July 20th - 4 Great TVs, Home Tech Trends and more on the DTV Green Dish - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-20-2012, 12:27 AM - Thread Starter
Braden Russell's Avatar
Today's Show:
There was a disturbance in the HT Guys force after our initial revue of the DTV Green Dish, a.k.a Dishtenna, so we decided to post a little bit of an update to the original review. We also cover four very highly rated HDTVs you should consider if you're looking to buy a new one and ten technology trends that may change the way you live.
We also discuss:
  • Netgear NeoTV Streaming Player
  • The HDTVs With The Best Picture Quality
  • Top 10 Emerging Tech Trends That Will Change Your Home
  • Roku Rolls Out Software Upgrade, More Features Coming Soon
  • With Channel Blacked Out on DirecTV, Ratings for Nickelodeon Plunge
  • Samsung launches massive 75-inch ES9000 LED TV
  • AppleTV 3 preset on handbrake
  • SlingPlayer for iPhone, iPod touch, or iPad for $15
and a lot more...
listen now - mp3
Braden Russell
Host, HDTV & Home Theater Podcast
Check it out at www.htguys.com
Braden Russell is offline
Reply AVS Forum Podcasts
