Monoprice 5.1 Channel Home Theater Satellite Speakers & Subwoofer $84.10 - AVS Forum | Home Theater Discussions And Reviews
Old 09-04-2013, 03:24 AM - Thread Starter
DaveCarrera4's Avatar
Looks like they are clearing out stock of the old model (compares with Energy Classic Take 5 per a few web reviews), to make room for the new model $248.71, taking pre orders. Either probably a great starter system for a smaller listening environment.
Why go out to a movie theater?
DaveCarrera4 is offline
Old 09-04-2013, 12:59 PM
arkaaya's Avatar
No, this is not the version that is similar to the Energy Take Classic. It is a common mistake as Monoprice sells two similar looking models of 5.1 HT Speaker sets.
- A cheaper version with a 60W subwoofer (item # 8247) which usually sells for less than $100. Lowest it went this year was $63 back in June. This is the model that is currently listed at $84.10.
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10906&cs_id=1090601&p_id=8247&seq=1&format=2&ref=cj
- A more expensive model (the one which is compared to the Energy Take Classic) had the item # 9774 and usually sold for $250. It comes with a 200W subwoofer and the lowest it went was around $160 this year just before it was discontinued and replaced with a newer version (item # 10565).
http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10906&cs_id=1090601&p_id=10565&seq=1&format=2
John4721 likes this.
arkaaya is offline
Old 09-07-2013, 06:02 AM - Thread Starter
Probably a very good deal nonetheless. *** NEWS FLASH! ***
C|net, one of the most prestigious sites for consumer electronics reviews and information, has honored us by declaring this 5.1 speaker kit as one of their Top 10 Sleeper Hits of the year! They also declared this kit as one of their Best tech gifts for under $100. You can read and watch their full review here.
*** NEWS FLASH! ***
