F20's now down to $149 each with code EMCXNXR233 July 5 Klipsch F-20 ($169.99 each) and S-10 Speakers ($129.99 pair) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-19-2013, 08:01 AM - Thread Starter
marjenmiller's Avatar
marjenmiller is offline
post #2 of 10 Old 06-24-2013, 12:16 PM
bgetter's Avatar
Looking for some real quick help for a newbie. I own (but not yet using) a yamaha 773 receiver here:
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v773_black_u/?mode=model
I would like to use these S-10 speakers for the surround and back speakers in the 7.1 setup in a dedicated HT room (also, I am not the type to go super loud with the audio). I know a difference between wattage in receiver and speakers are ok, especially with the less used surround, but is the difference here too much? Am I making some sort of rookie mistake? Thanks for any input.
bgetter is offline
post #3 of 10 Old 06-24-2013, 02:57 PM
ElectricFlow's Avatar
how do the F-20's compare to the Polk RTIA7?
ElectricFlow is offline
post #4 of 10 Old 06-24-2013, 03:18 PM
Banks1's Avatar
That Yamaha will do great those speakers are easy to drive.That is a really nice receiver.Enjoy.
Banks1 is offline
post #5 of 10 Old 06-24-2013, 03:33 PM
bgetter's Avatar
Have to say I got a great open box deal that was posted on here. Thanks to AVSforum...
bgetter is offline
post #6 of 10 Old 07-01-2013, 09:57 AM
fastsvo's Avatar
Quoted: 29 Post(s)
Seems like these promo codes are directly tied to specific email addresses.
fastsvo is offline
post #7 of 10 Old 07-01-2013, 10:15 AM
comicguy's Avatar
no, they are not. That being said, if you DON'T have a registered email address on file with newegg for their email s you will NOT be able to use them..
comicguy is offline
post #8 of 10 Old 07-18-2013, 04:12 PM
biliam1982's Avatar
Quoted: 341 Post(s)
Liked: 164
The S10's are back on sale for $149.99 w/ promo code EMCYTZT3842. $30 off and down from $179.99. Not as good as the original deal but still better than nothing if someone has been waiting to get this set.
The email just came in today and said it started yesterday, 17 July @ 12:01 AM PST going through tonight, 18 July. So hurry!
http://www.newegg.com/Product/Product.aspx?Item=82-780-033&nm_mc=EMC-GD071713&cm_mmc=EMC-GD071713-_-index-_-Item-_-82-780-033&
biliam1982 is online now
post #9 of 10 Old 07-18-2013, 04:20 PM
fastsvo's Avatar
Quoted: 29 Post(s)
What is the recommended use of these speakers? Rear speakers only?
fastsvo is offline
post #10 of 10 Old 07-19-2013, 04:00 AM
joehonest's Avatar
Quoted: 90 Post(s)
Liked: 37
What is the recommended use of these (S10) speakers? Rear speakers only?
The s10 are for rear light duty use, I had a pair and returned them. The best I could say about the s10 is that there light weight and easy to hang on any wall. As for the SQ , I did return them.
The s10 need to be Xed at a high hz were many large subs don't sound sweet.
Also I ran the s10 in stereo only, the high end sparkle was missing. The s10 sounded dull and lifeless, with two large horns, It was very disappointing.
The same can be said about the B-20, the horns in these speakers are just dull and lifeless.
joehonest is offline
Reply Great Found Deals
