Klipsch Icon WF-32 Icon W $299, Klipsch WC-24 Icon-W $229 @ Newegg ends 9/5/2012 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-30-2012, 11:17 AM - Thread Starter
Jelorian's Avatar
Just saw this. I may pick up a pair for my current project of building out my den.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780081&nm_mc=EMC-IGNEFL083012&cm_mmc=EMC-IGNEFL083012-_-EMC-083012-Index-_-HomeAudioSpeakers-_-82780081-L025B
There is also a $50 promo code but according to the site you won't see the discount till you've fully committed and you are at final checkout.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780085&nm_mc=EMC-IGNEFL083012&cm_mmc=EMC-IGNEFL083012-_-EMC-083012-Index-_-HomeAudioSpeakers-_-82780085-L025C
The center channel has a $70 off promo code on top of the $229 price.
Jelorian is offline
post #2 of 3 Old 08-31-2012, 05:28 PM
motorwerke's Avatar
Where is the $70 additional off the center? I don't see that coming up?
motorwerke is offline
post #3 of 3 Old 09-01-2012, 06:38 AM
TheaterChad's Avatar
Quoted: 27 Post(s)
Liked: 33
Promo codes are usually e-mailed to you directly from Newegg, go to New egg's web site, and register.
You have to add the item to your cart, then apply the promo code, then go to first check-out, you enter your info then it asks you at the final check-out, which is where the promo-code is applied, you can either click process order or change or delete you items, I think Newegg should remove this from their web site, as this is so stupid to have to do all that work to just apply a promo code.....
TheaterChad is offline
Reply Great Found Deals
