Inexpensive LED light fix ($1.99) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-10-2012, 06:33 AM - Thread Starter
ToAsTyWoAsTy's Avatar
I just got a new Panasonic TV which has a piercing red power light which can not be turned off. I thought about putting a piece of tape over it but then I could not see if it was on with no source. I found these... http://www.lightdims.com
for $1.99 it fixed my problem plus I used it on a few other things.
You can get a pack for free with 1.99 s&h
or get over 100 for $5.99 plus .99 s&h
I thought for $1.99 it was a definite deal.
ToAsTyWoAsTy is offline
post #2 of 5 Old 12-10-2012, 09:14 AM
brendelac's Avatar
Quoted: 134 Post(s)
Liked: 74
layer a few small pieces of scotch tape over the LED. not nearly as bright, but still able to be seen.
brendelac is offline
post #3 of 5 Old 12-10-2012, 01:24 PM
comicguy's Avatar
Scotch tape is ghetto! Light dims are awesome. Yes, they are overpriced what what they are but STILL they are a cheap fix AND look good.
I love the varying tints as well. Of course I am the weird guy who also buys port cover to put over unused RCA jacks and usb inputs. I HATED the fact that my Oppo 103 has an exposed usb port while my 93 had a cover! :-)
To each their own, but I love my light dims...
comicguy is offline
post #4 of 5 Old 12-10-2012, 09:59 PM
Tom4221's Avatar
I like it.
Tom4221 is offline
post #5 of 5 Old 02-14-2013, 10:22 AM
AVFORME's Avatar
Just buy some dark window tint and apply however many layers necessary to dim light.
AVFORME is offline
Reply Great Found Deals
taboola here
