Energy RC-Micro 5.1 $249 at amazon - AVS Forum | Home Theater Discussions And Reviews
post #2 of 8 Old 06-17-2013, 05:44 PM
nyrmetros's Avatar
How do these compare to the Energy Take Classic?
nyrmetros is offline
post #3 of 8 Old 06-18-2013, 02:17 PM
eah9's Avatar
Liked: 29
Build quality better on the micros but more frequency range on the takes - they would be better with a budget subwoofer.
Energy RC70 L/R | RC-LCR Center | C-R3 Surrounds | VMINI Bookshelves Surrounds | S12.3 and Dual S10.3 Subs | KRK 10s Sub | Benq w1070 pj | Elite 100" Sable Screen | SONY STR-DN1030| Sony S5100 and S3100 BDPs
eah9 is offline
post #4 of 8 Old 06-18-2013, 05:07 PM
nyrmetros's Avatar
Paired with polk psw505 subwoofer which would be a better option?
post #5 of 8 Old 06-18-2013, 05:16 PM
cacophonix's Avatar
Quoted: 25 Post(s)
I've listened to both. Get the take 5. Has better range. Micros are way too small, and need a sub that can cover atleast from 120hz down onwards. Take 5, can easily blend with subs from 80hz on.
cacophonix is online now
post #6 of 8 Old 06-21-2013, 09:07 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 756
I don't think the Takes go down to 80hz. The ones I had sure didn't.
Afro GT
afrogt is online now
post #7 of 8 Old 06-26-2013, 12:25 PM
shashchatter's Avatar
Correct. The center channel goes down to 110Hz, the satellites to 115Hz. I personally set the XO at 120Hz.
shashchatter is offline
post #8 of 8 Old 07-03-2013, 04:41 PM
whoiswes's Avatar
Quoted: 13 Post(s)
Agreed, I have both the Take and the Micros - I much prefer the sound of the Takes when both are paired with the same sub.
whoiswes is offline
Reply Great Found Deals
