Good Deals on Gaffers Tape or Console Tape? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-19-2014, 03:35 AM - Thread Starter
Liked: 0
Hey all- i was wondering if anyone has bought expendables in bulk ? I saw a case of gaffers tape for 300.00 and I was wondering if its a good deal or not? We are going through a lot of it for taping down AV cables.
Is this good?
ryanscott210 is offline
post #2 of 3 Old 08-19-2014, 03:42 AM
francisdaniel's Avatar
Liked: 0
hey ryan, i dont know about 300 but we get our gaff tapes for like 245 only, check this www.gafftapes.com so you can compare. hope this helps!
It is only when they go wrong that machines remind you how powerful they are.
francisdaniel is offline
post #3 of 3 Old 08-19-2014, 10:34 AM
Liked: 0
all gaffers tape is not created equal
There are gaffers tapes that are priced at less than $300/case, but you usually get what you pay for
Tape that uses natural rubber adhesive rather than synthetic adhesive costs less but is more likely to leave residue
The thickness of the cotton cloth from which the tape is made can also impact the price- 10 mil tape is less expensive (and less strong) than
11.5 mil or 12 mil thick tape
Not all gaffers tape is the same "standard" roll length and it may be offered in 50 yard, 55 yard or 60 yard rolls, so it is not possible to
compare the price of one against the price of another without comparing the lengths
Specs of all major gaffers tapes made in the US can be found here http://*******/8hS2mV
jeffharr is offline
Reply Great Found Deals
