55" Samsung UN55F6300 1080p 120Hz LED Smart HDTV - AVS Forum | Home Theater Discussions And Reviews
Old 11-25-2013, 01:04 PM - Thread Starter
lucaluca's Avatar
lucaluca is offline
Old 11-25-2013, 02:24 PM
socal swagger's Avatar
Quoted: 53 Post(s)
Liked: 25
i dont see it
socal swagger is offline
Old 11-25-2013, 02:45 PM
anthony fremont's Avatar
If you search for the model number, you can "customize it" and then add it to your own cart. I could see it after doing that. The "sale" price isn't really an incredible deal since it's the same price Amazon sells it for, but the $300 gift card makes it a steal.
anthony fremont is offline
Old 11-25-2013, 03:31 PM
Quoted: 53 Post(s)
Liked: 25
OK but can u use the g.card while making the purchase, to offset the cost?
Old 11-25-2013, 07:58 PM
Rajkmr21's Avatar
No, you can't as this GC will come as a rebate after purchase.
Rajkmr21 is offline
Old 11-27-2013, 03:39 AM - Thread Starter
lucaluca's Avatar
I was thinking you could sell the gift card on one of those gift card sites... forgot the name. Either way there is a ton of stuff on that so it probably can be easily used.
lucaluca is offline
Samsung Un55f6300 55 Inch 1080p 120hz Slim Smart Led Hdtv
