Pioneer Elite VSX-53 $499.98!! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 105 Old 05-07-2013, 06:37 PM
thatsgreat's Avatar
Just picked this up open box at my local BB for 387.11. They had 2 of them. Thanks Skrill for the heads up!
thatsgreat is offline
post #92 of 105 Old 05-07-2013, 10:07 PM
salaseghs's Avatar
Originally Posted by Crown7 View Post
+1 on the Onkyo replacement...Do the math, is there any Onkyo that is comparable at this price point for the features than the 53 has? Man im trying to step up from my 606, and this is a great deal!
I just replaced my 606 with the vsx-60. The receiver was $308 + BB 4 yr warranty + tax = $392.
All I can say is that it is a very much better receiver.
Pros:
-Audio is so much more accurate, it's hard to describe but you know it when you listen to it.
-Ethernet; being able to turn on the receiver with the app is great.
-Operating temperature is much better, Onkyo runs hot in comparison.
-The Pioneer audio calibration is better than the Onkyo one.
Cons:
-Learning the receiver requires a learning curve and is very confusing at first but worth it in the end.
-Blue power light is too bright and a bit distracting.
Here are a few screenshots of the apps; iControlAV2012 and AVNavigator:
salaseghs is offline
post #93 of 105 Old 05-10-2013, 11:53 AM
bungi43's Avatar
Man I'd pick one up in a heartbeat for that cost. Dang it.
bungi43 is offline
post #94 of 105 Old 05-10-2013, 12:52 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
is vsx 60 better than this? i can get it for 300.
caloyzki is offline
post #95 of 105 Old 05-10-2013, 01:03 PM
SupaKats's Avatar
Quoted: 66 Post(s)
Liked: 120
I didn't look at specs or other features but the 60 lacks a second Hdmi out and pre-outs to add an external amp.
My Basement HT/Gaming/Bar Space.
Official Hip Hop Thread
Equipment
Epson 8350 on a 100" Visual Apex screen, Pioneer VSX-53, Polk RTi A5(x2) CSi 5 RTi A1 (x2) RTi 4(x2), Outlaw Audio LFM-1 EX, PS3, XBox 360 with HD-DVD add-on.
SupaKats is offline
post #96 of 105 Old 05-11-2013, 01:17 PM
grigorianvlad's Avatar
Quoted: 164 Post(s)
Liked: 623
Pros:
Cons:
salaseghs, your first screenshot has a Tone/Balance button. I dont see that in mine. How did you set that up? What equipment do you have? What version of iControl? What does that button do?
DAC: Wyred4Sound DAC1LE || Processor: Marantz AV8801 11.2 Ch || Power Amps: Audio Research VS110 (100W tube) || Emotiva XPR-2 (600W), Emotiva XPA-5 Gen 2 & UPA-500 (200W/80W) || L/R Speakers: Eminent LFT-8b , Magnepan 2.7, Center : Polk LSiM-704C, Sur: Polk LSiM-703 || Sub 1: Rythmik F25 (800W). Sub 2: Sunfire True Signature TS-EQ12 (2,700W) || Cables: MIT terminator 2 Biwire, 4, Exp; Cardas Crosslink || Power: PS Audio Premier || HP: HifiMan HE560
grigorianvlad is offline
post #97 of 105 Old 05-13-2013, 10:43 PM
salaseghs's Avatar
It is dependent on the Listening Mode. Once you are able to select it, you have access to Bypass or On. If you select on, you can adjust Bass, Treble, and Balance.
I have a VSX-60. App version is 1.2.0.
Edit: I have the app configured as Expert within Settings (inside of the app) > Operation Mode.
post #98 of 105 Old 05-14-2013, 05:40 PM
Quoted: 164 Post(s)
Liked: 623
Thank for the post. We have different versions of the software. I think you have iCOntrolAV2012 which I can never install. IPad says there is another version and installs iCOntrolAV2 which doesnt have your Tone button, but instead has a 9 band equalizer. I also dont have the Sound Explorer button. What does it do?
post #99 of 105 Old 05-14-2013, 06:08 PM
Quoted: 164 Post(s)
Liked: 623
I found this app indispensable. Emphasis, dialog enhancement and Finger equalizer are alone life savers. Just an amazing app.
post #100 of 105 Old 05-22-2013, 02:32 AM
salaseghs's Avatar
It gives you more details about the sound. Here are some screenshots:
post #101 of 105 Old 05-22-2013, 12:03 PM
Quoted: 164 Post(s)
Liked: 623
Thanks. Your app does more than mine. Looks like you have VSX-60. Good for you! I dont have X-curve, some other things. I wonder if extra features you have are because of the different app or different VSX (mine is a VSX-53)? Also, how in the world did you manage to take a screenshot from an iPad?
post #102 of 105 Old 05-22-2013, 12:11 PM
SupaKats's Avatar
Quoted: 66 Post(s)
Liked: 120
Power and home buttons at the same time screen shots on idevices
Equipment
SupaKats is offline
post #103 of 105 Old 05-22-2013, 12:13 PM
Quoted: 164 Post(s)
Liked: 623
Thank you, SupaKats. I did not know that
post #104 of 105 Old 05-22-2013, 12:14 PM
SupaKats's Avatar
Quoted: 66 Post(s)
Liked: 120
No problem
Equipment
SupaKats is offline
post #105 of 105 Old 05-22-2013, 12:25 PM
Quoted: 164 Post(s)
Liked: 623
Also, what is Hi-24bit in your screenshot? What does it do?
Reply Great Found Deals
Pioneer , Pioneer Brand , Pioneer Elite , Pioneer Elite Vsx 53 Av Network Receiver 7 1 Channel 3d
