 01:21 PM
Shagz's Avatar
What cables are you guys using for this? i do not know where in my room to put it yet, just placed the order on the sub.
Will it be ok to order a 50ft cable in case i need to run it to he side of my couch?
Receiver will be the denon 1713.
Will order from monoprice.
thanks all.
Shagz is offline
post #281 of 656 Old 01-19-2013, 01:21 PM
Shagz's Avatar
thanks all.
Shagz is offline
post #282 of 656 Old 01-19-2013, 01:37 PM
myoda's Avatar
Liked: 57
thanks all.
Make sure you use a cable made of RG6 - much sturdier than RG59. Blue Jeans Cable is a good source also.
http://www.amazon.com/foot-Subwoofer-Cable-Tartan-brand/dp/B0038T37DC
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=5872&seq=1&format=2
myoda is offline
post #283 of 656 Old 01-19-2013, 03:53 PM
Bond 007's Avatar
Liked: 2088
Use the Monoprice cable he linked you.
Licence to Kill
Bond 007 is offline
post #284 of 656 Old 01-19-2013, 04:15 PM
Shagz's Avatar
No degrade if I use a longer cable?
Thanks for the help
Shagz is offline
post #285 of 656 Old 01-19-2013, 06:06 PM
Bond 007's Avatar
Liked: 2088
Thanks for the help
Not if you get the Monoprice one. You don't have to get the 100 footer though if you don't need that much.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=2684&seq=1&format=2
It comes in 50, 75 and 100.
Licence to Kill
Bond 007 is offline
post #286 of 656 Old 01-20-2013, 04:44 AM
Shagz's Avatar
Thanks, doing some mock placemsnts to see how much i need.
Are you using the Y-splitters with this cable or just right into the R chan of the sub?
Shagz is offline
post #287 of 656 Old 01-20-2013, 05:13 AM
Bond 007's Avatar
Liked: 2088
Usually you just hook up to the lfe port. What sub do you have?
Licence to Kill
Bond 007 is offline
post #288 of 656 Old 01-20-2013, 05:27 AM
Shagz's Avatar
Klipsch RW-12d Subwoofer just ordered it yesterday
Shagz is offline
post #289 of 656 Old 01-20-2013, 05:40 AM
Bond 007's Avatar
Liked: 2088
The instructions say "left and/or right". Neither is marked "lfe".
Licence to Kill
Bond 007 is offline
post #290 of 656 Old 01-20-2013, 06:52 AM
skidog's Avatar
Liked: 27
I have mine hooked into the left.
Panasonic TC-P65VT50
Denon 2113ci
Panasonic DMP-BDT220P
Ascend CMT-340SE L/R
Ascend CMT-340SE Center
Ascend CBM-170SE Surrounds
Klipsch RW12-D x 2
skidog is offline
post #291 of 656 Old 01-20-2013, 07:58 AM
scipper77's Avatar
Quoted: 39 Post(s)
Let me see if I understand this (I don't have the sub so excuse my ignorance) There is a port for left and a port for right, but there is only one speaker??
Or is there only one port on the sub that is labeled left and/or right?
scipper77 is offline
post #292 of 656 Old 01-20-2013, 08:38 AM
skidog's Avatar
Liked: 27
There are 2 ports for line in, one is marked R the other L, I have my sub cable hooked to the one marked L.
Denon 2113ci
Klipsch RW12-D x 2
skidog is offline
post #293 of 656 Old 01-22-2013, 08:40 AM
Rasta Linus's Avatar
I received my Klipsch RW-12D yesterday and that thing is very nice for 299 bucks. Nothing was loose or broken either. The thing was making my rug in front of it float from all the air it was pumping out. I believe that sub just completed my system.
Rasta Linus is offline
post #294 of 656 Old 01-24-2013, 06:06 AM
Maniac2k's Avatar
Sub arrived in perfect condition. It works great and i love it!
Maniac2k is offline
post #295 of 656 Old 01-24-2013, 06:40 AM
Angler55's Avatar
Newegg has the Klipsch RW-12d for $299.99 and free shipping with the promo code.
Al
Angler55 is offline
post #296 of 656 Old 01-24-2013, 07:47 AM
MNaudioguy's Avatar
Quoted: 59 Post(s)
Al
What is the promo code? Also, not sure if this is the right forum, but I will ask anyway smile.gif Will 2 RW-12ds hit the low bass frequencies i need to compensate nicely for my towers. i am looking at purchasing Polk LSi15s for fronts and LSi7s for surrounds. I think the 15s have a decent base frequency and want something to pick up where they leave off. I am guessing I will probably need to get one of the more expensive 15s (HSU, PSA, etc.) but am secretly hoping I might be able to get by with 2 12d's in the short term. Thoughts?
MNaudioguy is offline
post #297 of 656 Old 01-24-2013, 08:05 AM
blake18's Avatar
Quoted: 315 Post(s)
Liked: 191
Oh hell yes they will. Two will tear the paint off the walls.
Lumenlab "Community driven video lab".
blake18 is offline
post #298 of 656 Old 01-24-2013, 08:11 AM
MNaudioguy's Avatar
Quoted: 59 Post(s)
At the right frequency levels? Will they hit the lows that I need. For example, someone in another thread said to hit the ranges 20 to 80 hz i would need to get a more expensive sub. I guess my assumption was that even 2 12ds would not get to that range or a range for the "deep" bass. Is that assumption a accurate one?
post #299 of 656 Old 01-24-2013, 10:22 AM
Angler55's Avatar
You have to sign up for there email special to use the promo code so it wouldn't do me any good to give it to you. All you have to do is go to Newegg and sign up and they will send you emails with the promo codes.
I have no idea if this sub is what you're looking for as I'm trying to figure out what sub I'm going to get and never having owned one I wouldn't be the person to answer that.
Al
Angler55 is offline
post #300 of 656 Old 01-24-2013, 10:59 AM
Liked: 1404
More subs doesn't equate to deeper bass, just more evenly-distributed bass (which is at least as important). That said, these subs get close to 20Hz, so there's plenty of rumble when you need it.
If you need to get lower, you'll need to spend more. Probably more than two of these, in fact.
Reply Great Found Deals
Klipsch Rw 12d 12 Subwoofer Each , Klipsch
