Panasonic PT-AE1000U $2,699.00 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-21-2007, 06:45 AM - Thread Starter
eb50's Avatar
http://www.projectorpeople.com/proje...0U&tab=reviews
1080p HD Ready Proector Capable of 200" Display
$3699 in cart - $1000 rebate from Panny. Free shipping from respectable seller, Projectorpeople.com
You can find it cheaper as a refurb or an open box, BUT this is a NEW unopened one.
Specs:
The PT-AE1000U is a full-HD compatible home cinema projector featuring 1080p LCD panels. Extensive research and development was conducted on the optical system, image processing engine, and other major components to bring high-resolution, full-HD images into the home for full and easy enjoyment. The development team collaborated with leading Hollywood colorists to further increase imaging precision through the "Hollywood tuning" process. The result is a full high definition home cinema projector that packs comprehensive Panasonic technologies into a compact, stylish cabinet.
The projector offers a host of image optimizing features including a Dynamic Iris optical system. The Dynamic Iris helps provide the deeper, richer blacks you need for true-to-life images. This system works by analyzing histograms to determine the brightness level of each image, then adjusting the lamp power, iris and gamma curve accordingly to create the ideal image.
- With Cinema Color Management technology, correction of individual colors becomes possible without affecting the colors in the surrounding parts of the picture.
- For quick and easy adjustment of zoom and focus, two test patterns are built-in
- The PT-AE1000U gives home consumers a projector with the kind of waveform monitor used in equipment for professionals. This function displays waveforms to show how the projector has adjusted the images of the input signals sent from the source device.
- The remote control can memorize the functions of up to eight home theater components (both Panasonic products and products from other manufacturers) so you can control an entire home theater system with a single remote.
- Wide-screen (1920 x 1080)
- 1100 ANSI lumens of brightness
- 16:9 native aspect ratio, supports 4:3
- High 11000:1 contrast ratio
- 2X optical zoom lens and power focus
- Wide lens shift range (vertically, it can shift the image up to about 100% of the screen height; horizontally, it can shift the image in a range equal to about 40% of the screen width)
- Quiet operation 22dB
- A variety of input ports including two HDMI ports and an RS-232C serial port
- Optional cable cover that gives the projector a square shape while neatly concealing the connection cables
- 40" - 200 diagonal screen size
- Weight 15.9 lbs
Included Accessories:
- Projector Lamp (Already Installed in Projector)
- Wireless Remote Control with Batteries
- Power Cable
Warranty Information:
- Panasonic USA 3 Year Parts & Labor Warranty and 90 Days Lamp Warranty
eb50 is offline
Reply Great Found Deals
