Change Format By Using Your Amazing M4V to MOV Converter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-02-2012, 02:56 AM - Thread Starter
windyliang's Avatar
Because of the variety of programs available today, there is an increasing list of video file formats that you can use. Most basic PC users produce their video in Windows Movie Maker, which is optimized to export to mov format. This format is not supported by M4V, the default video player on Mac.
Trouble watching or editing video because of compatibility issues like "wrong codec"? To save your time and trouble, M4V to MOV Converter lets you easily convert videos, movies and TV shows to optimized preset formats to fit iPad, iPod, iPhone (iPhone 5), PSP and other devices. It also lets you convert video to and from all popular formats like AVI, WMV, MPG, MOV, etc.
We have to follow only four simple steps to convert any M4V file to MOV compatible format. You can use Video Converter Pro for Mac or Video Converter Pro for Windows to complete this task. This article just aims to introduce a powerful video compressor and a step by step guide on how to convert M4V to MOV with almost no loss of video quality. They will describe as follows.
Firstly, you can directly drag M4V files to the program or click “File” icon on the tool bar to import files.
Then, select MOV as the output format. Click “Output setting” icon and open the "Format" list, here you should choose MOV in the "Common Video" menu as your output format.
Before M4V to MOV conversion, if you want to set the video and audio parameters, please click "Options" item on the "Output Setting" menu. You can adjust the codec, resolution, frame rate and bit rate to make the output video perfect.
Finally, press "Convert" button, all the tasks will begin with high efficiency. If you make batch conversion, you can set the "After conversion" mode on the conversion interface. It provides you "Put computer to sleep", "Shut down my computer" and "Do nothing" three mode options.
Warnings: Because there is always the chance of the conversion process damaging a file, it is best to use a duplicate of the file instead. This will enable the original file to be available should the duplicate being converted suffer corruption or deletion.
Two Key Features:
Highly Customized M4V Conversion
This M4V Converter allows you to customize the parameter for output files: bit rate, frame rate, resolution, etc. You can also select the preset format that design for you player like iPhone, iPod, PSP, Zune, etc.
Support batch conversion
This M4V Converter supports batch conversion; you can also click the check box of turn off computer after conversion to shut down PC automatically.
Fully support Dual-core or Multi-core processor, compatible with Windows Vista-32 bit perfectly.
Free online technical support and upgrade; provide the best and quick service for you.
This M4V to MOV Converter for Mac allows users to edit their M4V files before converting M4V to MOV. You can crop videos, merge videos, trim videos, add watermark, capture attractive images, and so on. After conversion, you can watch videos anytime and anywhere.
windyliang is offline
post #2 of 2 Old 11-02-2012, 02:06 PM
LastButNotLeast's Avatar
Quoted: 1804 Post(s)
Liked: 1416
Another demo version of another video converter.
Sorry, not a "great found deal," just another promo.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
Reply Great Found Deals
