Cerwin Vega CV-5000 pro audio amp for $680 at guitarcenter.com using 15% off couponcode lday15 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1 of 82 Old 09-03-2012, 06:38 PM - Thread Starter
Archaea's Avatar
Quoted: 3086 Post(s)
Liked: 2715
http://www.guitarcenter.com/Cerwin-Vega-CV-5000-High-Performance-Professional-Power-Amplifier-H69833-i1688723.gc
This amp looks very nearly like my Crown XLS-5000. It's a beast. If you've got a DIY project or otherwise need a very powerful 3u battle tank amp -- this might be a great ticket.
This amp would be mated well to push a couple passive JTR Captivators or possibly some other monster drivers like the LMS-5400 drivers. (though I don't know where the rolloff occurs on the amp).
Cerwin-Vega CV-5000 High Performance Professional Power Amplifier Features:
Front
Volume control that features a 21 detent potentiometer for each channel
Rear
Mode selector switch (Parallel/Stereo/Bridged Mono)
HPF: On/Off switch for each channel
Limiter: On/Off switch for each channel
Connectors
Input: Combo jack electronically balanced 1/4" & XLR male for input link
Output: 5-way binding post & Speakon connector for each channel
Indicator: Signal, -20dB, -10dB, 0dB, Clip, Protect & Active
Protection: Short Circuit, Thermal, Current Limit, DC Offset,
Current Inrush, RF Protection, Turn On / Turn Off Mute
Cooling: Variable speed fan forced cooling
Cerwin-Vega CV-5000 High Performance Professional Power Amplifier Specifications:
Rated Power:
Stereo @ 8 ohms 1100 W
Stereo @ 4 ohms 1800 W
Stereo @ 2 ohms 2500 W
Bridge @ 8 ohms 3600 W
Bridge @ 4 ohms 5000 W
Input Sensitivity (8 ohms 1.42V (+5.3dB) Input Impedance 20 k ohms Balanced / 10t k ohms Unbalanced
Frequency Response (+/-3.0 dB) 5Hz – 50kHz
Class H , 3 tier
T.H.D (1 kHz, Rated Power) < 0.03 % 4 ohms and 8 ohms
Signal to Noise Ratio (20Hz - 20kHz) <-100 dB
Damping Factor (8 ohms,400 Hz) > 300
Power Source 100~240 Vac, 50/60 Hz
Dimensions: (H x W x D) 5.1" x 18.9" x 18.9"
Weight: 83.3 lbs
Archaea is offline
post #2 of 82 Old 09-04-2012, 04:36 PM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
Good to see big iron options still exist on the cheap. I wonder how accurate the 5-50khz +/- 3db is?
Gorilla83 is offline
post #3 of 82 Old 12-28-2012, 12:03 AM
johnplayerson's Avatar
Quoted: 229 Post(s)
Liked: 59
I bought two of these, when I found out the boys at marathon don't reply to emails, pick and choose what they reply to, and basically refuse to allow you to buy parts. I took them for a run on my homemade quad bass boxes. Got 4 alpine swr 10d4 per side and one cv 5000 hooked up to each 4 subwoofers in mono on 8ohms load. They power them really nice, and way more solid bass than my marathon ma 5050s gave me. The cerwin bass was tight and low, the marathon bass was low and loose.
Looking under the hood I could see why the cerwin vega cv 5000 was drowning out the marathon ma 5050. The cerwin has a massive toroidal transformer which is probably why it is 30 pounds heavier than the marathon. The cerwin has 24 smoothing capacitors, at 15000 uf each, the marathon only has 12 caps at 10000 each. The marathon just doesn't have the power supply to provide the same bass output the cerwin cv 5000 can do.
I immediately bought two more cv 5000s after seeing what they can do. and that I could no doubt trust cerwin vega more if I ever need parts or replacement. The three year warranty is cool too. I highly advise picking these up. The Marathon MA 5050 are retired. Maybe use for tops some day but bass performance is out!! No need to use the low cutoff with the cerwin vega cv 5000 SUC51175.JPG 2549k .JPG file
A Good amplifier requires a adequate power supply, It does not matter what the amplifier is capable of if the power supply will not provide the power required. Most amplifiers have under rated power supplies. It is up to you to make sure you get the ones that are least under rated if at all.
johnplayerson is offline
post #4 of 82 Old 01-13-2013, 04:38 PM
Quoted: 229 Post(s)
Liked: 59
http://www.avsforum.com/t/1438439/5-000-watts-699-until-nov-11#post_22824816
The funny thing about the world is everyone complains about censorship, but everyone runs to it when it comes to damage control. I wish all a good experience on the forums. A few more pics of the cv 5000
post #5 of 82 Old 01-28-2013, 09:12 AM
Tim7777's Avatar
johnplayerson, I stumbled on this forum doing research on the ma5050. I was ready to pull the trigger when I saw the interesting info u put up about the CV5000. I also saw the thread of you post in the speaker plans forum and I agree that you were unfairly treated like a punk kid because you were using car speakers with PA amps. Anyways, I was thinking of using two of these bad boys to power 4 jl 13w7. I built my own version of the jl gotham. Do you think these amps will handle the 3 ohm load well?
Tim7777 is offline
post #6 of 82 Old 05-09-2013, 04:50 AM
Quoted: 229 Post(s)
Liked: 59
I was on vacation for a while. I would not recommend anything under 4 ohm load on any amplifier even if they are rated to it. The JL audio are fantastic woofer but I would recommend you
power them at 6 ohm load. IE. wiring to get the ohms up. I use dual four ohm coils all the time, and either use 8 ohm load , or wire to 8 ohms. The four alpines I use are wired in series to give me
an 8 ohm load. Then using the cv 5000 in bridged mode, (technically 4 ohms per side) I get 8 ohm load bridged.
There really isn't much need to go under in the ohms. I am positive you will blow your mind with the sound quality and punch wiring the pairs to 6 ohms and then using each amp to power the two.
Wish you were close as I would love to hear it. My new subs are the Rockford fosgate t2s , Do they ever sound good in the house lol.
post #7 of 82 Old 05-09-2013, 04:59 AM - Thread Starter
Archaea's Avatar
Liked: 2715
Why do you say nothing less than four ohm? I can see it for DJ use but for home theater use two ohm per channel works great imo. I've been using a crown xls5000 in two ohm stereo on a pair of JTR captivator pros for about a year now and I've never even felt the amp begin to get warm even with extended demo sessions at reference levels.
Archaea is offline
post #8 of 82 Old 05-09-2013, 05:01 AM
Quoted: 229 Post(s)
Liked: 59
Check the other threads, I posted more good information that's nice to know about this amplifier and two of its identical cousins. I love top of the line equipment, and even
many name brand top of the line, but I must say using pro amplifers with car audio subs will blow away those veledyne dd subs that they have the nerve to charge
you 4000.00 for ONE!!!!.
Nothing wrong with using these pro amps for bass. Most pro amps are rated distortion at .1 percent vs home audio top of the line at .03 to .003, However most of your
distortion is always in the high end not the low end, so you get nice clean solid bass.
The cv 5000 is using the same output transistor as crown, qsc, the 2sc5200 and 2sc1943s
post #9 of 82 Old 05-09-2013, 05:03 AM
Quoted: 229 Post(s)
Liked: 59
Archea, You can use 2 ohm if you like but its much harder on your amplifiers, and I like mine to last 20 years. 2 ohm loading is one of the necessary evils of car audio due to low voltage.
In the home you have no limit on the circuit. you can hook up 20 amp and 30 amp lines, so there is no need to stress out your amplifier for nothing. Plenty of output can be achieved at 8 ohms.
post #10 of 82 Old 05-09-2013, 10:19 AM
datranz's Avatar
Quoted: 58 Post(s)
Liked: 43
i have been looking for a good amp, any1 know where i can find a good deal on this amp?
datranz is offline
post #11 of 82 Old 05-09-2013, 08:08 PM - Thread Starter
Archaea's Avatar
Liked: 2715
Guitar center has $75 off it right now for mother's day.
$800- $75 = $725
If you wait until the next big holiday - both musician's friend and guitar center usually have 15% off coupons.
Memorial Day will be the next 15% off coupon most likely.
Archaea is offline
post #12 of 82 Old 05-11-2013, 05:00 PM
Quoted: 229 Post(s)
Liked: 59
Sonic fibre apparently has best offer available on their internet site for this amp. Check the other threads. Quite a few recommending them now.
post #13 of 82 Old 05-14-2013, 07:42 PM
Mauricio Mejia's Avatar
Mauricio Mejia is offline
post #14 of 82 Old 05-14-2013, 08:14 PM - Thread Starter
Archaea's Avatar
Liked: 2715
I had an american audio v3000 and a behringer ep4000 was significantly better. Id buy the cerwin vega over american audio personally without thinking twice.
Archaea is offline
post #15 of 82 Old 05-23-2013, 01:40 PM
COACH2369's Avatar
Quoted: 968 Post(s)
Liked: 802
Has anybody found a quiet fan mod for this unit? I am thinking about picking one up but need a more quiet fan.
COACH2369 is offline
post #16 of 82 Old 05-24-2013, 12:18 PM
Rebel975's Avatar
Quoted: 21 Post(s)
Liked: 127
15% off at Guitar Center is back. When you are on the product page you can click "request online code" and a CSR will generate one for you.
http://www.guitarcenter.com/Cerwin-Vega-CV-5000-High-Performance-Professional-Power-Amplifier-109103564-i1688723.gc
As for the fan mod- it seems the best solution is to buy two quiet 12v fans and run them in series off of one fan header.
Rebel975 is offline
post #17 of 82 Old 05-24-2013, 05:11 PM
COACH2369's Avatar
Quoted: 968 Post(s)
Liked: 802
I am gonna pick one of these up this weekend. If i can't find a quiet fan, then I will just return it.
post #18 of 82 Old 05-25-2013, 08:23 AM
Rebel975's Avatar
Quoted: 21 Post(s)
Liked: 127
Rebel975 is offline
post #19 of 82 Old 05-27-2013, 07:41 AM
COACH2369's Avatar
Quoted: 968 Post(s)
Liked: 802
Mine was ordered as well... Hopefully it will arrive within a week or so.
Stupid sales tax...but it was still cheaper than most online locations right now.
Now to find the best solution to the fan situation.eek.gif..
post #20 of 82 Old 05-27-2013, 07:03 PM
Rebel975's Avatar
Quoted: 21 Post(s)
Liked: 127
Did you receive an out of stock email after ordering? It said that mine would ship after they get in some more stock (estimated 6/1).
Rebel975 is offline
post #21 of 82 Old 05-28-2013, 06:15 AM
COACH2369's Avatar
Quoted: 968 Post(s)
Liked: 802
Something odd happened. I received a shipping notification email last night and then 15 minutes later, I received a backorder notification...
Hopefully they will ship by the end of the week or soon after that.
post #22 of 82 Old 06-01-2013, 03:11 PM
COACH2369's Avatar
Quoted: 968 Post(s)
Liked: 802
Anybody receive a shipping notification for their unit yet?
post #23 of 82 Old 06-01-2013, 06:24 PM
Rebel975's Avatar
Quoted: 21 Post(s)
Liked: 127
Their website used to say that it was backordered until today. However, now it reads "AVAILABLE 6/5/2013".
Rebel975 is offline
post #24 of 82 Old 06-06-2013, 06:12 PM
Rebel975's Avatar
Quoted: 21 Post(s)
Liked: 127
Rebel975 is offline
post #25 of 82 Old 06-07-2013, 02:31 PM
COACH2369's Avatar
Quoted: 968 Post(s)
Liked: 802
I cancelled my order and went a different route.
post #26 of 82 Old 06-12-2013, 06:17 PM
Rebel975's Avatar
Quoted: 21 Post(s)
Liked: 127
I couldn't do that myself, as I really needed the Memorial Day discount. Anyway- mine has shipped. It should be here Friday. smile.gif
Rebel975 is offline
post #27 of 82 Old 08-27-2013, 05:26 PM
Quoted: 229 Post(s)
Liked: 59
http://www.ebay.com/itm/CoolerMaster-120mm-Fan-Blue-LED-A12025-12CB-3BN-F1-/310393028251?pt=US_Computer_Case_Fans&hash=item4844ddbe9b
This model coolermaster fan works great with the unit. wire in series to ONE fan connector. Series wiring means, join plus and minus of the fans together, then hook up the
negetive lead of one fan and positive lead of the other fan to the fan power.
The unit actually has quit a few more fan connectors, but there is only one 24 volt dc power supply running them all.
post #28 of 82 Old 08-28-2013, 02:38 PM - Thread Starter
Archaea's Avatar
Liked: 2715
Archaea is offline
post #29 of 82 Old 08-28-2013, 02:54 PM
Rebel975's Avatar
Quoted: 21 Post(s)
Liked: 127
Any idea why these fans don't work? I'd hate to have to buy another set if I didn't need to.
BTW- the wires on these fans are not marked, but I've tried every combination, assuming the middle wire is 12v.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181021
Edit- well, I guess I'll just buy a couple of those known-working Coolermaster fans.
Rebel975 is offline
post #30 of 82 Old 08-31-2013, 03:05 PM
Rebel975's Avatar
Quoted: 21 Post(s)
Liked: 127
Originally Posted by johnplayerson View Post
This model coolermaster fan works great with the unit.]
Okay- I just got in a pair of these fans, and they do work great.
I don't know why I tried to reinvent the wheel by buying those other fans. Oh well. These work great, and were pretty cheap. They also push a decent amount of air for being so quiet. I will actually be able to start using the amp now. The stock fans were so loud that I didn't even bother using the thing.
Thanks for the useful info, johnplayerson.
Rebel975 is offline
Reply Great Found Deals
Cerwin Vega Cv 5000 High Performance Power Amplifier , Cerwin Vega Brand
