April 27th - Mohu Leaf Plus Amplified Indoor HDTV Antenna - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-27-2012, 01:05 AM - Thread Starter
Braden Russell's Avatar
Today's Show:
We reviewed the Mohu Leaf Indoor HDTV Antenna back in July (Podcast #489) and thought it was the best indoor HDTV antenna we have ever tested. We're here to tell you that is no longer the case. Enter the Mohu Leaf Plus Amplified Indoor Antenna ($73.99). The Plus retains everything we loved about the original and adds amplification to help you pull in more channels.
We also discuss:
  • Dolby Atmos
  • 10 Ways to Save Energy with Home Control
  • Try MetaX to tag files on a PC for use in iTunes and AppleTV
  • MP3 or Lossless: See If You Can Hear the Difference with This Test
  • Samsung Widens Lead Over Panasonic In Plasma TV Shipment
  • Verizon Automation and Monitoring Not Smooth Sailing
  • Denon announces new core line of AV receivers
and a lot more...
listen now - mp3
Braden Russell
Host, HDTV & Home Theater Podcast
Check it out at www.htguys.com
Braden Russell is offline
Reply AVS Forum Podcasts
